Sekonic data transfer software? using L-758 DR
Started Apr 25, 2014 | Questions
VA-ArtG
Regular MemberPosts: 220Gear list
Apr 25, 2014
I have viewed the video on their site which said there would be a follow up video (apparently never accomplished) and am still wondering about the actual workings.
Apparently shots are taken in JPG?
It also seems you can only have a maximum of 3 settings, but although it is calibrating the camera, it appears that the calibration is also based on the lens used, so max. of 3 lenses?
If you use a 4th lens for shooting is the calibration ignored?
Has be done with camera set to full stops. If you go back to 1/3 stops (which I normally use) does that affect calibration
Any help would be appreciated.
Thanks,
Art
'There is no limit to what a man can do so long as he does not care who gets the credit.'
-Philip Hyde (1922-2006)
 VA-ArtG's gear list:VA-ArtG's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II
Trout479
Junior MemberPosts: 44
Re: Sekonic data transfer software? using L-758 DR
In reply to VA-ArtG, Apr 25, 2014
While I do not have that specific model, I have recently purchased a 478D.  I noticed that the meter was over exposing based on the camera meter, so I ran the transfer software to calibrate the meter to my 6D. I first upgraded the firmware on the 478D to the latest edition, (ver 3.092) after deleting previous editions per instructions.
I  took three shots, -2 EV, 0 EV, and +2 EV, of my Color Checker Passport, opened them in LR, cropped them and saved out as JPEGS.  I then followed the steps as outlined here. DTS software instructions . There are links for Win or Mac on the tabs at the top of the page. If you follow the instructions, I thought the process was pretty straightforward.  I need to create a few more for the most common lenses I use.
After checking the meter suggested settings, versus the camera settings for getting a proper exposure, I think my results are very close based on pictures using one or the other.
VA-ArtG
VA-ArtG OP
In reply to Trout479, Apr 26, 2014
Thank you
Art
