Best Flash for D610
Started Apr 25, 2014 | Discussions
mbyoh
New MemberPosts: 8
Best Flash for D610
Apr 25, 2014
Just picked up a D610.  Couldn't find the answer in a search, so could anyone tell me what are the fully compatible Nikon Flash units for this camera?
I have an SB 800 for my D90 and a backup SB 600.  I see presently it looks like the SB 910 and SB 700 are current flashes.  Would the SB 700 be a step up from from the 800 I presently have, or would it pay to spring for the SB 910?  I'm mostly thinking of power output as when I shoot a wedding and such, I use a Fong diffuser or bouce, so power is the criteria.  THough I do use the commander remote control sometimes. that is not the main crtieria.
Mike
Nikon D610 Nikon D90
Wahrsager
Regular MemberPosts: 152Gear list
Re: Best Flash for D610
In reply to mbyoh, Apr 25, 2014
Mike
SB-910! It's superb. Maybe consider this Nikon battery accessory:
http://www.adorama.com/NKSD9.html
 Wahrsager's gear list:Wahrsager's gear list
Nikon D7000 Nikon D800 Nikon D800E Nikon D4S Nikon AF-S DX Nikkor 35mm f/1.8G +15 more
Photofunster
Senior MemberPosts: 1,548Gear list
Second the +SB- 910 it's an awesome speed light.
"you light up my life"
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4 G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Apple iPad 3G +WiFi +2 more
calson
Veteran MemberPosts: 6,790
The SB700 would be a half step down in terms of power and IR AF functionality. The SB-800 that you have is the best you can do at this time. I have 3 of them and would have bought a fourth but Nikon stopped production to release the SB-900 series that overheat and shutdown completely without warning. The SB-910 may be better than the SB-900 but neither adds significantly more power than that provided by the SB-800 and they do have a wider range of focal lengths that will work for IR AF assist but the difference is negligible for 99% of photographers.
Wahrsager
In reply to mbyoh, Apr 26, 2014
PS-  For any Nikon speedlight, the SC-29 cord (for off-camera flash) has a built-in AF beam and is a fantastic tool to have. Durable as well!
Rexgig0
Senior MemberPosts: 2,889Gear list
Your present flashes are compatible, as are the SB-900, SB-910, and SB-700.
Mike
The SB-800 is more powerful than the SB-700. The SB-910 is certainly a very nice flash, and I prefer its controls, but the SB-800 is still a viable, powerful Speedlight. My wife prefers the familiarity of the SB-800, which she uses for forensic shooting at night, and we have two spares. (I was lucky to find an "open box" SB-910, as it was being marked-down, and saved about $150.)
I wear a badge and pistol, and, primarily with 7D cameras, with an EF-S 10-22mm and 100mm Macro L, make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. During personal time, I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm f/2.0L USM Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +29 more
