The camera to beat:
Started Apr 25, 2014 | Discussions
1prime Senior Member • Posts: 1,108
The camera to beat:
I quote from DPR: "The X-T1 is probably Fujifilm's best camera to date, offering a compelling combination of intuitive handling, excellent image quality, and one of best electronic viewfinders we've seen. It also features one of the most impressive autofocus systems on any camera at this price level, both in terms of accuracy with fast lenses and tracking moving subjects. Over all it's a hugely engaging and capable camera, and one that's fundamentally a joy to use."
Ok, Sony, your target has been set up, now take aim and fire!  I'm tired of continually seeing a Fuji product with an 84% rating. By about this time you should be able to muster a competitor APS-C camera that will outscore the X-T1's 84%.  Yes, the well price positioned A6000 is doing well for you with a better than 10% market position.  But I hope you've got an A7000 on your drawing board to overcome the X-T1. I expect your A7K to attend to those pesky details you sometimes say will be fixed on later models. And while you're at it, why don't you fool all of us and bring an A7K in at an attractive price much closer to the A6K than the X-T1? This is your chance to attain an extremely high DPR score and keep us NEX-7ers in your stable.
1prime
Fujifilm X-T1 Sony a6000 Sony Alpha 7 Sony Alpha DSLR-A700 Sony Alpha NEX-7
blue_skies
blue_skies Veteran Member • Posts: 9,638
Re: The camera to beat:
1prime
I don't know, Don.
  • Fuji X-T1 + 'kit' lens: $1,699
  • Sony A6000 + 'kit' lens: $800
Sure, the X-T1 scores higher, but it should be compared with the A7, not the A6000.
Kudos to Sony for bringing a full-feature top-of-line spec APS-C camera out for $650 (body only).
  • In terms of market share: Sony 1 - Fuji 0
  • In terms of bragging rights: Sony 0 - Fuji 1
Pick your horses...
And there is room between the A6000 and A7 for either/both an A7000 and A6...
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Carl Zeiss Biogon T* 2/35 ZM +33 more
1prime OP Senior Member • Posts: 1,108
1prime
I don't know, Don.
Pick your horses...
Henry
Henry, Thanks for your reply.  I tend to agree with your conclusion that there is room for something along the lines of an A7000 without or with hump.  My point is "wouldn't it be lovely" if Sony achieved the the bragging rights to go along with their increasing market share.  Implicit in this accomplishment would be a solid APS-C camera with all its bells and whistles well fastened.  That is, enhance the room for improvement on the A6000.  And l think Sony can do that at a price between the 2 comparative cameras you mention.  Don
1prime
Petroglyph
Petroglyph Senior Member • Posts: 4,960
If I could own them all it (X-T1) would be on my list.  But it's way down there and the 645Z is on that dream list overshadowing everything below.  In practical terms that is a spot on the list I know I'll never get past.
 Petroglyph's gear list:Petroglyph's gear list
Sony Alpha 7R II Pentax K-1 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +5 more
blue_skies
1prime wrote:
1prime
I don't know, Don.
Pick your horses...
Henry
1prime
For Sony products: yes.
To compete with Fuji: no.
Fuji is really a very niche-oriented camera manufacturer. They consider themselves as the digital replacement for Leica users. In their portfolio, camera and lens positions, they are keen to target the 'pro' user (more UI buttons) and their lenses are 'one-up' to Sony's lenses. I believe that they consciously aim to 'better' the Sony lenses by allowing R&D higher budgets (cost) which satisfies their target market (the product is now better).
The X-trans sensor has been very confusing. It seems unnecessary - I think that Fuji would have gotten to where they are now by simply following the above strategy to the tee. I think that the X-trans sensor has hurt them more then helped them in the end. But, purist believe that X-trans is ahead of equivalent Mp bayer sensors (I think it is lack of AA filter with sharp lens).
Sony can target Fuji, but it is the small (but expensive) volume. They seem to do better by following the A7/r targets: same $$$s, different users.
Sony is much more consumer oriented - for every Fuji camera that ships, Sony sells ten more. Sony deals in quantity, and products have to fit certain budget constraints.
I think that Sony got pushed 'higher end' by its own customers. Many left Sony to go to Fuji (even many forum users here) out of frustration with roadmaps, product maturity, lack of choices - only to learn Fuji frustrations afterwards. But the ones that stayed, and the ones that came in, have certainly justified the current mix of (expensive) cameras and lenses for E and FE mounts.
Many still believe that APS-C is not for consumers - only for prosumers and hobbyists, even some professionals. Stick to P&S or m43 if a consumer. Canon and Nikon (and Sony SLT) proved them wrong with their 'easy-to-use', but bulky, APS-C mirror based cameras - on which many use with the kit-lens only
Fuji went on a limp - believing that a high-end APS-C mirror less market can be realized, and so far they seem to be correct.
Sony did the unthinkable: they made the APS-C market a consumer market. I would argue that, up until the A6000 and X-T1, the APS-C mirror less cameras has had a very steep learning curve and its products are rather hard to use, making the experience not that much better than dabbling in FF camera/lenses.
Sony has been plowing forward - with incredibly cheap cameras (their 3 and 5 series top in volume way above the 6 and 7 series), and customers have been dealing with their low keeper rates just because when you do have a keeper, it is an impressive one!
It is funny, Sony is covering everything from cell phone cameras to all size still cameras, as well as video. They have a better perspective on how (photographic) products compare than any of us. But they are a consumer (electronics) oriented company, and they think in (annual) products, not systems... Fuji is far more traditional in comparison.
My guess
Oh, and a good thing: I don't see many Sony users purchasing Sony products for bragging rights
Henry
ttan98 Senior Member • Posts: 1,836
1prime wrote:
1prime
I don't know, Don.
Pick your horses...
Henry
1prime
Also Sony should provide better quality lens than its kit lens 18-55mm, something similar to Fuji's very well received lens, 16-55mm f2.8 at a reasonable/affordable price unlike the Sony's Zeiss 16-70mm at $1000. Until Sony starts developing then release that lens I wouldn't buying more Sony body.
captura Forum Pro • Posts: 21,781
blue_skies wrote:
1prime wrote:
1prime
I don't know, Don.
Pick your horses...
Henry
1prime
Henry:
Yes, a metal body NEX-7 replacement camera next year. But they've lost the way, now.
Fuji X and OMD are huge competitors...and may be way ahead in sales of better mirrorless cameras.
Perhaps the A7/A7R are more like Niche cameras than the Fuji X line. Many potential buyers of the FF Sony's are afraid of the lack of lenses available to them. And there's  no denying the quality of Fuji lenses.
Olympus has also swung over to a Bayer-less sensor with the E-M1. No doubt about the photo quality adavantages of Bayer-less.
There is a whole range of Fuji 'X' cameras to choose from, starting with the X20, at $500. The X100 and now the X100s have been judged to be the most popular personal cameras for use by professionals.
Sony is much more consumer oriented - for every Fuji camera that ships, Sony sells ten more. Sony deals in quantity, and products have to fit certain budget constraints.a
Unquestionably the quality aspect is on the Fuji side. Have you recently owned or at least handled one?
Again, they went mainly to get a higher quality, albeit more expensive product.
And many others believe that APS-C is ideal.
Sony, at least temporarily, abandoned the high-quality metal body APS-C camera when they failed to issue a replacement for the NEX-7. It is Sony's own fault that the Fuji X and OMD lines are doing extremely well in sales.
Enthusiasts and pros. are not impressed by incredible cheapo cameras.
They have made their share of mistakes.
Steve
My guess
Henry
Mel Snyder
Mel Snyder Veteran Member • Posts: 4,088
ttan98 wrote:
1prime wrote:
1prime
I don't know, Don.
Pick your horses...
Henry
1prime
Sony can never beat Fuji on quality or price
1.Fuji is a top optical company. It doesn't have to pay a logo license fee to anyone, or to hire an outside firm to design their lenses, or have contractors make the lens components. On a $1000 lens, that probably saves them $300. Unlike Sony, it's been making lenses for more than 70 years.
2. Sony is under the gun from shareholders - specifically activist investor Dan Loeb, who is whipping them mercilessly over profits. Dan owns 7% of Sony shares, more than all the management and board combined.
 Mel Snyder's gear list:Mel Snyder's gear list
Sony Alpha NEX-6 Sony Alpha 7 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 55-210mm F4.5-6.3 OSS Leica Summicron-M 50mm f/2 +12 more
Re: Fuji XT-1 vs SONY a6000 IQ AND AF TRACKING SPEED/ACCURACY
This guy did some tests:
http://chewyenfook.smugmug.com/Photography/Fuji-XT-1-vs-SONY-a6000-and/38693187_FJ37Hc#!i=3199673547&k=5W67zXW
"Finally I managed to try out the Fuji XT-1 and Sony a6000. Just for comparison sake, I have included one picture taken with the Canon 5D MK3 taken at ISO1600.
Note: In another folder, I have some Sony 7 and 7r shots for a quick review. You might want to check that out.
Theer are plenty of technical details which one can easily google so I shall skip all that and proceed straight to the pictures. I was not able to take the cameras outdoors (staff didn't allow that) so all tests were done indoors. But in a sense this is a blessing because the lower light indoor conditions posed a greater challenge for the cameras.
One of the things I desperately wanted to find out was whether these latest mirrorless models can actually track as well as a DSLR. Past Fuji and Sony models have exhibited dismal performance. Well, the good news is that both the XT-1 and Sony a6000 can track. I haven't had the chance to put them to test in outdoor conditions. I tested them indoors and under rather bad lighting conditions but they still work. The Fuij XT-1 and the Sony a6000 have broken the barrier and crossed the rubicon. From now, APS-C sized mirrorless cameras will only get better and better, especially in the AF department.
Which mirrorless does better in AF, I will reserve comments until I have the opportunity to do more detailed tests. Fuji XT-1 does up to 8fps; the Sony a6000 11 fps. This quick test is mainly about IQ and AF tracking in real life situations. All I can say at this point is that higher frame rate is useless if it cannot maintain focus. It is better to have a slighter lower frame fate with higher percentage of pictures in focus.
As for static shots, there is nothing to worry about - both models snap into focus almost instantly. They are more than adequate to do normal human activity photos.
While these mirrorless cameras do track but their AF system is not as sophisticated and refined as models such as the 5DMK3, D4 or 1DX."
-more at link.
quezra Senior Member • Posts: 3,915
The secret of unhappiness is to...
...always compare with others
 quezra's gear list:quezra's gear list
Sony Alpha 7 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony Alpha NEX-5N Panasonic Lumix DMC-GH3 +10 more
GaryW Veteran Member • Posts: 8,187
Re: The secret of unhappiness is to...
...and lust after the next new thing.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha NEX-5 +9 more
Mel Snyder wrote:
ttan98 wrote:
1prime wrote:
blue_skies wrote:
1prime wrote:
I quote from DPR: "The X-T1 is probably Fujifilm's best camera to date,....
Ok, Sony, your target has been set up, now take aim and fire! I'm tired of continually seeing a Fuji product with an 84% rating. By about this time you should be able to muster a competitor APS-C camera that will outscore the X-T1's 84%. Yes, the well price positioned A6000 is doing well for you with a better than 10% market position..... This is your chance to attain an extremely high DPR score and keep us NEX-7ers in your stable.
And yet, it seems like the A6000 would make a fine Nex-7 upgrade.
At some point, it has to be considered that if the Fuji is that great and such a great deal, who cares what Sony does?  Just buy the Fuji.  Of course, all camera systems have their drawbacks too.  The grass is always greener....
DPR gives the Nikon D7100 an 85% -- maybe that would be better than the Fuji.  You'd also have more of a selection of lenses.  I think the typical Fuji buyer probably likes the exclusivity of not being part of the crowd, kind of like a Volvo owner.
1prime
I don't know, Don.
The A6000 will sell a ton more -- these are vastly different price-points, and going over $1000 is going to be really tough for most people to get past.   And, I agree, if you get into the A7 price range, you have to consider the advantages that that might bring.  But DPR only ranks the A7 as an 80%/Silver, so it's obviously no good.
Pick your horses...
Henry
1prime
Why couldn't you buy a body-only A6000 and add the 16-70 and be at the same price-point as the Fuji?  Or do you want Sony to make a kit lens that is better than the 16-70?  That would seem odd and unnecessary to me.  Or if you mean that Fuji's kit lens is better than Sony's 16-70, I guess I'd have to see a comparison to believe that there would be a significant difference, but that certainly should be something to consider if purchasing a $1700 system.
In addition to CZ, you'd think Sony would have some leftover Minolta know-how.  Anyway, if you mean that $1000 is too expensive, Sony wouldn't attempt to sell a lens for $1000 unless they actually could sell it.  I'd rather have some Minolta-style lenses that are good bang-for-the-buck, but Sony seems to be focusing on the higher-end right now.  Oh well!
OK.  Are you saying he'll force Sony to make poor decisions to make short-term profits?  Or?
Gary W.
nevercat Senior Member • Posts: 3,193
captura wrote:
blue_skies wrote:
Henry:
Can you show sales figures that show this? The only (and I know not very reliable) figures I see is in Amazone.com, where there are 6 Sony Cameras in the top 10 (3 A6000, 1 Nex6, 1 Nex3n and a A7). The A6000 is on the first place, the third place and the 7th place) The Fuji XT-1 is 2 times (place 2 and 4) and there are two Olympus cameras (E-PM2 on 5 and E-M10 on 9) no E-M1 camera in the top 10)...
No there is no denying the quality of the Fuji lenses, but whrn you look at the quality of the Sony FE lenses, they score vey hight too, even higher then the Fuji lenses...
The E-M1 has a normal bayer sensor, only no anti aliasing filter.
Yes, but not all X cameras are ILC cameras. So there is no need to compare them with the ILC cameras from Sony. When you want to go cheap, look at the A3000 from Sony, $300 for a mirrorless camera...
Is it? The quality of the A7/r and their lenses is very high, many are better then the Fuji cameras, and these cameras and lenses are full frame!
Fuji is in every aspect more expensive then Sony. Fuji have no FF camera, but their X-T1 is in the same price group as the A7! The A7 is FF, has more MP on sensor, has the better lenses...
I do agree with you, APS is a great sensorsize....
Well did they fail? What camera was better selling, the Nex6 or the Nex7? Isn't it wise to come with the better selling camera first? The high end Nex 7, is only high end for the metal in the body, not for IQ, focus speed etc.
Well in fact they are! Many of the real enthousiasts are using cheaper cameras, both as back up and as first camera. They understand that you don't need the most expensive camera anymore, you need the camera with the features they need. Pro's is a very small group, they buy the cameras with the real pro service, so no Sony, Fuji, Panasonic and Olympus for them... Only Canon and Nikon, they need the service that those offer, and pay the price for it.
Fuji makes very nioce cameras, but their price is rather high. Sony makes very nice cameras too, at a lower price and a different approch, Sony goes for a modern camera look and feel (just like Leica with their new Mirrorless) Fuji goes for the more traditional way. Both types of cameras have their supporters...
Steve
My guess
Henry
KwhyChang Veteran Member • Posts: 3,527
1prime
There will always be a camera to beat.
In my opinion I think the Sony A7/R is the camera to beat at this point in time.
Dave
 KwhyChang's gear list:KwhyChang's gear list
Nikon Coolpix P900 Sony Cyber-shot DSC-RX100 III Sony Alpha 7
NomadMark
NomadMark Contributing Member • Posts: 602
At 1700 bucks, I'll take a FF A7 any day over the X whatever APS-C Fuji Camera.
 NomadMark's gear list:NomadMark's gear list
Sony Alpha 7R Canon EOS 6D Canon EF 24-105mm f/4L IS USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 17-40mm f/4.0L USM +12 more
Why must there be a camera to beat?
Why must there be a camera to beat? And what do we want to beat?
Size? The A6000 is smaller then the X-T1!
Price? The A6000 is cheaper then the X-T1!MP? The A6000 has more then the X-T1!
Weight? guess what camera is heavier... (I give a hint it is not the Sony)
Number of dedicated lenses? Again Sony who wins!
We could go on and on like this. There is no camera to beat, not for Sony nor for Canon, Nikon, Fuji etc! Buy the camera you like best, use it in the way you like best and enjoy it! Forget about the "best" camera, the best camera is the one you have with you, not the newest toy in the shop!
John Gellings Senior Member • Posts: 1,689
All of these cameras are good... even great.  Why focus on camera wars?  Just go out and photograph with what you have and forget about scores.
 John Gellings's gear list:John Gellings's gear list
Fujifilm X70 Fujifilm X100T Nikon Df Fujifilm X-E2 Fujifilm X-Pro2 +6 more
Edymagno Veteran Member • Posts: 3,096
Re: Why must there be a camera to beat?
I basically agree. But aren't we mostly here to talk about gear?
Eduardo
 Edymagno's gear list:Edymagno's gear list
Sony Cyber-shot DSC-RX100 IV Sony a6000
Yes this is a gear forum, and we do talk about gear, but why has it in the this camera beats that camera style?
Ilike to talk about our gear, how we can get the best results out of it, how some new lens can help to get a better picture, what camera and lens combination is best for the job etc. I like to talk about the differences in cameras and why I find it important. But I don't like to talk about beating one camera...
Eduardo
