Long Exposure Question
Started Apr 24, 2014 | Discussions
jrk Senior Member • Posts: 1,853
I've seen many photos that folks have taken that required a long exposure to achieve.  Sometimes ND filters were used and sometimes simply shooting at night or very low light conditions.  How does one know how to determine the exposure when shooting in these scenarios?  I realize when using an ND filter I can calculate the exposure based on normal (i.e. without the filter) then factor in the filter, but what about at night.  Is it trial and error or are there some basic rules?  Thanks
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Canon EOS 70D Fujifilm X-E2 Fujifilm X-T1 +12 more
darngooddesign Senior Member • Posts: 4,696
Re: Long Exposure Question
 darngooddesign's gear list:darngooddesign's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
flbrit Veteran Member • Posts: 3,665
Thanks for the links. I had one but lost it. They are both firmly is my browser now.
Brian
 flbrit's gear list:flbrit's gear list
Sony Alpha 7R II Carl Zeiss Distagon T* 1,4/35 ZM Canon EF 100-400mm F4.5-5.6L IS II Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +6 more
Brian
I believe the way it works is choose your aperture and use the rule of 500 to get your maximum exposure time before you get star trails. Then if its too dark increase the ISO till you're happy.
Jim Radcliffe
Jim Radcliffe Forum Pro • Posts: 11,480
Forget the rules..... kinda.. Experiment
Forget the rules because every situation will be different.  I have found that trying to follow rules eats up more time than simple trial and error.
Note:  Take extra batteries.  I usually always have four fully charged batteries when I go out doing long exposure shots (day or night).
I do a lot of night photography and the easiest way to determine what will work is to set the camera up with a remote release and set it on bulb.  Obviously a sturdy tripod is a necessity.  I usually shoot wide open to begin with.  Take a shot and adjust one of three things until you begin to see what you are trying to achieve on the LCD.
The three things you can adjust are:
  1. ISO  (last thing to adjust due to noise)
  2. Shutter Speed  (most used)
  3. f Stop (if it is really dark.. wide open, otherwise you can play a bit by stopping down and going longer with your exposure.  Distance to subject is also important.
When using Bulb mode the Fujis will display the amount of time that the shutter is open on the LCD.  It will count UP and that info is also displayed in review of the photo.
Set the ISO to 800 or 1600 to begin with.. if it is really dark, move to ISO 2000 and up.  I've had good luck with the Fujis up to 3200.
When I am shooting a starscape (wide field astrophotography) I usually try not to go beyond a 25 second exposure because you will begin to see star trails caused by the rotation of the earth.  The longer the exposure, the more stars you will see but be careful of ambient light that may interfere with your shot.
If you are shooting during the daylight you will shoot at the lowest ISO setting possible and use a neutral density filter.  I use a variable neutral density (very pricey) so I can shoot long exposures to get milky water and clouds and even make people disappear in crowded places... really long exposures.
Don't throw away the rules completely but honestly, you will learn more by experimenting.. that is the beauty of digital photography.. you can learn faster.
Jim Radcliffe
http://www.boxedlight.com
The ability to 'see' the shot is more important than the gear used to capture it.
 Jim Radcliffe's gear list:Jim Radcliffe's gear list
Leica D-LUX 4 Panasonic Lumix DMC-GF1 Pentax K-5 IIs Fujifilm X-E2 Fujifilm X-T1 +1 more
clockface Regular Member • Posts: 171
Why not put on the filter from the start and let the camera sort the exposure? I thought most cameras these days meter through the lens.
Jim Radcliffe
Because you don't learn anything doing it that way.
Jim Radcliffe
Jim Radcliffe
So with a 3 stop ND filter you leave it off, let the camera meter the scene, switch to manual, put the filter on, adjust the settings by 3,stops, and then take the pic. Learned a lot?
afragisk Senior Member • Posts: 1,291
I usually shoot with 10 or 13 stops and in my limited experience, I agree with Jim. I find it hard to get it right at a pre-determined exposure time and I'm typically one stop off - over or under. Maybe I lack lengthy experience but in either case, I would agree that for a beginner it's best to at least anticipate that there will be a learning curve - and more fun too. By the way, there are apps that make the theoretical calculation of lengthy exposure times easy. Other than that, hang your heavy bag from your steady tripod or do what I do, use a Joby and wrap it around a rail or branch as strong as you can:)
http://www.flickr.com/photos/apollonas/
Fuji XE-2, Canon FD 300 4L, Fuji 55-200, Fuji 56 1.2, Fuji 27 2.8, Fuji 23 1.4, Fuji 14 2.8, Bower 8 2.8
Yes, fair enough, I agree. It depends on the number of stops. Fewer stops, I would let the camera decided. 10 stops then calculate yourself as you will be outside the camera's meter operating envelope.
Chris Dodkin
Chris Dodkin MOD Veteran Member • Posts: 6,818
Here's what I use
It's a long exposure slide-rule, you can find them online or on EBAY
Just Google Jiffy Calculator
I did a full write-up on this useful tool here
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
Jim Radcliffe
Jim Radcliffe
There are a lot of subtle things involved... if you'd rather the camera do the thinking, have at it.  I prefer my way because no calculator or formula is right for every shot.  After a while you get the feel for what you need to do from prior experience and I prefer that rather than using a formula.. you LEARN to read the light and I think that is important.
Jim Radcliffe
biza43 Veteran Member • Posts: 4,274
Jim Radcliffe
I have learned the following:
1. Quite often the strenght of the filter is not exactly as reported by the manufacturer. For example, the Lee big Stopper can vary between 9.5 - 10 stops, or thereabouts.
2. I think it is much more useful as to progresso your knowledge to learn so you can make decisions yourself. I prefer to blame myself for mistakes, than blame the camera...
www.paulobizarro.com
 biza43's gear list:biza43's gear list
Sony Alpha 7 Sony Alpha 7 II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 +2 more
Jim Radcliffe
I concede that a 10 stop requires calculation and experimentation. My initial comments where aimed at more moderate ND filter that restrict by 3 stops. My 37 years of taking photos has taught me to sometimes let the camera do the thinking, and somtimes to think for myself.
jrk OP Senior Member • Posts: 1,853
Re: Forget the rules..... kinda.. Experiment
Jim Radcliffe
Jim
Thank you, really appreciate you taking the time to respond in such detail!
Re: Here's what I use
http://f-sunny.com
Chris,
This is great little tool, I've already saved and printed a copy and will be looking to pick up one from an online seller.  Very helpful!
Thanks!
