Uncropped version of posted Grand Canyon image
Started Apr 24, 2014 | Photos
jerrysdean43 Contributing Member • Posts: 706
Comment & critique:
mrgooch2008 Regular Member • Posts: 495
Re: Uncropped version of posted Grand Canyon image
Your ISO should be higher and your f stop should not be f 2.You should have your f stop around f 11
 mrgooch2008's gear list:mrgooch2008's gear list
Fujifilm X-T1 Canon EF 14mm f/2.8L USM Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
Tom Zimmer
Tom Zimmer Contributing Member • Posts: 550
I agree, that a higher f-stop should have been used. f/8 would have been good and would have added some additional sharpness to the image. i assume your suggestion to use a higher ISO is to assure the shutter speed will be high enough to avoid any motion blur. In that I agree, the shutter speed should probably be at least 1/60 or higher.
Tom Zimmer
http://photobubba.com/
Fuji X-E1
And my old friends - Sigma DP2, SD10, SD14
(unknown member) Forum Member • Posts: 85
jerrysdean43 wrote:
Nice shot, but also an example of how bad x-trans is with details in landscape. Very unnatural detail rendering.
KariP
KariP Veteran Member • Posts: 4,086
Crop
jerrysdean43 wrote:
The composition will look better if you cut a bit from the left - so that the well lit rock and the foot are out. Then shift the "exposure" slider a bit to the left and then add a small amount of contrast and saturation - whatever software you might use
Next time you should use ISO 1000 and f 5,6 or 8.
Kari
SLR photography started in 1968, Canon DSLR cameras, lenses and now also a Fuji X-E1
60.21 N 24.86 E
 KariP's gear list:KariP's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS 7D Fujifilm X-E1 Fujifilm X-T1 +11 more
KariP
Re: Uncropped version of posted Grand Canyon image - Xtrans ?
tee1000 wrote:
Are you serious ?
We can not tell anything about xtrans by judging this image.  The air is not clear , it is evening light and we do not know the settings or PP used.  Detail rendering is usually a PP issue with X trans.... if there are any issues. I have not seen any compared to my Canon cameras.
Kari
60.21 N 24.86 E
Len_Gee
Len_Gee Veteran Member • Posts: 8,892
tee1000 wrote:
What exactly is it in the image that is "very unnatural detail rendering"?   Please elaborate.
 Len_Gee's gear list:Len_Gee's gear list
Fujifilm X100T Panasonic Lumix DMC-GX7 Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Panasonic 20mm F1.7 II
jerrysdean43 OP Contributing Member • Posts: 706
Re: Crop
Original post version is here.
http://www.dpreview.com/forums/post/53553563
Charles2 Veteran Member • Posts: 3,406
One treatment, perhaps 20 minutes later:
See larger at gallery
KariP
Re: Crop
Looks better  ... i did not notice the original post...
Kari
60.21 N 24.86 E
DVT80111 Senior Member • Posts: 2,141
My critics
You need to start before sunrise and hike down a few more milesĀ
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Fujifilm X-E1 Canon EOS 6D Canon EOS 70D Sony Alpha 7R II
EricWN Senior Member • Posts: 1,874
Re: My critics
Very nice both, I like the second one better.
KariP wrote:
tee1000 wrote:
Are you serious ?
Kari
60.21 N 24.86 E
You are right, it is not a problem of X-Trans, but of rendering X-Trans data. No Bayer Sensor makes those water color like rendering. I've seen these problems with landscapes, so brown to green to grey gradients and trees in distance, where all renderings (like Lightroom, ACR, Capture one) except the Fuji jpgs and DCRAW struggle with details. This image above is one more example.
I've used X-Pro 1 for a year and X-E2 for half a year now. I love rendering of portraits and architecture, but landscape isn't its strength I think.
