any issues with the A6000 body?
Started Apr 22, 2014 | Discussions
miro3
Senior MemberPosts: 2,396Gear list
Apr 22, 2014
Light leaks?
Shutter shock?
Continuous focus not good enough?
Other issues?
Sony a6000
ryan92084
Contributing MemberPosts: 521Gear list
Re: any issues with the A6000 body?
In reply to miro3, Apr 22, 2014
miro3 wrote:
Light leaks?
Didn't torture test, nor do I intend to, but shining an LED with max iso and shutter time showed no leak for me.
Shutter shock?
Wouldn't expect it with an EFC.  Haven't tried without.
That's what half the new threads for the past week have been debating : P
Other issues?
Other than my impatience with having to wait for it to charge so I can tinker with it some more?  Not so far.
 ryan92084's gear list:ryan92084's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
Joachim Wulfers
Senior MemberPosts: 1,537Gear list
miro3 wrote:
Light leaks?
Shutter shock?
Judge for yourself: http://www.dpreview.com/forums/post/53539788
Other issues?
NO to all these questions
Joachim
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 16mm F2.8 Pancake Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS +9 more
DtEW
Senior MemberPosts: 2,167Gear list
It's an unrealistic portrayal of the average camera body, and so engenders feelings of unattractiveness and inadequacy in other camera bodies?
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Sony a6000 Sony E 10-18mm F4 OSS Sony E 35mm F1.8 OSS Samyang 14mm F2.8 IF ED MC Aspherical +17 more
Tuloom
Senior MemberPosts: 1,798
Does not come in mauve.
miro3
miro3 OP
In reply to Tuloom, Apr 22, 2014
I can live wit that
slidez
New MemberPosts: 2Gear list
Went to buy the A6000 with kit, purchased, turned it on during dinner to check everything out and it didn't detect the lens. Had to go back to the store (luckily we had dinner in the same shopping center). We tested 2 different lenses, different battery and still no go. The electrical connection points looked pristine. Returned it since there were no more left to exchange, went home disappointed.
 slidez's gear list:slidez's gear list
Sony Alpha NEX-5N Sony E 16mm F2.8 Pancake Sony E 35mm F1.8 OSS Sony E 18-55mm F3.5-5.6 OSS
BoatGuy
Regular MemberPosts: 155Gear list
If you're asking about the body, and not the camera, then…
Build quality is well below Nikon.  No weather proofing.
Be here now, be someplace else later.
http://www.newmorning.info/page41/page41.html
 BoatGuy's gear list:BoatGuy's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Sony E 55-210mm F4.5-6.3 OSS Sony E PZ 18-105mm F4 G OSS
DtEW
In reply to BoatGuy, Apr 22, 2014
No Nikon at that price level has any weather-sealing, either.
BoatGuy
In reply to DtEW, Apr 22, 2014
You're absolutely correct, and I'm comparing it to a D300 which cost 3x the A6000.   But Sony doesn't offer a solid body at any price.
Hiking near the ocean yesterday in a strong breeze I felt like I was putting the a6000 at risk, something I never felt with a D300.
DtEW
A99? A77?  Both weather sealed.
And even  ignoring the existence of weather-sealed Sony bodies...  the same can be said about Nikon not offering any truly compact large-sensored bodies at any price.  Or not offering an EVF at any price.  So let's call the D4 an usability nightmare because it no Nikon can meet either of these arbitrary attributes we suddenly deemed to be the very most important thing in the world, all-other-considerations-be-damned.
Makes total sense. *rolleyes*
Jokica
Senior MemberPosts: 1,141Gear list
If I have to carrie D300, I would probably give up hiking
www.TaraMountain.com
www.PlaninaTara.rs
 Jokica's gear list:Jokica's gear list
Sony a6000 Sony a77 II Sony DT 16-50mm F2.8 SSM Sony E 50mm F1.8 OSS Samyang 85mm F1.4 Aspherical IF +1 more
Dsnoir
Contributing MemberPosts: 583Gear list
You are absolutly wrong, I dropped my Sony A99 on to the pavement from waist level, about 40 inches, and looked on in horror as it bounced about. My fear was that the, presumably delicate, in body stabilisation sysytem would not function, in fact apart from a slight scuf mark the camera works just fine. As for the A7r I can sadly report that I lent a friend my LA-EA2 adaptor complete with Minolta 28-135 lens, this droped to the ground with sufficient force to dent the filter ring, on the lens, with no adverse effect on the camera.
As for issues with the A6000, I do find that I occasionally active the C2 button, with the fleshy part of the hand just below the thumb, but its not a continuing problem.
 Dsnoir's gear list:Dsnoir's gear list
Sony SLT-A99 Sony a6000 Sony 100mm F2.8 Macro Sigma 8-16mm F4.5-5.6 DC HSM Sony 24-70mm F2.8 II +7 more
captura
Forum ProPosts: 21,492Gear list
Build quality well below any Fuji with 'X' in the name, too.
DtEW
In reply to captura, Apr 22, 2014
But way better functionality and performance than any NEX with a 5 in its name.
Everyone can troll/fanboy.
cosmonaut
Senior MemberPosts: 2,176Gear list
www.gregmccary.com
No camouflage version was a deal breaker for me.
unknown member
(unknown member)
miro3 wrote:
Light leaks?
Shutter shock?
Other issues?
I have a problem with AF-S - inconsistent results, worse than AF-C for static subjects.
I thought that for static subjects AF-S should be more precise, because it does first PDAF, and then fine-trims it with CDAF - not in my experience.
I can clearly see : all AF-C shots are in focus, 50-70 % of the AF-S shots are not.
Also, in DMF mode, if I adjust the focus ring I have focused shots, if I don't, many shots are not well focused - probably it uses AF-S.
Anybody else has the same problem ?
 5nex7's gear list:5nex7's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha NEX-6 Sony a6000 Sony E 18-200mm F3.5-6.3 OSS +54 more
miro3
miro3 OP
In reply to 5nex7, Apr 22, 2014
5nex7 wrote:
miro3 wrote:
Light leaks?
Shutter shock?
Other issues?
You should probably return it then?
unknown member
(unknown member)
miro3 wrote:
5nex7 wrote:
miro3 wrote:
Light leaks?
Shutter shock?
Other issues?
I want first to see if it is a general problem, or it is my camera.
Your's works well ?
ryan92084
miro3 wrote:
5nex7 wrote:
miro3 wrote:
Light leaks?
Shutter shock?
Other issues?
Your's works well ?
Is this still just with the 18-200 or have you replicated it with other lenses? I only have the kit as an AF lens and I haven't had an issue like this yet but I'll work with it some more this afternoon.
