Olympus lens calibration
Started Apr 19, 2014 | Questions
webstop1 New Member • Posts: 5
My new Olympus 45mm lens is not any sharper than 14-41 kit lens. I don't think this is normal.
Can someone in the know please answer: does Olympus calibrate lens under warranty?  (I tried  emailing Olympus with this question, but received generic meaningless answer.)
What other lens calibration option are available in California?
Thanks.
Guy Parsons
Guy Parsons Forum Pro • Posts: 23,940
Re: Olympus lens calibration
Thanks.
What apertures and what focal lengths of the zoom are you comparing, and at what subject distances? The 45mm is best at f/4.0~f5.6 and the 14-42mm Mk2 seems best at f/5.6 for 14mm, f/8 for 25mm and f/8 for 42mm.
The 45mm is a portrait lens and I guess that can mean that absolute sharpness is not a high priority for portraits so wide open it falls off a bit. That's from examining the blur index graphs at http://www.slrgear.com/reviews/showcat.php/cat/7
Regards..... Guy
Olympus PEN E-PL5 Olympus PEN E-P5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus 12-40mm F2.8 Panasonic Lumix DMC-LX3 +19 more
Dave Lively Senior Member • Posts: 1,739
Could it be the 14-42 is sharper than you expected?
If you stop them down a little and look in the central part of the image most kit lenses are very sharp these days. I think the softest kit lens I have owned in the digital age was the 18-55 that came with the NEX-5N I owned and when stopped down to f8 in the middle of it's zoom range even it was sharp enough to create moire. The advantage of premium lenses are things like better performance wide open, sharper corners, faster aperture, more contrast, less CA, better build quality, less flare, etc.
If you think there is something wrong with your 45mm I would send it back to Olympus if it is under warranty.  Sometimes lenses will come with a decentered element or some other defect.  But there is nothing to calibrate.  Since m43 cameras use contrast detection for autofocus they do not have the front or back focus issues SLR lenses sometimes have.
berni29 Senior Member • Posts: 2,453
Hi
There are some very simple tests you can do to check for decentering. Lensrentals has a good one. The 45mm should be sharp even wide open. Do some tests, but you must follow the rules closely in order to get meaningful results.
Berni
Berni29
EM-5, GM1 + Pana 12-32mm, 35-100mm f2.8, 20mm, 14-45mm Oly 45mm, 50mm F2 macro, (prev GH1, E30, E510, E1, E300, LX3)
 berni29's gear list:berni29's gear list
Panasonic Lumix DMC-GM1 Olympus E-M1 Olympus OM-D E-M10 II Panasonic Lumix DMC-GM5 Panasonic Lumix G 20mm F1.7 ASPH +5 more
(unknown member) Senior Member • Posts: 1,178
Can you please post a full-sized example?
We can help diagnose your issue better, and make sure you keep the exif information intact please.
 dpalugyay's gear list:dpalugyay's gear list
Olympus OM-D E-M5 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +4 more
webstop1 OP New Member • Posts: 5
Thanks to all for some good information.
I did not do any specific tests and it was just general observation on my part.  When I purchased Olympus 45 mm lens I expected it to be generally sharper than the kit lens, something closer to Canon 50 mm 1.4 in pure sharpness.  Not even close. In reality overall results were not much different than 14-42 II lens.
I happen to leave close to Canon.  After purchase I brought them 50 mm lens for calibration.  They did it under warranty and it has been perfect ever since.
So I wonder, if I can do the same with Olympus.
jalywol
jalywol Veteran Member • Posts: 7,384
If you think your 45mm is less sharp than your kit lens at the same apertures, then your 45mm probably has a problem.  Occasionally this will happen.....I had the 45mm and it was blisteringly sharp pretty much throughout its aperture range, so I suspect that if your kit lens is sharper than your copy of the 45mm, you most likely have a bad one, and you should return it for exchange.
With CDAF, there is no front or back focus to calibrate for as the AF sensors are on the sensor itself, not off sensor in a different plane.  The motors moving the lenses for AF are also different, so there is nothing to calibrate there either (as there is in the large Canon lenses).
Essentially, if the lens has a focus issue, the thing to do is to swap it for another one.
-J
Again, post a photo of the unsharp concern.
With exif intact.
Re: Again, post a photo of the unsharp concern.
Here is one example.
Milla
In my opinion area in focus (front eye and hair next to it) lacks that crispness that I usually get from Canon 50 mm.
EXIF information should be included since I never removed it. In case it is somehow lost here it is:  45 mm lens, ISO: 200, f/1.8, exposure 1/200, camera: E-M5, Metz flash.
Thanks.
jalywol
The only thing in focus in this photo is the hair in front of her face.  Everything behind that is out of focus...could you have moved in between focusing and shooting?
Try the same shot using face detect and see what you get....
-J
Guy Parsons
Yup. In my opinion way to wide an aperture for a human face so close at that focal length. As noted only a few strands of hair are in focus, the rest is behind the acceptable depth of field at f/1.8.
Regards...... Guy
Her hair above her left brow
..is very sharp.  I think you should try face detect as the previous poster stated.  I really hope your 45mm is fine.  It's one of my best lenses and very very good for portraits!
Re: Her hair above her left brow
Hi
Apart from being OOF that is a lovely image. Reminds me of the shots I used to take when mine were that age.
I agree with the previous posters, but strongly suggest you test the lens for decentering. It is an easy test.
Berni29
berni29 wrote:
Hi
Berni29
How do I do such test?  You previously mentioned Lensrentals: I looked briefly at their website but did not find any instructions.
Thanks.
s_grins
s_grins Forum Pro • Posts: 10,294
Thanks.
CDAF do not need lens calibration. You have asked fussy question, you have got fussy answer.
If your NEW lens does not satisfy your needs, there are several reasons for that, except of lens calibration
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Sigma 60mm F2.8 DN Art Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +3 more
tt321 Senior Member • Posts: 7,265
webstop1 wrote:
berni29 wrote:
Hi
Berni29
Thanks.
You can do the upside down test.
At close focus this is somewhat easy - you can use a computer screen with a lot of text, at longer focusing distances you need to find appropriate large targets.
With a computer screen, set the camera close enough so that it's entire view is filled with text. Now try to set the lens as perpendicular to the screen as possible so that the text does not converge/diverge from left to right or from top to bottom - parallel text should run parallel. Focus at the centre spot. Shoot a picture. Note down five control characters (letters, numerals, punctuation, etc.), one at each corner of the frame and the last one at the dead centre that was used to focus the shot. Depending on the size of the text you may need to use groups of characters for these five reference points. Turn the camera upside down. Let's assume these characters are A, B, C, D for the corners from upper left in a clock-wise direction, and O for the centre. Maintain the same (as same as you can) relative position of camera vs. screen with being upside down being the only difference. Shoot with the exact same framing, i.e. the same characters in the four corners, and position O in the centre to focus at.
Now look at these two pictures at 100% pixel detail. First check the centre focus character to make sure that both pictures are focused correctly. Then examine the corners. If the lens is not centred properly, you will see inconsistent corner sharpness at different corners, e.g. A sharp and C unsharp in one shot and C sharp and A unsharp in the other.
Or you can make sure that you position the sensor parallel to the target with a small mirror fixed to the centre of the target - better with a large poster rather than a computer screen. Right-on aiming should show the camera (ideally the centre of the lens at the centre) in the mirror when you are aiming. If a shot is taken and one side or one corner is not sharp whilst others are, there is a problem with the lens.
zuikowesty
zuikowesty Senior Member • Posts: 2,054
DOF too shallow - f/2.8 or smaller needed
At 45mm, a head & shoulders shot needs f/2.8 to keep both eyes sharp, sometimes f/4 depending on angle. As others have said, there is some sharp hair, so it is a missed focus issue imho. Your lens may still have issues, but this photos shows that it is sharp at the in-focus plane.
Here are some shots with the OM 50/1.8 taken at f/2.8 - even here, both eyes are not evenly sharp, but there is more DOF.
https://www.flickr.com/photos/zuikowesty/12866290493/in/set-72157612863246970/
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus Stylus Tough 3000 Olympus Stylus 5010 Olympus E-410 Olympus PEN E-PM2 +12 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,062
The bits that are in focus are very sharp.
You may have wanted more to be in focus but that's not going to happen at 45mm f/1.8. What is in focus (especially hair) is very sharp. Should anything be wrong with the lens it is most likely in the areas that are out of focus here (corners).
I agree with others that if you were expecting something else to be in focus the issue is most likely that either you moved or the subject moved between acquiring focus and taking the shot.
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 +5 more
Guy Parsons
Re: DOF too shallow - agree.
Using http://www.dofmaster.com/dofjs.html and guessing that Milla was photographed from maybe 4 feet then this results at f/1.8 for 45mm (in inches and M4/3 sensor size chosen)....
So DOF is 1.49 inches and of course if viewed at 100% then that viewing size is above the 8x10 inch print standard that DOF is based on so the DOF shrinks even further.
Even at 5 feet distant the depth of field is still a poor 2.34 inches when viewed at 8x10 inch size.
So f/4.0 would probably be a better aperture for a face so close and slanted away from the camera, also the lens is sharper at f/4.0 if sharpness is what you are after.
Use face detect and set for nearest eye and a tripod so there's no shooter to and fro movement to cause problems.
Regards.... Guy
mchnz Contributing Member • Posts: 570
Re: upside down test, broadsheet newspaper page target
Last time I had a problem with a lens, Olympus suggested this test with a broadsheet newspaper page for a target.
I also found a row of distant houses is also a good target for testing for decentering when focused at infinity.
 mchnz's gear list:mchnz's gear list
Olympus E-M5 II
