D800 Question
Started Apr 18, 2014 | Discussions
Serathe
Serathe Forum Member • Posts: 54
D800 Question
So I saw the D610 is discounted a bit, but I think well if I'm going to spend that kind of money maybe I should just get the D800. In either case I think my wife may kill me. So in that case wouldn't the D800 be the better choice? LOL
 Serathe's gear list:Serathe's gear list
Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 50mm f/1.8D Sigma 70-300mm F4-5.6 DG Macro
Nikon D610 Nikon D800
backayonder Senior Member • Posts: 1,200
Re: D800 Question
Further punishment even after death  when she finds the lenses you also purchased
Wahrsager Regular Member • Posts: 152
Re: D800 Question
I don't think you'd have any regrets with a D800/E.  The files are wonderful as is the autofocus.  (Same can't be said about the D610's autofocus).
 Wahrsager's gear list:Wahrsager's gear list
Nikon D7000 Nikon D800 Nikon D800E Nikon D4S Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED +15 more
T O Shooter Senior Member • Posts: 5,026
Re: D800 Question
Here's the problem I see.  Buy the D610 and you'd probably go with cheaper glass. 24-85VR, 70-200 f4, etc., especially if you're concerned about what your wife has to say. If you buy the D800 you'd want the better glass.  Price difference between D610 and D800 will be the least of your worries. Not that fellows don't put the best glass on the D610 and vice versa with the D800, and not that it's the wrong thing to do putting the better glass on the D610, but in your situation the $$$$s are a concern.  So my advice would be to buy the D610.
Photography - It's a passion No other reason required.
 T O Shooter's gear list:T O Shooter's gear list
Canon PowerShot G5 Nikon D4 Nikon D810
M Lammerse
M Lammerse Forum Pro • Posts: 11,272
Re: D800 Question
If you're wife has just a bit of knowledge of DSLR camera's she knows that it is a typical "need" camera...So if you do not have need for a D800, buy a D610, and save your life...or at least your relationship
Michel
- Objectivity is of the very essence of photography, its contribution and at the same time its limitation -
http://www.fotopropaganda.com
http://www.fotopropaganda.com/blog
http://www.flickr.com/photos/9240992@N05
ARB1
ARB1 Veteran Member • Posts: 3,082
Re: D800 Question
If you get a D800 you may also need a new computer; that was my second expensive purchase.
Allen
___________
"It's easier to build strong children than to repair broken men."
-- Frederick Douglass
 ARB1's gear list:ARB1's gear list
Olympus OM-D E-M5 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 24-120mm f/4G ED VR Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +6 more
Robin Casady Forum Pro • Posts: 12,898
Re: D800 Question
Can you afford to offer her $5,000 in jewelry while you buy a D800 and a good lens?
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
munro harrap
munro harrap Contributing Member • Posts: 946
Re: D800 Question
You have a D7100. It has no AA filter its images are crisper and require less sharpening and then noise reduction as a result. It works better in low light as it has greater inherent depth of field.
If you like what it does the only improvement, and then only in size, would be a D800E.
But you already have a perfectly good camera, with a good enough lens. You could improve a bit with an old 18-70mm f3.5-4.5, which is what I have on mine, but avoid shelling out for the 17-55mm f2.8 because (and read DXO on this, not me!) it's only got about 6MP resolution over most of its scope( the barrier of all that yellow on the sharpness chart).
I think that if you are asking, and are worried, that maybe you already know you have got what it takes already....
Photofunster
Photofunster Senior Member • Posts: 1,548
Re: D800 Question
Yes, D800e only after you buy heavy life insurance.
Hey you only live once... Let her be happy after you are gone.
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR Apple iPad 3G +WiFi +2 more
Serathe
Serathe OP Forum Member • Posts: 54
Re: D800 Question
Well, maybe I will do the logical thing and slowly build up on FX lenses then one day buy an FX camera... I tried to bribe her with jewelry... I even told her her $20,000 car that we are paying off should count.... Just didn't quite buy it LOL
Josh152 Senior Member • Posts: 1,888
Something to consider
I see you currently have a D7100. If you buy a D610 just make sure you will be happy with stepping down significantly feature wise to get the full frame sensor. Especially when it comes to the AF system and the coverage of the actual AF points in the VF.
pmenear Regular Member • Posts: 178
Re: D800 Question
I own/shoot the D7100 and D610 and have used the D800E extensively, all my lenses are Nikon pro. The D610 is leagues ahead of the D7100 in everything except AF so trade up with confidence that the jump in quality is worth it. I would not choose the D800 over the D610 as there are not enough noticeable advantages to warrant the price difference but I would choose the D800E over the D610. The D800E would be my choice if price was a not a factor and the D610 if it is.
 pmenear's gear list:pmenear's gear list
Nikon AF-S Nikkor 800mm f/5.6E FL ED VR
TheMeister Regular Member • Posts: 247
Advantages of the D610
Since the OP asked about advantages of the D610 over the D800:
- significantly cheaper
- lighter, smaller and better built (mostly polycarbonate: more repairable, no dents)
- very slightly less noise at higher iso
- 6fps even without battery grip
- in camera timelaps
- slightly more pictures on one charge
- two sd slots (no ancient, bulky, expensive CF-Card slot)
- quite continous burst mode
 TheMeister's gear list:TheMeister's gear list
Canon PowerShot A410 Nikon D610 Nikon AF-S Nikkor 50mm f/1.8G Samyang 14mm F2.8 IF ED MC Aspherical Samyang 85mm F1.4 Aspherical IF +10 more
I forgot to mention the customizable U1 and U2 modes.
