Hand strap real????
Started Apr 18, 2014 | Discussions
JOHN Senior Member • Posts: 1,117
Hand strap real????
Did Nikon make this  Genuine Nikon Hand Strap II AH4 DSLR Camera.??
Can't find it in the online store or any ref to it.
Is it any good or is their better hand straps for my D800 ? and where is the best place to purchase one in the UK?
Thank Jonathan.
Nikon D800
Janoch
Janoch Senior Member • Posts: 2,408
Re: Hand strap real????
If it's the one on eBay, then it clearly is so *not* from Nikon!
Nikon do not make any accessories for $21... maybe except an eyepiece cap!
But I did a search on Nikon Global for that strap, no results.
http://www.nikonusa.com/en/About-Nikon/Search.page?searchCollection=SEARCH_ALL&q=hand+strap
Some seems to like hand straps, but it's not something, I like to use. Don't use any straps at all, btw...
 Janoch's gear list:Janoch's gear list
Nikon D800 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm f/4G ED VR +2 more
sillyconguru Veteran Member • Posts: 3,057
The only SLR hand strap Nikon produce is the AH-4; the so-called 'mkII' versions on ebay are not real. I have 3 AH-4 straps; they are expensive, but (IMHO) are worth it.
http://www.wexphotographic.com/buy-nikon-ah-4-handstrap/p1005488
 sillyconguru's gear list:sillyconguru's gear list
Canon ELPH 100 HS Pentax Optio I-10 Casio QV-5500SX Fujifilm FinePix X100 Fujifilm X20 +54 more
Island Golfer Senior Member • Posts: 2,342
dwight3
dwight3 Senior Member • Posts: 2,377
I had an AH-4 when I was looking for a new strap. The shoulder/neck straps I found inconvenient and at times I wanted to just carry my camera in my hand. Wrapping the strap around my wrist didn't hack it because it kept unwrapping and falling off, even when I put a twist in it.
So I tried an AH-4. It had some nice features, like being able to let go of the camera and have it dangle on your wrist without falling. You could use that hand for something else, although the attached camera did get in the way.
I finally gave up on it because it was designed only for portrait orientation. I had a D3 with the built in vertical grip and I used that grip a lot. But I couldn't reach the grip with the wrist strap. Moreover, I had trouble reaching the multi-selector when the wrist strap was tight. Even when it was loose it was a struggle to reach it. And when loosened enough to reach it easily, it wasn't secure.
Eventually I gave up looking for a strap. I use the camera without one. I hold it in my right hand. When I need my right hand for something else, I stick the lens in the crook of my left elbow and just hold the camera there. Works for me. I've never dropped it using this technique. I do not do any street shooting, or carry the camera in areas that might be a problem. Primarily event shooting and documentation at work.
 dwight3's gear list:dwight3's gear list
Nikon D200 Nikon D4 Nikon D800E Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 24-70mm f/2.8G ED +8 more
paulski66
paulski66 Senior Member • Posts: 2,746
$70 for a hand strap? Are they out of their f***ing minds?!?
Though I did like this in the description:
"...and is handy when holding the camera for a long time."
Is hand-y. Heh.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +2 more
Paul Spatafora Contributing Member • Posts: 921
http://optechusa.com/ez-grip-strap.html
I have this on my D800 and RRS L Bracket. Best strap I've used. Comfortable, adjustable and modular. Comes off easily and you can attach a strap to it. Check it out.
Hope this helps.
Paul
CoolHandLu Regular Member • Posts: 350
I use the Camdapter leather prostrap ( http://www.camdapter.com/handstrap/prostrap.html ).  For $27 bucks, it's incredibly compfortable.  Note that it does require a plate to be attached to the tripod screw mount on the bottom of the camera; my RRS plate does the trick nicely.
Brian
I don't want to achieve immortality through my work. I want to achieve immortality
through not dying. (Woody Allen)
 CoolHandLu's gear list:CoolHandLu's gear list
Nikon D300S Nikon D700 Nikon D5100 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II +18 more
Photofunster
Photofunster Senior Member • Posts: 1,548
All though the Nikon Wrist Strap is of decent quality, and does look good on my D800, it was actually a slight hassle to use, when you have to continually remove it from the tripod mount, every time you want to use a tripod, leaving it hanging from the camera strap bracket up top, because the plate on the wrist strap is not Arca-Swiss compatible, so you either must remove it, or have two plates on your tripod, which just wasn't worth the bother for me.
For anyone with a lighter camera, or who don't use a tripod very often, it would be awesome. It just didn't work for my style of shooting with the heavy D800. Perhaps its newer version II, would have  been a better fit and alternative. Too bad I never had a chance to try those out. If you can get version II, I'd go for that first.
For neck straps, this is how I also connect mine, burying the loose ends
https://www.flickr.com/photos/arkku/1335553912/
http://www.diyphotography.net/the-diy-r-strap/
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Nikon AF-S Nikkor 24-120mm f/4G ED VR Apple iPad 3G +WiFi +2 more
Stacey_K
Stacey_K Veteran Member • Posts: 7,815
Free and easy to make strap.
I make my own from the neck strap everyone throws away.
Cut strap to length
Stitch it into a wrist loop, I use a sewing awl made for canvas repair.
They work great and are very comfortable. You won't notice it's there until it saves you from dropping a camera.
Stacey
 Stacey_K's gear list:Stacey_K's gear list
Nikon D200 Nikon D700 Nikon D7000 Nikon D800 Sony Alpha 7 +14 more
mikemsphoto Senior Member • Posts: 1,495
I have the Nikon hand strap on both my D4 and D700 bodies. They are too expensive but are excellent quality and work perfectly for my style of shooting. I have a Really Right Stuff L bracket on the D4 and a RRS bottom plate on the D700. Both RRS plates have an attachment slot for a handstrap, so you just remove the tripod-socket plate that comes with the hand strap and attach the strap to the RRS plate or L bracket. Very sweet and tripod/ handstrap incompatibility problem eliminated. (Also for anybody about to do this, you don't have to cut off the finished tab-end of the handstrap to attach it. Feed the other end of the nylon web strap thru the plate slot to attach it. It works perfectly.)
Michael Sherman
http://www.msphoto.ca
Rservello
Rservello Senior Member • Posts: 1,157
I have:
http://www.amazon.com/dp/B003Y363BA/ref=cm_sw_r_udp_awd_FEvstb0M0KYCC
it's a clone of the old nikon strap and works quite well.
https://www.flickr.com/photos/49019071@N03/
http://www.imdb.com/name/nm2334596/
* Sensitive Internet User Disclaimer: All opinions are my own and are not meant to offend you or damage your precious beliefs.
 Rservello's gear list:Rservello's gear list
Panasonic Lumix DMC-LX100 Nikon D600 Rokinon 85mm F1.4 Nikon AF Nikkor 50mm f/1.8D Voigtlander 58mm F1.4 Nokton SL II +4 more
Lou Tent Veteran Member • Posts: 3,595
I posted this "review" back in '09 - might be of interest (has pics)….
http://www.dpreview.com/forums/post/32373569
JOHN OP Senior Member • Posts: 1,117
Thanks everyone,
Pity Nikon does not put a slot in bottom of camera or on battery grip like canon it would stop the need for a plate and make using a tripod a lot easier.
Regards Jonathan
