D800 fn button odd behavior
Started Apr 18, 2014 | Questions
Ketil Skogen New Member • Posts: 8
I have fiddled around with the menu settings on my D800 off and on. I have presently assigned spot metering to "press fn button only" and toggle image area to "fn button + control wheel". As far as I remember this used to work fine, but now pressing the fn button activates the image area selection without touching the wheel. Spot metering cannot be activated unless I turn all wheel options off in the menu. Does anyone recognize this?
Ketil
Nikon D800
Schroedingers_cat
Schroedingers_cat Veteran Member • Posts: 3,899
Re: D800 fn button odd behavior
Ketil
You have to select either Button only or Button + wheel only. Can't do both.
Some combinations behave differently. For instance,I have Spot Meter and Speed/Aperture Lock assigned to the Preview button.
http://www.nightstreets.com
"Sick cultures show a complex of symptoms such as you have named...but a dying culture invariable exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners is more significant than a riot."
This symptom is especially serious in that an individual displaying it never thinks of it as a sign of ill health but as proof of his/her strength. ...Friday, it is too late to save this culture--this worldwide culture... Therefore we must now prepare the monasteries for the coming Dark Age. Electronic records are too fragile..."
--Robert A. Heinlein in "Friday"
lickity split
lickity split Senior Member • Posts: 2,591
Ketil
Check to see if assigned spot metering to the preview button.
 lickity split's gear list:lickity split's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +10 more
Ketil Skogen OP New Member • Posts: 8
lickity split wrote:
Ketil
That is possible, but only if nothing is assigned to pw+wheel. Some combinations are not possible to select, OK, but others can be selected. One would expect that if they can be selected, they should also work.
