Is everyone's D4/ D4s vertical sub-command dial so shallow?
Started Apr 17, 2014 | Discussions
Wahrsager Regular Member • Posts: 152
It's my first pro-body and have only just realized that using the vertical
sub-command dial in the heat of the moment can prove difficult.  It's very shallow.  Is your body the same?  Accessory battery grip dial on D800 bodies is better in my opinion.
 Wahrsager's gear list:Wahrsager's gear list
Nikon D7000 Nikon D800 Nikon D800E Nikon D4S Nikon AF-S DX Nikkor 35mm f/1.8G +15 more
Nikon D4 Nikon D4S Nikon D800
stowei Forum Member • Posts: 79
Re: Is everyone's D4/ D4s vertical sub-command dial so shallow?
Only have D3 but have just had a look and it is the same so I guess it's likely to be the same for all models.  Have never even thought about it and it has always seemed 'perfect' to me.  I do have small hands.
Wahrsager OP Regular Member • Posts: 152
Thank you stowei.  I have large hands and fingers.  I need to develop a callous on my forefinger to grip it more effectively.
Donald Chin
Donald Chin Veteran Member • Posts: 5,602
Yes, my D4 & D4s both look the same.
