Stupid things you do with your camera.
Started Apr 16, 2014 | Discussions
Lumixdude Senior Member • Posts: 2,782
I just went out shooting today and realised I wasted 2 hours worth of shooting with my shots in ISO1600.
So what's your story?
 Lumixdude's gear list:Lumixdude's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 Apple iPhone 4 +2 more
Dareshooter Senior Member • Posts: 1,802
Re: Stupid things you do with your camera.
When I first made the transition from film to digital back in 2006,I took my 5 year old grandson out for walk and took some unforgettable pictures. When I say unforgettable I mean I'll never forget the fact that I'd forgotten that my memory card was still in the card reader back home.
billythek Veteran Member • Posts: 5,258
I have screwed up so many times that I can't remember them all. Not switching everything to manual when taking panoramas, for example. Or leaving the lens AF/M switch set to the M position while shooting AI Servo.
One big screwup I remember was on a trip I took shortly after buying a new camera. I normally shoot RAW, and had the camera set up that way, and usually shoot in aperture priority AV mode. For whatever reason, I decided to try out shooting in the full auto mode. Little did I realize that this changed me from shooting RAW to shooting JPEG. And what's worse, is when I switched back to AV mode, it left it set to JPEG. So all my shots of Bryce Canyon are JPEGs.
- Bill
 billythek's gear list:billythek's gear list
DxO One Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM
I've made that mistake, but fortunately, the shots I missed were just some test shots when trying out the camera. I found out pretty quickly since I was chimping and the shots seemed to disappear. I quickly found the menu item that disables shooting when a card is not in the camera.
- Bill
- Bill
I was using a Canon 300d at the time and I can't recall if it had that option. If I was to say the most stupid thing I've done it's shooting jpeg for the first couple of years,what a  daft mistake that was.
Photofunster
Photofunster Senior Member • Posts: 1,548
Stupid things I did with my Nikon FE 35mm film camera.
I was attending a funeral reception, after the main event, and had been taking pictures of the various family members when the camera battery died on my FE & consequently locked up with the shutter open. Instead of putting it in manual mode, I opened the back... Even in very dim light, not a wise move, if you want to save any of the photos near that section of film. What a waste, I could have just stayed home, but mourned in private?
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Apple iPad 3G +WiFi +2 more
Re: Stupid things I did with my Nikon FE 35mm film camera.
Chas
Your camera battery died at a funeral, I'm guessing there was no pun intended there ?
Mind you that reminds me of an occasion when a person won a box of multigrade paper in a camera club meeting. She then took the paper out of the box to see what it looked like !
newmikey Veteran Member • Posts: 4,351
Loooong list!
1. Forgetting to take the camera off manual focusing
2. Leaving on spot metering
3. Leaving tungsten WB during daytime (and not shooting raw at the same time)
4. No battery in camera (or low battery and no spare)
5. No SD card in camera
6. Leaving timer delay on (which disables shake reduction) while using relatively low shutter speed
7. Doing a bracketed exposure and moving the camera after the 3rd exposure when 5 exposures are set
8. Making efforts to look all-professional....with the lenscap still on
9. Choosing only one lens while travelling and ending up with the wrong lens
10. Leaving an ND filter on and wondering why shutter speeds are so low
11. Taking the whole Lowepro flipside 400 filled to capacity on a hike but finding out the camera is still on the kitchen table
12. You name it, I've done it!
http://mike.bing-photography.com
http://www.flickr.com/photos/newmikey/
Opensource: fresher, tastier and cheaper!
 newmikey's gear list:newmikey's gear list
Ricoh GR Pentax K-5 IIs Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Sigma 8-16mm F4.5-5.6 DC HSM +5 more
Photofunster
A favorite was
Being reminded by your model, "Don't forget to take the lens cap off!"
Blush much,,, Oh yeah, thanks for reminding me of that infrequent blunder...
Chas
Ron Poelman
Ron Poelman Veteran Member • Posts: 5,177
You can't turn JPEG off in an R1...
so a trick we RAW shooters used was to cut it down to 1MB size
to save expensive Sony card space and kill them later.
Pulled the old girl out the other day and decided RAW was no longer required,
so selected JPEG only.
A day's shooting later, a nice collection of tiny little photos, spewing !
 Ron Poelman's gear list:Ron Poelman's gear list
Sony Cyber-shot DSC-H2 Sony Cyber-shot DSC-R1 Sony SLT-A57 Sony Alpha 7R Sony DT 55-300mm F4.5-5.6 SAM +13 more
tarsus Forum Member • Posts: 94
Shooting an indoor event at 3 fps and exposure is all over the place. Frantically changing EV, ISO and shutter speed made it worse. Had it on bracketing!
Super16mman
Super16mman Regular Member • Posts: 287
Every time I open one of my film cameras to put film in it, and realize I never took the last roll out : P
hotdog321
hotdog321 Forum Pro • Posts: 15,748
Back in the film days, there wasn't a single pro on Earth that didn't shoot at least one assignment with no film in the camera. I did a similar boneheaded move when I shot an assignment with no card in the camera (yeah, I now use the control that says "do not fire if no card inserted.")
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
PK24X36NOW Senior Member • Posts: 1,570
Back in film days, my first camera was my father's 35mm half-frame film rangefinder camera. Observing its inner workings, I noticed it appeared to be "slipping" when I wound the film advance. Thinking this was a mechanical problem (i.e., that the film wasn't advancing properly), I applied a bit of super glue to the part that didn't seem to be moving when it should. The result? I got only 36 frames (every other shot on the roll) with my half frame camera, and couldn't rewind the film, either. A roll of pink pictures after I had to open the back to get the film out!
Removed the glue after that and the camera worked fine again.
I do mostly outdoor shooting. Once I did a shoot of an indoor flower show that my wife was writing a piece for. Hundreds of pictures. All shot in "Daylight" WB, with a nice green cast which then needed to be color corrected. Ack! (At least I shoot RAW + JPEG!)
Now I leave my cameras on "Auto" WB all the time.
megamatze Junior Member • Posts: 44
Recently I played around with remote flashing and left the camera internal flash on "commander" mode.
For half an hour I was wondering why the camera flash is so low
Aaron801 Senior Member • Posts: 3,102
Damn... I'd look at the images really close and you might find that depending on how well your camera does high ASA and what kinds of images they are... as well as your skills in post processing, that you can get some really nice, very usable images out of that.
I just did some shooting with my camera inadvertently set to a square format. I hate that my camera (a gh2) doesn't show the aspect ration as your shooting (or at least I haven't figured out how). I actually like the square format, I just like to crop in post processing when I'm going for that... Fortunately it wasn't with shots that I care too much about.
It really is too easy (at least for me) to inadvertently change things with those small buttons and very deep menus that these digital cameras all seem to have.
 Aaron801's gear list:Aaron801's gear list
Panasonic Lumix DMC-GH2 Olympus OM-D E-M10 Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
Lightpath48 Senior Member • Posts: 3,815
I'm stupider than you. I still shoot jpeg!
 Lightpath48's gear list:Lightpath48's gear list
Sony Cyber-shot DSC-RX10
Thanks for giving us permission to let our hair down.  I've developed some memory lapse problems after a stroke a few years back, so have to do many camera resets, as I regularly forget what manual settings I've made.
MinAZ
MinAZ Senior Member • Posts: 2,816
Two recent events come to mind.
With my brand my Panny FZ200 at an event, I noticed every shot I took had a greenish cast. Damn this viewfinder sucks, I thought (you can see the previews in the viewfinder in the FZ200 so no need to flip out the LCD). Later I found out I had the WB on tungsten.
The other was after a longish studio session, I spent the whole night doing photo editing (half asleep). When I woke up, I found out I processed everything using the JPG rather than the RAW files. I kept the JPGs however (just too much work to redo).
PhotoSenpai
PhotoSenpai Regular Member • Posts: 221
Thinking "Damn it's taking a couple seconds to get autofocus and the light seems fine - what's wrong here?"   ...then later realising I had camera set to 2 second delay.
