Nikon View NX 2 ver 2.9.2
Started Apr 15, 2014 | Discussions
DonGiles Junior Member • Posts: 44
 DonGiles's gear list:DonGiles's gear list
Nikon D1X Nikon D2X Nikon D3 Nikon Df Nikon D750 +13 more
DonGiles OP Junior Member • Posts: 44
Re: Nikon View NX 2 ver 2.9.2
Capture NX 2 also got an update to 2.4.7.
In the notes for both it says support for XP has been dropped so if you are still running that OS, don't update.
mtlr Regular Member • Posts: 294
Thanks, Don, downloaded and installed both CNX2 and VNX2 without a hitch.
Just hope these are not the last updates we'll see, I use CNX2 as my NEFs editor, will miss it when it's gone. In fact, I plan to continue using both CNX2 and VNX2 after their announced demise, probably in a dedicated photo editing notebook running under Win 8.1.1, as suggested by Thom Hogan in a recent article on the subject.
 mtlr's gear list:mtlr's gear list
Fujifilm X-T1
Manfred Bachmann Contributing Member • Posts: 978
DonGiles wrote:
This may be the last one.....
https://support.nikonusa.com/app/answers/detail/a_id/18916
Don
and who tells you viewNx will also gone? i have no idea, but nikon have never talked to stop the support of viewNx!
 Manfred Bachmann's gear list:Manfred Bachmann's gear list
Nikon Coolpix P900 Nikon D90 Sony a6000 Nikon D7200 Sony Alpha 7R II +13 more
Captain Hook
Captain Hook Senior Member • Posts: 1,792
Re: Nikon View NX 2 ver 2.9.2 on WinXP?
Did you install the latest versions of VNX2 and CNX2 on a Win XP system?
Because I found out (on one of my older laptops, which runs XP) that the installer refuses a Windows XP system... "ViewNX 2 does not run on your operating system"
bflood Senior Member • Posts: 1,069
Last?  Really?  New DSLRs from Nikon will not include any software that can read the NEF files?  Hell of a business plan.
 bflood's gear list:bflood's gear list
Nikon D70 Nikon D80 Nikon D7000 Nikon D610 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +8 more
olyflyer
olyflyer Forum Pro • Posts: 23,919
Don
Why would it be the last one unless Nikon stops making cameras?
olyflyer
Did you try with the 32-bit version?
Captain Hook
Yep.
The installer is testing for the local OS version and if OS is WinXP, it just quits...
Or did you find a workaround?
toomanycanons Forum Pro • Posts: 10,754
I see this:
  • Support for Windows XP has been eliminated.
  • Only Pre-installed versions supported.
  • Both 32 and 64-bit versions of Windows Vista & Windows 7 are supported, however, on a computer running a 64-bit OS, only View NX 2itself and the Picture Control Utility function as native 64-bit applications
How does that translate into this update being the last one?
Geomaticsman
Geomaticsman Senior Member • Posts: 1,833
Nikon has announced it will replace Capture NX2 with a new software package called Capture NX-D. Once NX-D has been formally released, support for CNX2 will be halted. The problem is that NX-D functionally lies between VIEW NX2 and Capture NX2 -- most importantly all NIK selection point and colour control point technology has been removed which, to me, makes this decision a huge mistake by Nikon.
NX-D will certainly convert NEF's but it's pretty well useless as a stand-alone converter+processor for doing anything more than simple conversion, global exposure & contrast adjust, crop and print.
Gary -- Some Nikon stuff -- and a preference for wildlife in natural light
www.pbase.com/garyirwin
 Geomaticsman's gear list:Geomaticsman's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR +3 more
You all are very correct, View NX2 may live forever. I incorrectly assume that Capture NX D would also replace View.. my bad. They just seem very similar.
Jurwees Regular Member • Posts: 435
As NX-D will be a free package as well, to me it seems very unlikely that both NX-D and ViewNX2 will continue to be supported.
Jur
 Jurwees's gear list:Jurwees's gear list
Nikon D800 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED +17 more
