I don't think I get TTL
Started Apr 11, 2014 | Discussions
MrChristopher
MrChristopher Senior Member • Posts: 1,288
I've been using an x100 and EFx20 for a while now, both in manual mode.  I've tried using the flash in TTL but I don't see any difference in the shots I take.  I believe TTL adjusts to the environment I don't see any changes in the shutter or aperture or ISO other differences.
I've used auto ISO, shutter and aperture priority, yet I fail to see any difference that TTL makes.  I'm not complaining, I'm pleading ignorance.
I'm posting in hopes some of you can enlighten me on what to expect as well as how to get the most out of TTL.  In some instances, at least in theory, I can see where it could be beneficial (like at an event).
Also, I picked up an XE1 the other day so I'm now using it as well.  Thanks
 MrChristopher's gear list:MrChristopher's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R +1 more
clockface Regular Member • Posts: 171
Re: I don't think I get TTL
I think that if you use autoiso then the camera will generally expose for the ambient light and add flash as a fill. Try turning autoiso off then flash will become the greater component of the light.
Increase speed or close down the aperture and the TTL flash will contribute more to the overall illumination.
ryan2007 Forum Pro • Posts: 12,001
Mikess1
Mikess1 Contributing Member • Posts: 612
say what now? if you are in fact using TTL then no matter where the flash is or what your camera settings are you will get what the flash thinks is perfect exposure you will get the same exposure for every shot you take unless you use the flash exposure composition to lighten or darken the shot hope this helps
 Mikess1's gear list:Mikess1's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR +1 more
MrChristopher
MrChristopher OP Senior Member • Posts: 1,288
are you saying the flash output changes as needed and the shutter and/or aperture/ISO do not change?
Sorry to sound dense, but if I wasn't dense on this subject I would not have posted
newtoy Regular Member • Posts: 391
Partially correct! If your original shutter speed before you turn on the flash is faster than the x-sync speed, then it should change those setting.
 newtoy's gear list:newtoy's gear list
Nikon D70 Nikon 1 V2 Fujifilm X-T1 Nikon D810 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +23 more
Mikess1
yes the flash output changes as needed and the shutter and iso should not change unless of course your in a auto mode
http://500px.com/mikess1
Mikess1
the faster the shutter speed or the higher the aperture the more power the flash will automatically use
MrChristopher
Thanks guys, this is helpful.  I think I get it now.  I have always used manual settings so I'll be experimenting with TTL more this weekend.  Most of my flash units cannot use TTL on the Fuji but my EFx20 sure will.
Cheers!
Mikess1
Cheers!
no problem glad to help! i have actually got a little lazy using TTL so for at least this month i am shooting only manual flash to better understand it
carlk Forum Pro • Posts: 15,940
Anyone knows how Fuji does TTL? Flash systems used to take real time TTL measurement but many (Canon for example) now do a pre-flash and use the data to calculate exposure.
On the other hand a lot of (experienced) photographers actually prefer manual flash to get better and more consistent results. Jut do a few test shots and you're all set.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
BurpeesAreHard Contributing Member • Posts: 521
You shouldn't think of it this way. You're right that closing the aperture cuts down on the amount of light from the flash, but the flash is much faster than the shutter. MrChristopher is using a camera with a leaf shutter, which can sync at much faster speeds than your X-T1, and any shutter speed within the sync range is fair game.
Older flashes that have an 'auto' mode, using a sensor on the front of the flash itself to cut off the light, have adjustments for ISO and aperture, so the flash can calculate approximately how much light the camera is getting, but no input for shutter speed. It isn't needed. Modern 'flash calculator' apps are the same way.
(not counting whatever FP high speed sync flashes might do, as part of a sequence, since we aren't talking about those)
SaltLakeGuy
SaltLakeGuy Forum Pro • Posts: 11,451
You got it clockface
That is essentially how the flash system works. Also a reason why if one buys a non Fuji non TTL flash it can be just as easy to get the proper exposure desired.
Fuji X-T1 Camera, Fuji 18-55 f2.8-f4 Lens, Fuji 55-200 f4-f5.6 Lens, Fuji 23mm f1.4 Lens, Fuji 56mm f1.2R Lens, waiting for the Fuji mount Nissin i40 Flash, Picturecode PhotoNinja, Adobe Lightroom 5.4
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Zeiss Batis 85mm F1.8 +4 more
MrChristopher
Good point about the x100.  In this case I'm using the XE1.  And yeah the shutter leaf and synch to 1/2000 on the x100 is what makes that one so special, but i'm trying to figure this TTL business out on my XE1.
I'm very comfortable using manual camera/flash settings (with either camera) but I'm trying to determine if I'm missing anything by not using TTL.  I plan to use it quite a bit this weekend.
Or you can also open up the aperture and slow down the shutter, as permitted, along with lesser flash power for the so called dragging the shutter technique.  It's popular among wedding and event photographers when they want to incorporate as much ambient and use as little flash as possible to avoid the shadow on the face and shot in the cave flash look.
virginiajwolf Junior Member • Posts: 44
Yes, TTL bypasses the manual approach of shutter for ambient/background and aperture for the subject, since the flash exposure automatically compensates. A good discussion of this is here:
http://neilvn.com/tangents/manual-flash-ttl-flash/
His B&H video on flash is terrific:
http://www.youtube.com/watch?v=mivhtzg7P4s
It's mostly about bounce techniques for portraits/weddings, but he goes into detail on manual vs. TTL about 50min in.
I'm just learning the ef-x20 as well (on an x100s). I love its portability, but for TTL the limited flash exposure compensation and bulky TTL cable bother me (I don't like it on-camera in the hot shoe, with its inability to tilt or swivel). I'm mostly using it on manual. It's fun as an optical slave, using the on-camera flash to trigger it. Here, though, the camera flash is often too bright: the commander mode fires at full power only, it seems, while the regular mode can be dialed down only by -2/3. I may play with filters/diffusers to cut this down and make the x20 more dominant.
For bounce with the small flash, higher ISO helps increase the effective range.
