Does your 10-24mm rattle
Started Apr 10, 2014 | Discussions
Herbieo
Herbieo Regular Member • Posts: 177
I just received my 10-24mm lens and on unboxing I noticed that I can hear the lens rattle a bit. Is this abnormal?
Thanks in advance.
 Herbieo's gear list:Herbieo's gear list
Fujifilm X100S Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R +2 more
Ollie 2
Ollie 2 Senior Member • Posts: 1,525
Re: Does your 10-24mm rattle
Thanks in advance.
They all rattle.
Mine had to go back. It wasn't solid in the body housing and periodically lost electronic communication.
 Ollie 2's gear list:Ollie 2's gear list
Sigma DP1 Merrill Olympus PEN E-P2 Fujifilm X-Pro1 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +16 more
Herbieo
Herbieo OP Regular Member • Posts: 177
Thanks in advance.
They all rattle.
Thanks good to know.
Bmat
Bmat Regular Member • Posts: 312
Ollie 2 wrote:
They all rattle.
Are you saying a rattle is indicative of the problem you had, and all of them have it.  Or that they all have the rattle--perhaps due to OIS or something else--but also that yours had a problem unrelated to the rattle and had to go back?
Or something else?
Brian. Too much stuff; not enough stuff.
jennajenna
jennajenna Senior Member • Posts: 1,298
It should not rattle. But its a new lens so maybe production issues.
Evan Effa
Evan Effa Veteran Member • Posts: 3,340
Mine does a bit.
I'm guessing that it's the OIS mechanism that has some sort of play designed into it.
Mine works very well so not concerned.
-evan
 Evan Effa's gear list:Evan Effa's gear list
Fujifilm FinePix S2 Pro Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Canon EF 16-35mm f/4L IS USM
mudakas
mudakas Regular Member • Posts: 111
It rattles until you turn camera on so it mas be ok...
jack Hoggard
jack Hoggard Contributing Member • Posts: 825
I agree.  Only when the camera is off.  When the camera is turned on, it works spectacularly.
jaxupra
 jack Hoggard's gear list:jack Hoggard's gear list
Olympus Stylus 1 Sony Xperia Z Ultra Google Nexus 7 +1 more
Chad Hardy
Chad Hardy Senior Member • Posts: 1,191
jaxupra
Agree no issues with mine.  Fantastic lens!
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony Cyber-shot DSC-RX100 III Olympus E-M1 +16 more
kevingm
kevingm Regular Member • Posts: 108
Nikon lenses with vibration reduction used to come with instructions to turn the VR off before turning the camera off to avoid the lens chattering. I don't know if they still warn buyers about that. My 10-14 doesn't rattle, but I'm in the habit of turning the OIS off before I turn the camera off.
KevinKessler
KevinKessler New Member • Posts: 21
This thread makes me feel a little better.  I bought a 55-200mm on the sale, but I still do not have the X-T1 to test it on.  It also rattles too, so I hope that is normal as well.
 KevinKessler's gear list:KevinKessler's gear list
Panasonic Lumix DMC-TS3 Canon EOS 5D Mark II Fujifilm X-T1 Canon EF 50mm f/1.4 USM Canon EF 16-35mm f/2.8L II USM +5 more
