Carl Zeiss on X-E1
Started Apr 10, 2014 | Questions
no focus New Member • Posts: 5
Carl Zeiss on X-E1
Hi there,
I've sold my 5d and now looking for something more compact. Thinking about some fuji's.
I red that there are adapters for the X-E1. Is it also possible to mount my older contax/zeiss lenses? And what would work or not. I guess the 28mm will become like a 45?!
Before I buy a body I would like to know if I can use my lenses..
Cheers, Martin (Netherlands)
Canon EOS 5D Fujifilm X-E1
Rod McD Veteran Member • Posts: 3,916
Re: Carl Zeiss on X-E1
You can buy adapters for a number of mounts that you might find on Zeiss glass that will allow you to fit them to Fuji X mount.  I'm not sure which Zeiss mounts you have.  You can buy them for Contax Yashica and Leica M to Fuji X.  You can also buy them for Nikon F & G and Canon EF to Fuji X mount in case you are using Zeiss ZF or ZE series.
I suggest you have a look through the websites of companies like Novoflex, Metabones, Kipon, Fotodiox, Pixco and others for the details.  If you want any electronic connections for Canon versions, suggest you look at the Metabones or JR smart adapters.
Be aware that you can pay from $10 to $200 each for plain adapters and more for those with electronic couplings, speed boosters, tilt shift and other additional features.  You'll find many threads here from people who've found the cheap ones excellent, and others who've had a lot of trouble and switched to more expensive brands.  It seems that the experience varies......
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Fujifilm X-T1 Voigtlander 90mm F3.5 APO-Lanthar SL II Voigtlander 15mm F4.5 Super Wide Heliar Fujifilm XF 60mm F2.4 R Macro +8 more
fuji P
fuji P Regular Member • Posts: 231
http://www.fujifilm.com/products/digital_cameras/pdf/lenses_accessories_catalogue_01.pdf
Have a look at page 18 for m-mount adaptor info.
I remember reading an m-mount breakdown of what lenses work with Fujis somewhere on the net but cannot find it at the moment. Maybe someone can help you with this.
 fuji P's gear list:fuji P's gear list
Fujifilm X-E1
fuji P
Fujifilm X-E1
Jasko014
Jasko014 Contributing Member • Posts: 582
Nofocus hi)))
you an mount your Zeiss lens to Fuji X, but you need the Canon to FujiX adapter. There are many companies making them, here is one of them, you can find corresponding adapter here:
http://www.fotodioxpro.com/lens-mount-adapters/mirrorless-dslr/fujifilm-x-mount-system-lens-adapters.html
Previous poster did mention LeicaM to FujiX adapter, but that one can be only used for the ZEISS, Leica, Voigtlander and other lenses with Leica M Mount.
Jaka
 Jasko014's gear list:Jasko014's gear list
Sony RX1R Nikon D3 Nikon 1 V1 Nikon Df Fujifilm X-T1 +17 more
Treve1 Regular Member • Posts: 309
I would really advise you against doing this.
I tried a Contax G 28mm f/2.8 Biogon lens on an X-E1, using a quality Metabones adapter.
I found the corners to be unacceptably soft/smeared until stopped down to f/8-11.
I can provide photos if you wish.
 Treve1's gear list:Treve1's gear list
Leica X1 Ricoh GR Fujifilm X100T
1drey
1drey Senior Member • Posts: 1,408
Why not Sony A7(r/s)? Very compact, plenty of adapters for various mounts, same angle for your existing lenses.
Of course if you would not mind to move to X system entirely, I could recommend XE1 with a heart beat.
 1drey's gear list:1drey's gear list
Fujifilm X10 Fujifilm X100S Canon EOS 5D Mark II Fujifilm X-E1 Sony Alpha 7R +7 more
no focus OP New Member • Posts: 5
Jasko014 wrote:
Nofocus hi)))
Jaka
Huh, why would I need anything from Canon?
I have the C/Y lenses.. planar 1.5 50 and distagon 2.8 28.
I have an adapter with dandelionchip from Leitax for the 5d but I haven't used it and now I've sold the 5d anyway.
That chip would be needed for recognising apertures and ....? I'm very bad with digtal stuff.
But does that mean that you alwaus need a chip? Or how does it work with a simple adapter.
And...what will my lenses become equivalent on the sensorsize 28-45mm?? 50-75mm?
Tx sofar
deednets Veteran Member • Posts: 4,760
no focus wrote:
Hi there,
28 will become a 42 ... Canon uses 1.6 extension on their APS-C whereas Fuji like old Nikon use 1.5 ...
You can use almost all lenses with some sort of mount that is reasoably common, excluding some enlanger formats and mid-format lenses like Plaubel Rodenstock and the likes, but Hasselblad, Nikon, M42, Canon, Minolta, Leica etc
No worries ...
Good luck!
Deed
