Thousands (BILLIONS! j/k) of hot pixels at 1/200 and ISO 6400 on D800
Started Apr 9, 2014 | Discussions
MickLaF Junior Member • Posts: 41
Hello,
I know this has been discussed many times in the past, but it usually refers to long exposure times (in which I expect some hot pixels). On my Pentax K-5 at long exposure I had probably 30 hot pixels at 1600 iso, which got mapped out using the menu option. I also know having some hot pixels are a fact of sensors.
However, I just received my D800 yesterday and was taking some pictures. I was NOT intentionally looking for hot pixels at the time and just testing out the Auto ISO mode. So I set the shutter speed to 1/200 and the ISO was automatically set to 6400. I took a picture of my living room to see the low light capabilities I've read great things about. When I loaded up the picture, I thought the ISO noise wasn't too bad, I zoomed in to see how it would be on a crop and noticed hundreds and hundreds of red and blue hot pixels. In a 1:1 zoom, there were anywhere from 30-100 in each portion that I zoomed in on (rough estimate as I gave up counting after a bit).
I'm at work now, so I don't have the picture. But I'm sure you get the idea. Should this be happening that badly at 1/200th of second? They are there at 3200 as well. I just want to make sure because this is one of the bigger purchases I have made and I don't want to kick myself once I'm out of the return window.
I did try taking a couple long exposure high iso pictures promptly followed by two Sensor Cleans in quick success, and it did not seem to help. I know RAW converters will pluck the hot pixels out, but I would rather exchange if this goes beyond the normal expectation of hot pixels.
I'm trying not to be totally naive about hot pixels, but I want to feel confident that all that money went to a good copy of the camera.
 MickLaF's gear list:MickLaF's gear list
Pentax K-3 Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +10 more
Nikon D800 Pentax K-5
MickLaF OP Junior Member • Posts: 41
Re: Thousands (BILLIONS! j/k) of hot pixels at 1/200 and ISO 6400 on D800
Can anyone confirm if their D800 performs in a similar manner?
Janoch
Janoch Senior Member • Posts: 2,493
"Hot pixels" are something else. These are pixels always on (or off) regardless of settings...
You're describing high ISO noise. Try enabling NR in camera, and if you really want to use the highest ISO settings, perhaps try something like Photo Ninja for effective noise reduction.
I'm not sure Capture NX2 can cope, as I never touch these high settings. And frankly, above ISO 400 to 800 you're beginning to degrade the otherwise fairly fine sensor...
 Janoch's gear list:Janoch's gear list
Nikon D800 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm f/4G ED VR +2 more
If it's always on, that would be a stuck pixel right? I might be off, though.
The spots I'm talking about are at full brightness, red blue or green, and don't look like typical high iso noise. There is plenty of iso noise too, but it's MUCH more subtle than the hot pixels. I've seen hot pixels on other cameras, but not nearly as many as what in seeing here. I mean, there are thousands of them.
TOF guy MOD Forum Pro • Posts: 12,823
Something is amiss. Could you post an image (or better a RAW image)?
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +5 more
pluton Senior Member • Posts: 2,794
I have had a D800 and D800E for over a year and have not seen such things.
What raw converter are you using? I have seen bad stuff that might be mistaken for hot pixels in iPhoto.
-KB-
 pluton's gear list:pluton's gear list
Nikon D800 Nikon D800E Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R
Sure. I'll post an image after work. They pixels are small so it takes a bit of cropping/zooming, but they are there. With how many there are, this has to be the norm, though.
-KB-
ACR will pull them out, but I just want to verify that having so many is expected. If it's not, I might as well exchange while I still can. I'll post an image once I get an opportunity.
user_name Veteran Member • Posts: 3,134
Did you under expose?
You will probably have less noise with a higher ISO and a correct exposure (ETTR) than a lower ISO and underexposed shots if you are needing 1/200 shutter speed.  Try it and see.
You also need to have NR enabled.
 user_name's gear list:user_name's gear list
Leica M8 Nikon D700 Nikon D800 Leica M Typ 240 +1 more
Janoch
Guys, ISO 6400 and 100% pixel peeping... that's enough to make full grown men break down in tears...
Pictured was exposed well, if not a little over. If I shot it in the middle or underexposed and boosted it in post, it still wouldn't have the pixels on at full strength or red/green/blue. Also, of note, I didn't do any PP to the pictures, myself, the RAW files were viewed directly in Windows Photo Viewer.
For testing (the lens cap shots), I left NR off. ACR will clean the pixels up unless I'm shooting a long exposure star shot. I'm just curious if this is the norm for this camera and its sensor.
CFynn Veteran Member • Posts: 5,224
How much are you zooming in?
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 105mm f/2D DC Nikon AF Nikkor 180mm f/2.8D ED-IF +14 more
It was around a 1:1--enough to see the pixels. Originally I was zooming in to see how well the noise performed compared to my K-5, I wasn't intentionally looking for them. But now knowing that there are so many excited pixels, I just want to see if other's D800s perform similar. I'm suspecting unless I got the crap luck of the century, the sensor having this many hot pixels means that it's pretty typical.
Haha. I expect PLENTY of noise under those conditions (better looking than my K-5, though). However, I didn't expect so many hot pixels peppers within the noise. It's there with 3200 as well.
I was fully anticipating getting hazed/blasted for this, but my K-5 had like 30 total before pixel mapping. It also cost much less than the D800 and my money anxiety didn't kick in.
LMCasey Contributing Member • Posts: 708
It's not normal to have huge numbers of hot/stuck pixels even at 6400. I don't see this on my D800, and I've taken hundreds of photos at 6400.
 LMCasey's gear list:LMCasey's gear list
Canon EOS 5D Canon EOS 350D Canon EOS 400D Nikon D800 Canon EF 35mm f/1.4L USM +16 more
By the way, my posts are taking a while to be displayed because I'm a new member. Each one has to wait to be approved by a moderator to make sure I'm not a robot. I was hoping after the first or second time, the restriction would be lifted.
Have you looked at the photos through Windows Photo Viewer and zooming in a good amount? Most raw converters will automatically pull them out without you knowing.
digital ed
digital ed Veteran Member • Posts: 3,463
Stuck pixels will be automatically remapped by the camera
Manually run sensor clean twice in immediate succession.
Edited: there is a difference between hot and stuck pixels.
"There is a little of not done yet in all of us."
John Madden, football coach
 digital ed's gear list:digital ed's gear list
Olympus E-1 Olympus E-3 Nikon 1 V2 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +14 more
Re: Hot pixels will be automatically remapped by the camera
Thank you for the suggestion. I've tried that a few times and it's the same. I even tried it immediately (by mapping the top menu item to the function button) after a couple long exposures.
Janoch
Re: Stuck pixels will be automatically remapped by the camera
Neither dust nor pixel errors... onlu pure noise...
D800 + ISO6400 + 100% view (or 1:1 as OP said in first post) = lots of noise, not pretty
But let's see the NEF, please.
I'll put a beer on noise!
