No distortion correction with kit lens
Started Apr 7, 2014 | Discussions
blue_cheese
blue_cheese Senior Member • Posts: 1,722
Is it just me or does the D7100 not have distortion profile for the 18-140 kit lens that comes in the same box? Jpegs are vignetted obviously at the wide end, and the distortion correction is unavailable with that lens only.
I went on the Nikon site, but the latest firmware does not appear to remedy this.
If someone has that setting working, please enlighten me.
"We are fast approaching the stage of the ultimate inversion: the stage where the government is free to do anything it pleases, while the citizens may act only by permission; which is the stage of the darkest periods of human history, the stage of rule by brute force."
- Ayn Rand
Nikon D7100
Mako2011
Mako2011 MOD Forum Pro • Posts: 19,953
pincushion distortion
To be on same page...are you saying you can not set the "Auto Distortion Control" to on or off in the shooting menu (it's greyed out?)
Also note...Auto distortion control only corrects pincushion distortion and not vignetting.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
blue_cheese
blue_cheese OP Senior Member • Posts: 1,722
Re: pincushion distortion
Correct, with that lens attached I do not have the ability the change the setting. No problem with the 70-300 or the 60mm macro.
Are you sure distortion is just for pincushion? I thought it also covers vignetting and CA, at least i thought it did (although I have hardly made a through examination), i keep RAWs, but in the odd chance I use the JPEG I leave this setting on. Would be nice to know why that particular lens does not have the option though.
- Ayn Rand
OpticsEngineer Senior Member • Posts: 4,480
Re: No distortion correction with kit lens
I also have the D7100 with 18-140 lens. You are correct. Distortion correction is not available in camera.  But CA and vignetting correction is available.   Several reviews have mentioned this.  The lack of distortion correction shows up in my test shots too.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Sony Alpha NEX-7 +21 more
Patco Forum Pro • Posts: 12,116
18-140mm not yet included...
The 18-140mm does not yet appear to be included in the latest distortion control data update, which is Firmware L 1.009:
http://www.nikonimglib.com/dcdata/index.html#os-windows
Patco
A photograph is more than a bunch of pixels
Mako2011
JPEG
That means the lens isint supported yet. Will eventually with a firmware update. Was included in the last update.
The auto distortion Data for a lens only corrects barrel and pincushion distortion, AFAI. CA and Vignette control are low level and automatic in JPEG only via the Expeed engine. You don't have control of it like you do with the D600/610. You can also apply CA and Vignette control with some Raw convertors.
swimswithtrout Senior Member • Posts: 1,657
You need in camera distortion correction for a JPEG from a kit lens ?
Am I the only one that see's the irony in this question about a "non-pro" camera ?
blue_cheese
Re: You need in camera distortion correction for a JPEG from a kit lens ?
I don't get it... there is no irony... there is a menu option that isn't available with just one lens. I got my answer, i wanted to make sure it wasn't something I was missing.
- Ayn Rand
_sem_ Veteran Member • Posts: 4,731
I wouldn't lose sleep over this. In-camera correction of these isn't always problem-free. I used to think software correction would be mandatory to fix the horrible flaws of such lenses. In fact, distortion and vignetting need to be corrected only when they bother you, and even then you may want to alter the degree of correction. And Nikon's correction isn't best out there; DxO, PTLens and Adobe do a bit better.
