7D Auto ISO vs. fixed ISO?
Started Apr 6, 2014 | Questions
RGF Forum Member • Posts: 55
Using auto ISO today (over cast and low light) all of my images out of focus.  looking at the info it showed the ISO at 3200.  I am using the 7D with a 100-400 L lens.  Really got no keepers.  I am having difficulty comprehending the ISO setting as some say they never use Auto - I guess now I see why?  Any suggestions on camera settings would be helpful.  I used M, AV, and TV modes.
Thanks,
RGF
Canon EOS 7D
RGF OP Forum Member • Posts: 55
Re: 7D Auto ISO vs. fixed ISO?
Also - this was for BIF photos and waterfowl resting on the water.
RGF
Don Richardson Senior Member • Posts: 1,454
Thanks,
RGF
I have a 7D and 150-600 mm and Tamron 70-300 and shoot Shutter speeds between 2500-500 depending on light and use Auto ISO all the time. You'd be suprised at the low ISO I get at 2000 shutter speed Check out my zenfolio for thaen with 150-600 of Taken with 70-300. They should be on top row as all in both have been taken in last month and I'm pretty sure I used Auto ISO on all of them,
 Don Richardson's gear list:Don Richardson's gear list
Canon EOS 7D Tamron SP 150-600mm F/5-6.3 Di VC USD Epson Artisan 835 +1 more
Lanidrac Veteran Member • Posts: 7,544
What BIF photos?
RGF
Are we supposed to use our imagination of the photos that you took?
If you had a clue about the 7D, which I doubt that you even used or should not be using, you'd know that you can set maximum Auto ISO ranges with the camera.
Lanidrac.
Don Richardson wrote:
Thanks,
RGF
Tell me that ain't so. You use auto-iso ALL the time??? Wow.
Re: What BIF photos?
Thanks for the "constructive criticism" - geez - do you really need a sample - when I say oof -  I meant it.  Yes I know the 7d have had it for a few years - unfortunately don't know everything about it - was merely seeking a little help!
RGF
Thanks Don
RGF
Constructive
RGF
Try being specific then. We don't read minds. Maybe learn the gear you have or read the manual before posting too would be good??
RGF
birdbrain
birdbrain Veteran Member • Posts: 3,475
Thanks,
RGF
Auto ISO is brilliant, when used in the right situations
I shoot lots of planes at air-shows, I am tracking these across the sky doing my best to keep them in the frame
I have to rely on the camera to make the exposure for me, I shoot TV with a shutter speed of 1/250 and auto ISO and anything from +1 to +2 EC as I am shooting against the sky. I use Auto ISO and it works excellently.
If you want to see results of using Auto ISO go to my Flickr site and look at the planes in the sky they were all Auto ISO 7D with 100-400 mostly.
Here's one:
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/sets/
 birdbrain's gear list:birdbrain's gear list
Sony Cyber-shot DSC-RX10 II Canon EOS 5D Mark III Canon EOS 6D Canon EOS 7D Mark II Canon EF 16-35mm f/2.8L II USM +13 more
PK62
PK62 Contributing Member • Posts: 950
I've had the 7D for a couple of years and almost always use Auto ISO for birds.  I just adjust the exposure.  I've tried using different ISO settings and just seem to have better luck with Auto.   I do have the maximum set though.
Patti
 PK62's gear list:PK62's gear list
Canon EOS 6D Canon EOS 7D Mark II Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Tamron SP 150-600mm F/5-6.3 Di VC USD +6 more
phill104 Senior Member • Posts: 2,704
Lanidrac wrote:
RGF
Lanidrac.
Is there anything wrong with politely asking rather than being obtuse?
C&C always welcomed.
Some of my piccies - http://www.flickr.com/photos/distinctly_average
A windsurfing website I built - http://www.windsurf.me.uk
Thanks,
RGF
I don't use it 100% of the time but I set Max. ISO at 1600 and probably use it 80% of the time and wouldn't you know I shoot birds 80% of the time also.. You should try it. On bright days I'll get 320-400 ISO at 2000 shutter speed with very little noise. I use AV and set ISO the other 20% but as light changes I forget to change ISO.
Re: Constructive
Lanidrac wrote:
RGF
Seems to me you're one of those that just likes to be rude. Try smiling.
Abu Mahendra Senior Member • Posts: 4,011
AutoISO probably had nothing to do with it.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 70-200mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 40mm f/2.8 STM +4 more
Kaso Senior Member • Posts: 2,636
Re: Constructive
Select the first option under that obnoxious post:
And block out the noise from now on.
MarshallG
MarshallG Veteran Member • Posts: 3,384
RGF
Lanidrac.
No need for the rude comment. If you don't want to help (nicely!), then don't click Reply.
 MarshallG's gear list:MarshallG's gear list
Canon EOS 7D Mark II Canon EF 50mm f/1.4 USM Canon EF-S 10-22mm f/3.5-4.5 USM Canon Extender EF 1.4x II Canon EF 70-200mm f/2.8L IS II USM +2 more
Thanks everyone for your suggestions and help - really appreciate it.  I did set the max to ISO 1600 and will see how that goes.
RGF
jhendrix Senior Member • Posts: 2,086
RGF
Could you share what other settings are being used? A, P, TV, single point AF, etc.
Rather than setting the max ISO, you should set the minimum shutter speed under AutoISO. Indeed setting the max ISO to 1600 might be the reason for the blurry pics for the camera will then select longer shutter speeds in order to expose correctly. You need to understand that AutoISO is an ISO-minimizing function. It will try to set the lowest shutter speed required for i. proper exposure and ii. satisfy the 1/FL criterion.
