A FastStone Image Viewer replacement for a Mac
Started Apr 5, 2014 | Discussions
FrankS009
FrankS009 Veteran Member • Posts: 3,894
XP is no longer supported after Tuesday at 6pm here, and I am shifting all my photography processing to my IMac. Presently I use FastStone Image Viewer For Windows which is a programme that I enjoy and use often.
What might be the Mac equivalent that deals well with GX7 files?
thanks
F.
"We shoot the things that move us in ways that will move others." David duChemin
Panasonic Lumix DMC-GX7
rsmithgi Senior Member • Posts: 1,092
Re: A FastStone Image Viewer replacement for a Mac
thanks
F.
iphoto, picasa, xnview are a few. Xnview is probably most similar.
take a look at alternativeto.net. Enter the name of an application that you want n alternative to and browse around.
 rsmithgi's gear list:rsmithgi's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M10 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 +6 more
JeanPierre Martel Senior Member • Posts: 2,842
Adobe Lightroom and DxO Optics Pro fully support the Panasonic GX7.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
assaft
assaft Senior Member • Posts: 1,267
What do you use FastStone for?
 assaft's gear list:assaft's gear list
Olympus PEN E-PL2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +5 more
FrankS009
FrankS009 OP Veteran Member • Posts: 3,894
I have used FastStone to do a number of things on the Windows side. The first is as a kind of Windows Explorer for Photographs to review my catalogues. I can rely on SoftStone to view RAW files, and it is easy to turn them into JPGs if I might want to by simply cropping a little or performing some other minor transformation using  its tools. It also has links to other more sophisticated editing programmes for individual photographs, and can open those programmes with that particular image in them. It shows the data for each image as well. No doubt there are other functions it3 performs. FastStone viewer is a kind of photographic Swiss army knife.
F.
FrankS009
Thanks. I will do some exploring.
XNView is a Windows only programme, and won't work on a Mac which is what I need.
F.
ttan98 Senior Member • Posts: 1,837
thanks
F.
FastStone version 5.1 is excellent image viewer and processor more importantly it's free, it works with Win 8 as well.
FrankS009
Thank you. So does Capture One. FastStone is not a sophisticated editing programme, but a way of sorting and manipulating images in an organizational way. It does not create catalogues, but lets you work with the catalogues you may have created yourself. My response to assaft gives more examples
F.
FrankS009
I agree, but it won't work on a Mac.
F.
Bob657 Senior Member • Posts: 1,992
You might look at Photo Mechanic for Mac
Bob G
 Bob657's gear list:Bob657's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus 12-40mm F2.8 +2 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,724
there is XnViewMP for Mac and that is what I use...
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
natal New Member • Posts: 24
XNViewMP runs on a Mac
jeffharris
jeffharris Veteran Member • Posts: 6,431
I’ve never heard of FastStone, since I've used Macs since 1985.
I use PhaseOne's Media Pro to make quick catalogues for review. It was originally iView Media Pro then languished for a few years when Microsoft acquired it and called it Expression Media. Thankfully they sold it to PhaseOne and it's useful again, that is, actually supported and getting updates.
Then I import to Lightroom 5.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +27 more
thanks
F.
Another option is Finder. It can display images and handles the raw files from my GX1 and G3.
Paul_R_H Contributing Member • Posts: 853
If you download the latest DigitalCamera Raw Update from Apple, your Mac will read the RAW files natively, and turn them to jpegs with cropping and basic exposure and colour adjustments, using the built-in Preview application. Use the free iPhoto for cataloguing, or Aperture for cataloguing and practically everything else except distortion and perspective adjustments. But Aperture isn't cheap so maybe try DxO which does have those adjustments and is more modern.
Paul
thanks
F.
FrankS009
Appreciate all your suggestions.  Will work my way through them.
F.
FrankS009
This may be close to what I am looking for. Have a lot of working with it to do. Might look for Youtube instruction. Thanks
F
FrankS009
1985? Sounds like how long  I have been using my academic word processing programme - no not 'Word. The only problem is that is a Windows programme.
Downloaded MediaPro for a 60 day trial period. I have also downloaded Capture One 7 for the same time period. Would be interested if you tried Capture One and why you use Lightroom instead. I still have Lightroom 3 on the system, but as yet have not downloaded the Adobe converter for my GX7 files. In any case, there must be ways to catalogue and ways not to catalogue, with Media Pro and need to look at some tutorials.
Thanks for your suggestion.
F.
honeyiscool
honeyiscool Senior Member • Posts: 1,375
Paul
thanks
F.
DxO is $169, Aperture is $79. If you want distortion correction, DxO ViewPoint can be used inside Aperture.
Anyway, I suggest starting with iPhoto and if you like that basic setup, upgrade to Aperture.
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GX85 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 12-40mm F2.8 +2 more
Lumixdude Senior Member • Posts: 2,782
Set up your photo library in iPhoto and send all your photos to aperture for editing, it works just like Adobe Bridge, except it's more powerful, then send your photos from there to Aperture. Done... There better programs and the sum total is $79 for aperture, iPhoto is free. They're both extremely simple to use, but Aperture is as powerful as Lightroom.
Follow me online at http://blog.roumelio.com
 Lumixdude's gear list:Lumixdude's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 Apple iPhone 4 +2 more
