Does Fujifilm pace their lens releases to to make us buy them all?
Started Apr 5, 2014 | Discussions
davidjlee Regular Member • Posts: 150
I really like the Fujifilm lens lineup. But honestly there are lenses that I wouldn't have purchased if lenses released later had been available. Are they timing the releases so people buy them all?
Is it just me?
The 60mm f/2.4 before the 56mm f/1.2.
The 14 f/2.8 before the 10-24mm f/4.
The 16-50mm f/3.5-f/5.6 before the 16-55mm f/2.8
 davidjlee's gear list:davidjlee's gear list
Sony RX100 Sony RX1 Fujifilm X-Pro1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 +5 more
gerard boulanger Senior Member • Posts: 2,262
Yes n/t
No text.
 gerard boulanger's gear list:gerard boulanger's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8
dannybgoode Contributing Member • Posts: 829
Re: Does Fujifilm pace their lens releases to to make us buy them all?
They are all different lenses with different functions and with the x mount being a new system they have to have a roadmap (and from memory you would have seen the 10-24 would be available when you bought the 14) as they are not going to have the capability to launch with the full set all at once.
The 60 is a macro the 56 is not so if the 56 came first some may then have wished they had waited for the 60 but those are the only 2 lenses in the line up that cross in terms of functionality.
The 14 is a prime and all systems have 1 or 2 wide primes and a wide zoom. You prefer a wide zoom but a lot of people prefer a wide prime so they have to cater for both.
The 16-50 is a 'kit' variable aperture lens, cheapish and light, the 16-55 is going to be considerably mire expensive and larger. Again there is nothing unusual about a system having lenses of similar FL's but different apertures, build and pricing.
Which ever order they release the lenses in some people may prefer the newly released one but as stated above there is very little true crossover in the range and you can always consult the roadmap.
Shoot lots...
http://www.dannybowerphotography.co.uk
 dannybgoode's gear list:dannybgoode's gear list
Ricoh GR Digital IV Sigma DP2 Merrill Fujifilm X-Pro1 Canon EOS 5D Mark III Canon EF 50mm f/1.8 II +7 more
TravelLight Regular Member • Posts: 282
Re: Yes n/t
Does yes mean "yes, it's just you" or "yes, it's Fuji's lens strategy"?
To OP's question -- I had that same conspiracy theory too, but it's prob. not the case. Fuji built this line from scratch so there are "early" lenses, and then "later" lenses. They have to start somewhere. Since all of them are good, "late" adopters like us will have a hard time choosing.
I wasn't too happy that the WR lenses are not available at the same time X-T1 was pushed to the market (like the perfect match of 12-40mm and E-M1), but I think it's just timing (too naive?). Honestly, looking at the specs I am not sure if I'd have preferred the larger/heavier WR lenses over the more compact 18-55 even if they were made available at the same time.
Talking about the overabundance of choices, I think the M43 system is way more confusing (when I was thinking about buying a macro, I vacillated between the Oly 60mm and Pana 45mm for the longest time and still couldn't pull the trigger).
Now I am done looking for the next best thing. I enjoy what I have and try to focus more on images than lenses.
gerard boulanger wrote:
DVT80111 Senior Member • Posts: 2,117
Re: Yes n/t
me too. Stop buying more Fuji's stuff, and just trying to be in focus.
 DVT80111's gear list:DVT80111's gear list
Sony RX100 Fujifilm X-E1 Canon EOS 6D Canon EOS 70D Sony Alpha 7R II
Bill Robb Senior Member • Posts: 3,332
Is it just me?
Yes. Fuji also tracks where you live, and if you don't buy one of everything, they will send Yakuzas after you and your family. You will know because of the subtle signs they leave. The water being mysteriously drained out of your goldfish bowl, wife going missing, house burning down with only your camera bag undamaged, that sort of thing.
Oh wait, that might be Olympus.
Al Valentino Senior Member • Posts: 4,582
The first lens were small and light, 18, 35, 60, 18-55 and 14mm. Then came to big guns/primes. I suspect that if they started with big lenses the system would not have sold as well since part of the allure was small and light. Next comes the big zooms with 72 and 77mm filter sizes like the 10-24, 16-55, 50-135 w/tripod collar
Personally, i am sticking with the small and light lenses. Choice is good.
they also started out with a hybrid rangefinder style and now have a model T SLR style with big hump.
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
Les Lammers
Les Lammers Veteran Member • Posts: 3,010
They are after me as I type. Gotta run.....:-O
 Les Lammers's gear list:Les Lammers's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X-E1 Fujifilm X-T10 Fujifilm XF 18mm F2 R +5 more
proque Forum Member • Posts: 54
In my mind pace lens releases equals lens roadmap. Therefore, the answer is yes. FUJI is still in the business of making revenue and the more we buy their products the better it is for them.
Lucky for us early adopters, the image and build quality of their initial lens offering (XF line) are so good that it is really up to you if you need more. As opposed to some manufacturers that will start with crappy lens offering.
I also like the way they pace it with price in mind as well. The prices of their latest offerings is trending higher. Imagine if it is the reverse.
 proque's gear list:proque's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +2 more
