Impression on XT-1 and 56mm/1.2, plus some thoughts on upcoming 16-55 f2.8 and 50-140 f2.8 lenses.
Started Apr 5, 2014 | Discussions
jennyrae
Senior MemberPosts: 2,690Gear list
Apr 5, 2014
XT-1:  got to try it. impression I have of camera is very positive. AF is very fast and accurate. build is very solid. EVF is very good and did not see lag, though could be better if bigger and brighter but otherwise very nice. display screen is very good and nice also. camera is not small but about same size as XE-2.  but XT-1 is best when bigger. I find perfect balance with XT-1 camera if used with battery grip accessory. if people consider buying this camera, it is highly recommended and advisable to get battery grip also.  camera may look bigger but is best that way, I promise.
56mm 1.2: one word description only, AMAZINGLY BEAUTIFUL ! wait, that is two words, laugh.  lens is a must buy. very beautiful isolation and creamy background blur, also bright. but what is amazing is despite opening, lens is very easy to focus and accurate. speed is fast enough. very very very very very very sharp from f1.2 and no problem getting perfect focus.
16-55mm f2.8: only dummy model but I see lens is small compare to similar fast zooms from other brands but still cannot be put on pocket.  weight approximation is possibly around 400g only. target release date is June 2014.
50-140 f2.8: dummy model also. lens is big and long but small compare to similar lens fast zooms from other brands. definitely cannot be pocketed and need bag for it. lens has clamp and approximate weight could be 600-700g.  quite heavy but very light and small compared to similar fast zooms. target release date is September/October 2014.
*** lenses are perfect fit for XT-1 especially with battery grip.
No Regrets
Senior MemberPosts: 1,018Gear list
Re: X-T1 and the 16-55 f2.8
In reply to jennyrae, Apr 5, 2014
Hi Jennyrae,
I just ordered the XT-1, 23mm1.4 and the 55-200mm.  I didn't go with the kit 18-55mm as I was hoping to maybe get the 16-55 f2.8 instead.
Do you have any idea of what the 16-55 f2.8 will cost?
 No Regrets's gear list:No Regrets's gear list
Nikon Df Carl Zeiss Apo Sonnar T* 2/135 Sigma 50mm F1.4 DG HSM | A +2 more
inasir1971
Senior MemberPosts: 3,415Gear list
Get your guesses in!
Cool - let's see who gets closest!
650g
900g
 inasir1971's gear list:inasir1971's gear list
Nikon D4 Nikon D810 Nikon D750
SaltLakeGuy
Forum ProPosts: 10,918Gear list
In reply to No Regrets, Apr 5, 2014
I think it is very safe to assume you can count on it costing NO less than $1000USD. Probably more like $1200. Guess we will see soon enough.
Fuji X-T1 Camera, Fuji 18-55 f2.8-f4 Lens, Fuji 55-200 f4-f5.6 Lens, Fuji 23mm f1.4 Lens, Fuji 56mm f1.2R Lens, waiting for the Fuji mount Nissin i40 Flash, Picturecode PhotoNinja
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-240mm F3.5-6.3 OSS +1 more
jennyrae
price is relative with other similar lens from other brands. so is not cheap.
jennyrae
In reply to SaltLakeGuy, Apr 5, 2014
something around that. lens is heavily corrected from what I heard.
Steve W
Senior MemberPosts: 2,009Gear list
Re: Get your guesses in!
In reply to inasir1971, Apr 5, 2014
650g
900g
If the 16-55mm is ~650g then its about the same weight as Canon 16-35 f/2.8 is 625g
if the 55-140mm is ~900g thens a little heavier than Canon's new 24-70 f/2.8 which is ~805g. The older 24-70mm f/2.8L Version 1 was a little heavier.
So if you get access to these you can probably get a good feel for the size of Fuji's new lens.
 Steve W's gear list:Steve W's gear list
Canon PowerShot G11 Canon EOS-1D X Canon EOS 5D Mark III Sony a6000 Canon EOS 7D Mark II +33 more
jennyrae
In reply to Steve W, Apr 5, 2014
sorry I have no scale to weigh lens with precision but I only feel dummy lenses with my hand. my approximation of the lenses is 400g for the short zoom and 600-700g with long zoom. as I said, lenses feel lighter than my Canon glass counterparts. take grain with salt also because Fuji lens is subject to change. modify with pull something mechanism for focus and trim down further from what I hear.
Full Frame project is not top priority but Fuji try to compete against FF with performance and lenses.
gerard boulanger
Senior MemberPosts: 2,262Gear list
Re: Impression on XT-1 and 56mm/1.2, plus some thoughts on upcomin -55 f2.8 and 50-140 f2.8 lenses.
Pentax 50-135 f/2.8 weighs 685 gr...I guess the 50-140 to be close to that?
 gerard boulanger's gear list:gerard boulanger's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8
Steve W
Re: Impression on XT-1 and 56mm/1.2, plus 16-55 f2.8 and 50-140 f2.8 lenses.
There is no question in my mind after owning Fuji equipment along side my Canon gear for about the last 2.5 years that the Fuji APS-C system will always be smaller and lighter than FF, even when the make f/1.2 primes or f/2.8 zooms. The key will be is it small enough? There original 18-55 f/2.8-4 is great. The f/2.8 I'm sure will be great as well just larger and heavier. Just like all the f/4 zooms Canon and Nikon make are smaller and lighter than their f/2.8 brothers. Or why a 23mm f1.4 prime is bigger than a 23mm f/2.0 prime. Physics is physics. For me I'd rather own the 14mm f/2.8, 23mm f/1.4 and 56mm f/1.2 since I'm more concerned about weight when I hold the camera than the weight on my shoulder which isn't much different.  I know the 10-24 is much bigger than the 14mm. Some want speed, flexibility, and the convince of not changing lens, some like fast primes, and some want lighter and are more than willing to accept the loss of one stop. Heck, Leica realized this more than 75 years ago. I just want the flexibility to choose which as Fuji grows this lens line we are getting. Now if I could just get a 90mm f/2 or f/2.4 with IS that would be great.
jennyrae
In reply to gerard boulanger, Apr 5, 2014
Yes. something like that. is not really very heavy. difference is build quality and finish of Fuji zoom is really nice. too bad it come late this year.
