canon 600d
Started Apr 4, 2014 | Questions
BhaskaranBhas New Member • Posts: 1
canon 600d
can i get doubled when i use Canon -Extender EF 2x III  to my cannon 600d 55-250mm to 500mm
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
confyushis Senior Member • Posts: 1,070
no ...
from the canon usa website:
This lens is only compatible with fixed focal length L-series lenses 135mm and over, as well as the EF 70-200/2.8L, EF 70-200/2.8L IS, EF 70-200/4L, and EF 100-400/4.5-5.6L. Additionally, please see the lens and/or camera body manual for full compatibility information with the Extender EF 2X III.
 confyushis's gear list:confyushis's gear list
Canon EOS 550D Canon EOS Rebel SL1 Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 30mm F1.4 EX DC HSM Sigma 8-16mm F4.5-5.6 DC HSM +3 more
Lemming51
Lemming51 Forum Pro • Posts: 14,050
and more generally, no ...
Also the third party TCs that fit between camera and lens (Kenko, Tamron, ...) cannot be used either.  No one makes a TC compatible with the EF-S mount.
There are teleconverters that will screw onto the front threads (58mm diameter) of the EF-S 55-250.  However, these are intended for the small sensors of compact digital cameras, so are likely to vignette.  Additionally, they are a quite heavy attachement to the end of the lens, stressing the zoom and AF mechanism.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM +5 more
Digirame Forum Pro • Posts: 32,408
Re: canon 600d
I've been using the Canon 55-250mm lens for a little over two years.  I have not heard of a good 2x teleconverter for that lens.  So, what I do is challenge myself to get closer to the wildlife.  We were discussing it the other day, that you could buy or make a bird screen.  It's basically a tent with holes in it for the camera etc. (to keep you hidden from them).  I don't know if that is why you want more zoom, but doing things like that can help and it doesn't cost a lot of money.  You could save up for the Tamron 150-600mm lens, as soon as it's available.  That's a good option too.
