DF - low light focusing speed?
Started Apr 2, 2014 | Discussions
vladi1234567 Contributing Member • Posts: 808
I was just wondering if the owners could share their experiences with how fast the Df can lock the focus in the low light situations - something that would require 1/100s shutter speed, 1.8 aperture and 6400-12800 ISO.  I've found a couple of reviews today that claim it takes up to 10 seconds to lock focus, and sometimes it wouldn't lock at all.  Would those who use the Df in low light agree or disagree?  What are your personal findings in that regard?
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
Nikon Df Sony RX1 Sony RX100
Nikonparrothead Veteran Member • Posts: 4,648
Re: DF - low light focusing speed?
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
Frim my experience it focused "easily" I never bothered timing it -- which should suggest that it's inconsequential.
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
vladi1234567 OP Contributing Member • Posts: 808
Thank you!
D700, RX100, RX1
www.vnkphoto.com
Dave Thompson Contributing Member • Posts: 805
Hi, I shot some pictures recently at a folk festival and was at 12800 ISO for a lot of the time and had no issues at all. Using a 50 1.8, 85 1.8 and 70 - 200 2.8
I was really impressed with the results considering the lighting.
Regards, Dave
 Dave Thompson's gear list:Dave Thompson's gear list
Olympus E-M1 Nikon D750 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Panasonic Lumix G Vario 7-14mm F4 ASPH +13 more
Hugo First Contributing Member • Posts: 780
6
bottom line: no light or contrast, no focus.
even in low light, if you have a decently lit edge of a person, for example, it's no worse than the bigger bodies like the D800 (which i also use). in good-- but not great -- light, i've been surprised at how well the Df compares with the D800 in obtaining focus on moving subjects. not saying it's perfect, just better than you'd expect given all the negativity.
on the minus side, that cluster of AF points can seem a little constraining, if you're used to having 51 of them across the frame -- even worse if you're coming from a 51-point cam like a D300.
but given the sensitivity of the sensor, gosh, it just opens up opportunities for getting shots that you just don't have without springing for a D4(s).
scokill Senior Member • Posts: 2,448
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
Have had zero issues in any light.  As another poster mentioned, if there is no light or no contrast any camera will have an issue.  To claim under any reasonable circumstance that the Df takes 10 seconds to lock focus in low light is BS.
 scokill's gear list:scokill's gear list
Nikon D610 Nikon Df Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 50mm f/1.8D +1 more
InTheMist
InTheMist Senior Member • Posts: 3,077
This is my experience too.  ISO H1, find a location with 1/50th shutter speed with kit lens, can I focus?  No.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 +18 more
Felts Contributing Member • Posts: 566
Coming recently from Fuji cameras, I am astounded there is ANY negativity surrounding the AF on the Df... Really! I'm not saying the D800 isn't better, but we surely have to be disecting pre-split hairs here.
And not even the X-Pro1 with FW 1.0 would take 10 or even 5 seconds to focus in the darkĀ
 Felts's gear list:Felts's gear list
Fujifilm FinePix X100 Nikon Df Nikon AF Nikkor 135mm f/2D DC Sigma 50mm F1.4 EX DG HSM Samyang 14mm F2.8 IF ED MC Aspherical +6 more
j_photo Senior Member • Posts: 2,597
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
It's nearly as good as my D800. Maybe not always as good, but close enough not to notice any meaningful difference under normal shooting.
In regular usage I've never seen it hunt anything like what you describe, except once when I deliberately aimed it at an featureless wall with no detail or contrast in extremely poor lighting. I doubt my D800 would have focused there either.
 j_photo's gear list:j_photo's gear list
Nikon D800 Nikon Df
kape06111
kape06111 Regular Member • Posts: 157
Really happy and satisfied with the focus of the DF in every situation.
 kape06111's gear list:kape06111's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX8 Phase One Capture One Pro
Regards, Dave
Thank you, much appreciated
D700, RX100, RX1
www.vnkphoto.com
I had a D600 for a couple of months, but never used it in low light - but I do know what 39 focus points look like.  Appreciate your response - I'm pretty close to buying me one - just got concerned by those reports of focus troubles with the Df.
D700, RX100, RX1
www.vnkphoto.com
scokill wrote:
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
Thank you for the response - glad to hear it.
As far as 10 seconds to lock focus, here's the review I'm referring to:
"I do have one gripe, though. I kept pushing the camera to tricky low light situations.. but the lower the light, the harder it was for the Df to focus. In almost all of the portraits, it took around 10 to 12 seconds for the camera to hunt and nail the focus.. it can be quite awkward for the stranger to look at the lens that long. On normal lighting situations, the camera usually gets the focus in a second, and I get all the frames I need well within 10."
http://www.dannyst.com/shooting-low-light-portraits-with-the-nikon-df/
D700, RX100, RX1
www.vnkphoto.com
By kit lens - do you mean 50 1.8G?  The Df wouldn't lock focus in H1 and 1/50th?
D700, RX100, RX1
www.vnkphoto.com
Hi, yes - being the Sony RX1 owner - I'm aware of what the slow focus in low light works like with mirrorless cameras The RX1's PQ is pretty phenomenal in low light, by the way - but I just don't want another camera that would be as slow to focus as my RX1 in low light, what's the point then.
Here's another Df auto focus observation - this one from Amazon, verified purchase:
"the focus at low light sucks, real bad. I wanted to do a high ISO group shots but couldn't because my camera couldn't focus. This being the strongest feature of NIXON is now a disappointment on the Df. The light was low, but not that low. I think not having an assistant light is the biggest mistake they made. MY SOLUTION: I programmed the fn button to "no flash" so I put on the flash on the camera, used the strobe's assistant focus (red light) and shoot while pressing the fn button to avoid actually triggering the flash when I shoot. Way to loose your vintage look"
D700, RX100, RX1
www.vnkphoto.com
j_photo wrote:
Thanks and regards
D700, RX100, RX1
www.vnkphoto.com
Thank you, much appreciated!
D700, RX100, RX1
www.vnkphoto.com
Thank you!
D700, RX100, RX1
www.vnkphoto.com
Shotcents
Shotcents Senior Member • Posts: 4,472
Compared to my D800, my Df nails focus as fast.
The only time I was able to make the D800 "better" than the Df was in marginal situations where I looked to make both cameras miss. Most of the time BOTH would have trouble locking focus and these were silly lighting situations where I was lighting a room with a single bulb in a corner!
My Df has REPLACED my D800 90% of the time. I only grab the D800 when I need the 36mp. Other than that, the Df is a better camera for me, smaller, lighter and more fun to use with superior low light results right out of the camera.
Robert
 Shotcents's gear list:Shotcents's gear list
Nikon Coolpix P7700 Nikon D800 Nikon D5200 Nikon D5300 Nikon Df +11 more
Cliff Fujii
Cliff Fujii Veteran Member • Posts: 4,691
I have a Df that was purchased especially for it's low light abilities. I take photos at EV2 and the Df locks in as if it was taking images in broad day light. In fact, I have been in situations where the D800 would roam a bit before locking in but not the Df (using the same lens, of course). The ability to capture good images at ISO 12800 is priceless.  The AF was working very well.  I could just see the sign when I took the photo at 1/10sec with VR on.
Disneyland restroom taken at night at EV2
Cliff
 Cliff Fujii's gear list:Cliff Fujii's gear list
Fujifilm X-E2 Nikon Df Nikon D810 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +46 more
Cliff Fujii
That statement is irrelevant unless it's justified by contextual information.  What was the EV that the photo was taken at?
Cliff
