Rubber frame with a dioptric adjustment lens, Canon 600D
Started Apr 2, 2014 | Questions
TheMrPatrick New Member • Posts: 9
Hello,
I am going to purchase a Canon 600D in a few weeks. I have tested the camera last week in a store, but I noticed I couldn't get things that were at a distance perfectly in focus with the dioptric adjustment wheel alone. I wear glasses, but I prefer to use the viewfinder without my glasses on, so I need to buy a dioptric adjustment lens. But I have a question about what rubber frame I should use.
There are 2 models of rubber frames, one is the original that is already on the camera and the second is made for a dioptric adjustment lens.
http://www.bhphotovideo.com/c/product/262221-REG/Canon_8171A001_Eyecup_Ef_for_Digital.html
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=262222&is=REG&addedTroughType=categoryNavigation
The original rubber frame already has a piece of plastic in it, can I remove this plastic and be left with just the rubber frame? Or are they melded or glued together?
I hope I can use the original frame, because finding accessories for the viewfinder is incredibly hard where I live(The Netherlands).
Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
confyushis Senior Member • Posts: 1,070
rubber and plastic are detachable ...
the entire original eyepiece (plastic+rubber) can be removed from the camera by sliding it up relative to the camera body.
the entire original eyepiece is meant to be removed so that a photographer can cover it when doing remote shooting. if no eye is looking through the eyepiece, light can enter the camera through the eyepiece and affect metering and even the final photo ... see the following video for more info ...
https://www.youtube.com/watch?v=B-dxQ_Xxapk
no.  the rubber can also be detached from the plastic with gentle pulling and manipulation.
 confyushis's gear list:confyushis's gear list
Canon EOS 550D Canon EOS Rebel SL1 Canon EF-S 15-85mm f/3.5-5.6 IS USM Sigma 30mm F1.4 EX DC HSM Sigma 8-16mm F4.5-5.6 DC HSM +3 more
TheMrPatrick OP New Member • Posts: 9
Re: rubber and plastic are detachable ...
Alright, thanks. But it seems like it doesn't matter. I am reading the customer reviews on B&H and apparently the original rubber doesn't fit the new adjustment lens.  But again thanks for the help.
msowsun
msowsun Contributing Member • Posts: 578
Re: Rubber frame with a dioptric adjustment lens, Canon 600D
TheMrPatrick wrote:
Hello,
What camera have you been using up to now? I don't think there should be any difference with near or far subjects and what you see in the viewfinder.
I would test the camera again before you spend money on a dioptric adjustment lens. All you need to do is adjust the dioptric so the numbers at the bottom of the viewfinder are sharp. If they are sharp then the viewfinder should also be sharp.
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EF 100mm f/2.0 USM Canon EF 100mm f/2.8 Macro USM +19 more
