Z Coming soon. Hmmmm....
Started Apr 2, 2014 | Discussions
waxwaine
waxwaine Contributing Member • Posts: 981
Re: Z Coming soon. Hmmmm....
"Zo", FF is what you want Pentaxians???...
paulkienitz
paulkienitz Veteran Member • Posts: 5,204
Re: So, it's not a full frame dslr?
VaLeX wrote:
It's sad, because my FF k-mount lenses won't work on the 645D
Or, will they? What's happening if I put my K mount 31mm Ltd on the 645D? The sensor will be cropped, but to what amount? How many megapixels will be used? Not to mention that you get a round image that you can crop as you wish: 4/3, 3/2 etc. Or keep it round
What a great idea for Pentax! To use the 645D as a full frame with ff-K mount lenses, via an adapter that makes auto-focus possible
How will you get the 31 Ltd into the 645's mount flange so it's at the correct registration distance?  With a hammer?
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
VaLeX Senior Member • Posts: 1,067
Anything that works!
Anyway, I don't have a clear grasp on what's the registration distance and how this varies between K-mount and 645D mount. From what you say, I assume it's the distance between mount (or last element of lens?) and sensor? And the registration distance for 645 is bigger than that for k mount?
However, my commentary was not supposed to be taken seriously
Comments, criticism, suggestions: it goes without saying!
 VaLeX's gear list:VaLeX's gear list
Pentax K10D Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited
James O'Neill Veteran Member • Posts: 4,106
It's the distance between the back of the lens (when focused at infinity) and the image. If you measure the distance between the image and lens mount on a K3 all the way back to the M an K series film cameras it's the same, but less than 6x7 and 645 cameras. So you can mount their lenses on a K mount camera with a spacer (with MF mount one side and K mount the other side).
To put a K mount lens on a 645 it would have to mount inside the body to focus at infinity (might work for close ups though).
ozdean
ozdean Forum Pro • Posts: 22,995
In lieu of FF? New format so not a 645 MF.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
ozdean
No maybe just the new 645d - no other intro for it on the site.
Roland Karlsson Forum Pro • Posts: 24,546
The registration distance for K-mount is 45.46 mm, and for 645 it is 70.87 mm.
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony Cyber-shot DSC-RX100 III Pentax K-3 Pentax K-1 +12 more
solarider Veteran Member • Posts: 4,382
With special adapter, 645 lenses can be mounted on K mount cameras, though AFAIK not the reverse.
solarider wrote:
What's so sad about much-fuller-than-so-called-35mm? 645 is a whole lot bigger than FF. Pentax 645 is over and well above any FF out there.
VaLeX wrote:
So sad!
The intuitive mind is a sacred gift, the rational mind is a faithful servant.
We have created a society that honors the servant and has forgotten the gift. - Albert Einstein
________________
Science... became Scientism, which means it didn't just pursue its own truths, it aggressively denied that there were any other truths at all... Ken Wilbur
__________
Coincidence is God's way of remaining anonymous - Albert Einstein
________________
__________
samhain Senior Member • Posts: 1,157
It's a 645d with a cmos sensor.
It would be pretty funny if they teased a fake FF model for April fools day
justin23 Veteran Member • Posts: 4,347
That has been done for many years, several times people fell for it.
Justin
http://www.pentaxphotogallery.com/justinwatson
 justin23's gear list:justin23's gear list
Pentax K-5 Pentax Q Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA 16-45mm F4 ED AL +11 more
