Kirk L-bracket on D800
Started Apr 2, 2014 | Discussions
Paul Skelcher Regular Member • Posts: 412
I'll be renting a D800 for an upcoming 3 week long project.
Any one know if the Kirk L-bracket I use on my D700 will fit?
Paul
Photofunster
Photofunster Senior Member • Posts: 1,548
Re: Kirk L-bracket on D800
The main difference between the D700 L-Bracket
http://www.kirkphoto.com/L-bracket_for_Nikon_D700.html#
D700 L Bracket
and this D800 L-Bracket, http://www.kirkphoto.com/L-bracket_for_Nikon_D800.html
is where the screw attaches it the the camera tripod mount.
This L-Bracket can be adjusted further over, because of the screw slot, to allow more room for a larger body.
D800 L-11Bracket
You would have to measure the bracket you already have, from the centre of the mounting screw to the inside edge where it curves up. Then one of us could compare that measurement to our D800, for you.
Chas
D800, AF-S NIKKOR 80-400mm f/4.5-5.6 G ED VR, B+W Clear MRC 77mm, AF-S NIKKOR 24-120mm f/4G ED VR, Sigma DG UV 77mm,
SB-910, WG-AS3, ME-1, Lexar Professional 600x 64GB SDXC UHS-I 90MB/s*, 400x 32GB SDHC UHS-l 60MB/s*
Vanguard ALTA PRO 263AT, GH-300T, SBH-250, SBH-100, PH-22,
Lowepro S&F Deluxe Technical Belt and Harness~Pouch 60 AW 50 AW & 10, S&F Toploader 70 AW, LC 11x26cm
FE, NIKKOR 2-20mm f/1.8, OPTEX UV 52mm, Viivitar Zoom 285,
Kodacolor VR 1000 CF 135-24 EXP DX 35mm, rePLAY XD 1080P
 Photofunster's gear list:Photofunster's gear list
Nikon D800 Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 80-400mm f/4.5-5.6G ED VR Apple iPad 3G +WiFi +2 more
GBJ Regular Member • Posts: 238
Hey paul, yes the L bracket for the D700 camera will work on the D800 camera.
I did exactly that about a year ago. The thing to know is that it does not fit perfectly on the D800, but it fits fairly closely, so if you are just trying to make it work while renting the D800 then it will be more than adequate!!!
Photofunster
That's pretty awesome to learn.
Ok, well then put away the inside outside callipers... Hahaha
No need to buy the second bracket, or go without.
Enjoy that D800 by the way.
Chas
Paul Skelcher OP Regular Member • Posts: 412
D700 L Bracket
Chas,
Thanks for going to the trouble about this.
From the center of mount screw to inside edge of the back of the bracket is 16/32". The thickness of that edge is 2/32".
From center of screw laterally to the outside edge of the shorter vertical part of the "L" is 2 3/4". That shorter vertical arm clears the camera body by a tad over 1/8".
All I need is for the D800 bracket to be same size or slightly smaller with regard that back edge.  If necessary I'll just go ahead and buy the bracket as I'll probably buy the D800 after giving it a try out.
Paul
Hey, Chas and GBJ,
I cross posted there. Question answered.
Thanks very much both.
Paul
