EM-1 Wifi question with Samsung S4
Started Apr 1, 2014 | Questions
dfstarman
Contributing MemberPosts: 526Gear list
Apr 1, 2014
has anyone with the S4 on kitkat  gotten the save photo on the app to work?
If so was there any trick or setting on the phone?
 dfstarman's gear list:dfstarman's gear list
Sony RX100 Sony Cyber-shot DSC-HX50V Sony SLT-A77 Fujifilm X-Pro1 Olympus E-M1 +27 more
alolywu
Regular MemberPosts: 273Gear list
Android feature
In reply to dfstarman, Apr 1, 2014
Yes, there is.  Under Wifi Settings, select Advanced.
Deselect Auto network switch.  This "new" feature disconnects any wifi connection that does not connect to the Internet so any Hot Spots created by cameras will be automatically disconnected.
That worked for me.
dfstarman
Re: Android feature
In reply to alolywu, Apr 1, 2014
Thanks but that does not affect the ability to save a photo, Mine was not checked
alolywu
Re: Android feature
In reply to dfstarman, Apr 2, 2014
So you can connect to the camera?  You can preview the photos but can't save?
dfstarman
Re: Android feature
In reply to alolywu, Apr 2, 2014
correct, I Can connect and control camera but cannot save
smithling
Regular MemberPosts: 380Gear list
Re: EM-1 Wifi question with Samsung S4
Are you shooting raw only? I believe only jpgs transfer.
dfstarman
In reply to smithling, Apr 2, 2014
I normally do shoot raw but spotted that in the doc and tried to save a jpeg same thing "photo not saved"
Impulses
Senior MemberPosts: 4,037Gear list
Re: Android feature
It does actually, if you select it then it'll never work because the phone can't see the internet on your camera so it refuses the connection. Not saying you don't have some other problem, just making sure you don't add to it.
 Impulses's gear list:Impulses's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 +26 more
ippiu
New MemberPosts: 15
The same problem happened to me with S4 kitkat and em-10.
Oly fixed that with a new version of OI Share: search on google play and download the new OI Share version.
It fix the problem you mentioned and everything works well.
the problem was caused by the fact that who had a smartphone with an extra memory card inserted. If you take out memory card from the phone, it worked. Now they fixed the problem and you can let the extra memory card inside the phone!
dfstarman
In reply to ippiu, Apr 2, 2014
I just discovered this before I read your post.
I took out my sd card and it worked ,
YEAH
Now I will try the new release, I did not know about that
That works too Eureka
Grazie
dinoSnake
Senior MemberPosts: 1,607
Which means that the problem is caused by KitKat"s new handling secondary (external) storage permissions
http://www.doubleencore.com/2014/03/android-external-storage/
it is turning into a royal pain
ippiu
New MemberPosts: 15
In reply to dinoSnake, Apr 2, 2014
Pain? Everything works fine now after installing the new OI Share version...
dinoSnake
Exactly.  Every developer who's app uses general file access is having to rewrite for KitKat's media / SD permissions and issue an update, and everyone who is using the app must apply the update (and hope that it doesn't break something on non-KitKat models).  Try a Google on "es file explorer KitKat" or "SD card KitKat".
