Traveling heavy (D3s) to light (D800)....not the files : )
Started Apr 1, 2014 | Questions
svai2 New Member • Posts: 15
Hi guys,
I recently did a complete reorganization of my gear.
I used to travel with a D3s, 14-24mm, 24-70mm,70-200mm and 85mm f1.4d.
I had more than enough...so, for my next travel I purchased a D800 and the new 85mm f1.8G (wow, now that's light !).
I was thinking of getting the 35mm f1.8 as well...
Now I would bring only the D800, 2 primes and the 70-200mm.
Anyone out there having done it before ?  Any thoughts or experience to share ?
Thanks in advance for your inputs,
M
Nikon D3S Nikon D800
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 12,505
Re: Traveling heavy (D3s) to light (D800)....not the files : )
I've gone through various setups to travel 'lighter' (lighter than bringing the whole backpack), while trying to maintain highest IQ.
While I've not gone from D3s to D800, I do now travel with a D800e.   And I always have a grip on there, so it probably isn't any lighter than a D3s.
My upper limit for lenses and cameras is 'whatever fits in my waist bag'.   Gotta draw a limit somewhere, and the waist bag I have is the most comfortable way I know of to carry my gear.  (Waist strap combined with a cross-shoulder strap).   I use a Thinktank Speed Racer.   It will certainly carry more gear than a single camera and two primes, but it really has a problem with the 14-24.
With DX, I crammed 12-24, 24-70, 80-400AF-D and 10.5 fisheye in there with a D300+grip.  (And the Speed Racer is needed for cameras with grips.  Otherwise you can use a Speed Demon or Speed Freak.)
With FX, the problems began with the 14-24.   If I put that in, something else had to come out.  Eventually, when I went from D300 to D700, I decided that 24mm was wide enough, so I left out a wide zoom entirely.   And I went from the 80-400AF-D to my old 80-200F2.8, just because I once again liked the 80-200 range (on FX).
For a big Euro trip last year, I decided I needed more range for flexibility.  So I added a 16-35 (about the size of the 12-24DX) and switched from 80-200 to 80-400g.
I also, at times, carried the Sigma 35F1.4 and Nikon 85F1.8g instead.
I've never really liked traveling with the 70-200 much.  It's quite a long lens, and in the bag I use, that becomes a small issue.  If I mount the camera to it, it sticks up so high it's a problem zipping the bag closed.   If I put it off to the side of the camera in my waist bag, it sticks up where the camera sides are, so I still have the same issue.   I prefer carrying the 80-400g, because they are about the same length for packing and about the same weight.   But I can zoom in on architectural details nicely.   I ended up using the 80-400g far more in Europe than the 16-35.
Seems like if you are going for a prime solution, then the 180F2.8 prime may be a nice fit instead of the 70-200.
Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +35 more
Schroedingers_cat
Schroedingers_cat Veteran Member • Posts: 3,908
I believe that it is essential to differentiate between a "vacation" and a "photographic vacation."
You going by yourself or with some body else? If with somebody else, what's their level of tolerance for you holding things up changing lenses and taking photographs?
I am a proponent of the one body/one lens theory, although before I got married I just took as much as I could carry. I'd like a D800 and mid range zoom, but that's just for my personal uses. YMMV.
And welcome to the forum
http://www.nightstreets.com
"Sick cultures show a complex of symptoms such as you have named...but a dying culture invariable exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners is more significant than a riot."
This symptom is especially serious in that an individual displaying it never thinks of it as a sign of ill health but as proof of his/her strength. ...Friday, it is too late to save this culture--this worldwide culture... Therefore we must now prepare the monasteries for the coming Dark Age. Electronic records are too fragile..."
--Robert A. Heinlein in "Friday"
Rich Rosen Senior Member • Posts: 1,929
svai2 wrote:
Hi guys,
Unless I know that I am absolutely going to need the 70-200, it stays home. In previous travels, I use wide angle and mid range zooms, and when I tour , I prefer the one lens solution (that's a laugh, because there really isn't a one lens solution).  I have also gone lighter. I bring my D600, my 24-120 f4, an 85 1.8G and the 28 1.8g.
 Rich Rosen's gear list:Rich Rosen's gear list
Nikon D810 Nikon D1X Nikon D610 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +25 more
bocajrs
bocajrs Senior Member • Posts: 1,571
D800 with 28/50 1.8g and 70-200 F4 lenses.
 bocajrs's gear list:bocajrs's gear list
Nikon 1 J4 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-20E III Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
larrywilson
larrywilson Veteran Member • Posts: 4,714
I travel with a 25mm f2.8 Zeiss, 50mm f1.2 Nikon and 70-200 f4.0 Nikon with my d4, from now on with my d800e.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 500mm f/4G ED VR Tokina AT-X 16-28mm f/2.8 Pro FX Carl Zeiss Makro-Planar T* 2/100 +7 more
Janoch
Janoch Senior Member • Posts: 2,401
Can't help you, but if we should have a contest of weirdest solution, I might be the winner!
Here's the odd three-some, I've ended up with in my attempt of running "light"...
An old Nikkor 17-35mm f/2.8, an even older Nikkor 35-70mm f/2.8 and a brand new Nikkor 70-200mm f/4.
Beat that! - and with a weight of 2260 grams.
 Janoch's gear list:Janoch's gear list
Nikon D800 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm f/4G ED VR +2 more
(unknown member) Veteran Member • Posts: 3,348
D3s
D3x
14-24 or 17-35 on one (presently the 14-24 but want to sell and replace with 17-35)
70-200 VRII on the other.
Spider holster, one on each hip. No other lenses usually when travelling (maybe my old 50mm f1.4D in a pocket) overseas.
David314 Veteran Member • Posts: 4,790
D800 with 50mm prime
svai2 wrote:
Hi guys,
A
I'd just throw in the 50mm f1.4 prime and be done with it
RBFresno
RBFresno Forum Pro • Posts: 10,934
For me, Travel weight is more about the lenses.....
svai2 wrote:
Hi guys,
M
HI!
Although I've had multiple bodies in the past, I'm pretty much down to a D4 (and a Coolpix!) at the moment.
I have a mixture of relatively 'heavy' and 'light' lenses.
Depending on the locale and subjects, my mix varies. My last 'light' kit was at Disneyland: D4, 10.5 fisheye, 28 1.4, and Zeiss 100/2. Oh, and a flash (I probably should get an SB-300 so I don't drag around the much larger SB-900 as much):
Nikon D4 ,Nikkor 28mm f/1.4D AF ,SB-900
1/500s f/1.6 at 28.0mm iso3200
Nikon D4 ,Carl Zeiss Makro-Planar T* 2/100 ZF
1/125s f/2.8 at 100.0mm iso3200
RB
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +12 more
larrywilson
Re: For me, Travel weight is more about the lenses.....
Robert, I was looking at you at 100%, did you not shave for the image?
Larry
RBFresno
Larry
Ha Ha!
Well, I sometimes like" letting myself go" if I get a few days away from work (where I can't!).
(Warning: I'm not sure that looking at any 100% shot of me is a good idea)
However, I do engage in some activities that do show off my good looks:
(10 hours ago, I was up in the Mountains skiing on 10 inches of fresh snow.....Winter in April!)
Best Regards,
RB
soloryb Senior Member • Posts: 2,126
I travel with a D800E with a 70-200 attached. I also carry a 2X tel-extender, a 50-mm and a 10-mm. Except for the 70-200, the other glass doesn't weigh much and takes up little space.
I carry it all (plus more) in a Kata 3N1-30 and I can keep the body with the 70-200 attached in the lower quick-access compartment - where I can get it out in under 10-sec. The Kata is incredibly comfortable and highly versatile.
soloryb
svai2 wrote:
Hi guys,
M
 soloryb's gear list:soloryb's gear list
Fujifilm FinePix X100 Nikon D800E Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Fisheye-Nikkor 16mm f/2.8D +9 more
svai2 OP New Member • Posts: 15
Thanks a lot for all your comments and hints ! Very informative !
I can't go without the 70-200mm that's why I thought of replacing the heavy 14-24mm and 24-70mm by primes.
I'll give it a try, anyway... on my last trip, I took a lot of pictures with my iPhone and Hipstamatic...I like old look and crappy as well as high resolution pictures...
Go figure !!
