A6000 quick AF test with dogs
Started Mar 30, 2014 | Discussions
koylez New Member • Posts: 4
I know there have been some people asking for AF test with dogs, so here's mine:
http://www.dpreview.com/galleries/5522221024
The weather finally cleared enough for me to take these yesterday afternoon after 5:30. The light was falling so I let the camera decide ISO. A lot of them appear to be ISO 1600 and above, so the results are a bit muddy. I also had to use a faster shutter speed to avoid motion blur.
I'm not sure if it's as good as my old Nikon D300, but it's at the stage where I don't really have to worry about the focus system. My NEX 7 could not take these.
Nikon D300 Sony a6000 Sony Alpha NEX-7
jpr2 Forum Pro • Posts: 14,710
re: since EXIFs seem to be stripped...
koylez OP New Member • Posts: 4
Re: re: since EXIFs seem to be stripped...
jpr2 wrote:
...what lens[es] was it?
jpr2
It was the FE 55mm 1.8. The only other lens I've got is the 24mm, which is a bit wide to test with. I notice the 24mm doesn't support AF-A. Not sure if I can get the firmware updated to support it? The 55 does seem to focus quicker.
shadowz Regular Member • Posts: 197
Re: A6000 quick AF test with dogs
Thank u very much for taking the effort to do the 'running dog AF test "
I felt that the images 2837  and 2838 have the area of best focus a little behind the subject ....
[just my opinion ]:)
dbm305 Senior Member • Posts: 1,625
Thanks! I was one of those asking. ours arrives tomorrow!!
 dbm305's gear list:dbm305's gear list
Sony RX100 Sony Alpha 7R II Canon EF 135mm f/2.0L USM Canon TS-E 17mm f/4L Canon MP-E 65mm f/2.5 1-5x Macro +16 more
Bolshevik Forum Member • Posts: 89
Thank you very much! Very informative - and very enqouraging.
ijustloveshooting
ijustloveshooting Senior Member • Posts: 2,806
if you're not sure if d300 is better or not, then it means that a6000 has top notche focusing performance...d300 af is simply stunning and if a6000 is head to head with d300, then a6000 af is a killer one!...
 ijustloveshooting's gear list:ijustloveshooting's gear list
Fujifilm X-M1 Fujifilm X-A1 Sony a6000 Sony Alpha 7 II Fujifilm XF 35mm F1.4 R +11 more
José B
José B Forum Pro • Posts: 18,324
thanks a lot for doing this test. It looks very, very promising. Just curious, what aperture did you shoot this with?
Best regards,
José
 José B's gear list:José B's gear list
Canon EOS-1D Mark III Canon EOS 5D Mark II Sony Alpha NEX-6 Sony a6000 Canon EOS 5DS +11 more
mrbenji Regular Member • Posts: 252
Thank you SO much! This is one of the best real life tests I've seen... a very valuable data point. Even at ISO3200 & f5.6 there is definitely enough detail and shallow enough DOF to see where the area of critical focus is... the grass really helps in that regard.
Can I ask about your settings, if you remember? Your drive mode was single frame, not continuous, right? Were you in AF-C? What was your AF area, wide?
If you're feeling magnanimous and are are up for another test, I'd love to see a test in similar lighting where you're in A mode, forcing the aperture to f1.8, using AF-C/tracking & wide AF area. Using continuous shooting mode and shooting a burst after calling the dog to you would be way cool.
Provided the lighting is similar, that should get you a high shutter speed AND a lower ISO... depth of field would be way shallower, too. If it chooses a shutter speed under 1/1000 you can dial in a higher ISO to boost it.
Thanks so much!
 mrbenji's gear list:mrbenji's gear list
Sony a6000 Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS +5 more
bill hansen Veteran Member • Posts: 8,686
Another vote for AF-C
I'd like to see that too, and I'll bet you already have plans to try it. I think single point AF, or at most 9 point AF, will work better than wide area (the narrower the focal area, the faster the focus - probably).
Bill Hansen
Ithaca NY, USA
