CV28 Ultron + VM-E on A7R
Started Mar 29, 2014 | Discussions
JeffGo
JeffGo Contributing Member • Posts: 830
Got my new CV28/2 Ultron and the close focus adapter from Voigtlander. I took a few quick shots, nothing special, just checking sharpness and distortion.
Sony A7R sporting a CV28/2 Ultron
Exceptional build quality on this lens, compact and dense. The same can be said for the adapter which is heavier than expected. It has a helicoid focus in the mount to allow much closer focusing, but it takes some practice as it has a disproportionate effect compared to the lens focus ring. I still need to figure out some things about manual focusing, so OOF subjects are my fault.
As expected, distortion isn't a problem at least with landscapes that don't contain bricks or other straight lines. Microcontrast greatly exceeds my expectations and sharpness looks very good although I have not taken much to prove that the borders or corners are very sharp yet.
I took these shots in fairly crappy light, just before the incoming thunderstorm but before the lighting got interesting. There may be some magenta smearing in corners, certainly a little bit of CA which corrects in LR but not done in these postings. These were shot RAW, imported into LR5.3, standard sharpening of 25 and nothing else done.
F2, 1/250s, ISO 100 close focus engaged (about 8-10 inches from the chive plant). Any focus issues are my own as I relied on peaking and didn't have magnification engaged. Specular highlights aplenty if you zoom in, I don't know enough to say they are good or bad.
F2, 1/250s, ISO 100 close focus engaged.
F5.6 or F8, 1/250s, ISO 1250
I will try to take more interesting shots soon this was just what I could get to from my backyard before it poured (again).
 JeffGo's gear list:JeffGo's gear list
Panasonic Lumix DMC-TS20 Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Voigtlander 28mm F2 Ultron +11 more
Sony Alpha 7R Voigtlander 28mm F2 Ultron
Euell
Euell Senior Member • Posts: 1,796
Re: CV28 Ultron + VM-E on A7R
This lens is very sharp and contrasty used with the NEX 6
 Euell's gear list:Euell's gear list
Sony RX100 Canon EOS 7D Sony Alpha NEX-5 Sony Alpha NEX-6 Sony a6000 +15 more
JeffGo
JeffGo OP Contributing Member • Posts: 830
Focus assist?
I don't seem to have the zoom focus assist working as described by others. Do you have that on the NEX-6? While it is possible I have set up something to break this in the menu system, it does work on my FE55. I will keep looking.
JeffGo
Re: Focus assist?
It does work when I set C1 to Focus Mode. One press and I get a bounding box I can move, the second and third presses give me magnification. I guess this is fine.
KwhyChang
KwhyChang Veteran Member • Posts: 3,525
Looks really nice Jeff. I think you made a great choice here. It'll be really nice to have f2 sometimes and 28mm, at least for me, is a very useful angle of view.
Here, I have the Canon 28/2.8 IS which I like a lot.
Some nice images there. I for one would like to see a few more.
Have you needed the fancy adapter, or would a cheaper one suffice?
Is it too early to decide if you will keep it?
Dave
 KwhyChang's gear list:KwhyChang's gear list
Sony Cyber-shot DSC-RX100 III Nikon Coolpix P900 Sony Alpha 7
Euell
Below were taken with the CV 28 Ultron and NEX 6. They have been down-rezzed.
Bald Rock (CA)
BALD ROCK (CA)
BALD ROCK (CA)
osv
osv Veteran Member • Posts: 4,199
those pics are pretty clean jeff! it looks like a nice piece of glass.
when you get a chance... how about a long distance wide landscape shot, camera jpeg, no processing.
thanks,
dan
JeffGo
Dave
Thanks Dave. I am pretty sure this will be a keeper. I have some new skills to work on (like MF with assist). From what I have seen so far, it has some corner weakness for sure, just a little bit of color smear, and a fairly normal and small amount of CA. Center sharpness is really good. I love the build on this lens, everything is tight and smooth. The hood is minimal - I actually thought it was built in because I couldn't get it off yesterday, but today, no problem. I ordered a little bit bigger hood in 52mm instead of 46mm. I can then stack my 49mm CPL and that hood with appropriate step ups and hopefully avoid vignetting.
I think a cheaper adapter would have worked fine. I was interested in getting closer focus than the specified 70cm and with the adapter I can get to 24cm. I did want a decent quality adapter and the regular CV is about $200, Novoflex was about $260. And besides, Brian gave some compelling arguments in his book so now I can shoot just like him I now feel empowered to try other M mount lenses although I can't afford the Leica ones and the Zeiss Biogons might not be the best match, although I would love to be proved wrong.
It might be a long time before we see the sun again so I will try some indoor/flash shots today. Most of my shots have been at higher ISOs. I might also pop this on my NEX-7.
JeffGo
thanks,
dan
Sure, I will definitely try that. If the rain holds off (I think we hit an all-time record for March with a few days left) I will take a walk. I'll turn RAW+JPEG back on for you
Gary H
Gary H Senior Member • Posts: 2,154
I didn't even bother to use my CV28mm f/2.0 given the negative reports.  I have the A7 and the Voigtlander close focus adapter.  Now that I see that someone is happy with the lens, I'll have to dig through my storage and give this lens a try.  Thanks..
 Gary H's gear list:Gary H's gear list
Fujifilm FinePix X100 Fujifilm X100S Canon EOS-1D Mark III Sony Alpha NEX-6 Sony Alpha 7 +13 more
JeffGo
thanks,
dan
JPEGs are at http://1drv.ms/Qwptkr. If anyone wants the RAWs, I can post them too. I am using Auto ISO with a fixed Shutter speed (so same as Manual); apertures were usually f8 or f11, with a few f5.6 - too bad it doesn't get recorded in the EXIF. Some shots appeared dark, and at one point I had boosted the exposure+1. The shadows recover just fine from the RAWs. Nearly all the shots were focused at infinity which with an f11 which puts everything from about 5 feet into focus.
My conclusion from this round is that the corners and borders are definitely soft, and there is definitely a little bit of purple color on the edges. There is also a fair amount of CA that can be corrected; you might have to play with the LR eyedropper a few times to hit just the right spot. Center is quite sharp and the microcontrast is quite nice. So it might not be that much better than the FE2470 at 28mm but I think it is sharper and less distorted so probably no need to correct in landscapes. Vignetting is present but minimal.
osv
that looks like a cool neighborhood to live in!
i see everything that you said about those pics, but i think that there are things that can be done to help alleviate some of it.
were those shot hand-held? because there is micro jitter in most of 'em.
i've been doing a lot of lens testing lately... in bright sunlight i use full manual mode on the a7r:
iso200-250, or slightly higher if necessary.
test-shoot the lens at f8, then ~f10, then f11
shutter at 1/800th or faster if possible, never under 1/500th
i always use a monopod, at the minimum.
view this pic at 1:1, and scroll over to check out the sides... it was shot with an old vivitar 28mm f2.0 lens, using the settings that i just listed above, this was ~f10:
dan
Euell
JeffGo wrote:
thanks,
dan
The wide rangefinder symmetrical-design lenses tend to work better with the APSc sensors, other than the NEX 7.
JeffGo
dan
Thanks for the advice Dan. Yes, they were all handheld, all shot at 1/250s thinking that should be fast enough. But I don't have the steadiest of hands so I will try even faster speeds. The ISOs mostly stayed around 100 so I can definitely afford to go higher and switch it to full manual. I'll bring out the monopod as well but not sure I will take it on my upcoming trip.
