NEX-6 - Will the LCD delaminate like a 5N?
Started Mar 29, 2014 | Discussions
Sleepdance
Sleepdance Junior Member • Posts: 33
I've owned the NEX-3 and 5N, and both suffered from the rear LCD delamination problem . They were easily fixed by peeling off the original anti-glare film and replacing it with an optical glass protector, which brought them back to looking flawless and new.
I have a used NEX-6 ordered and will be installing an optical glass protector on it--should I peel off the original film before doing this, or has Sony made improvements to their coating since the 5N days?
I've come across threads suggesting an optical glass LCD protector for the 6, but no one has specifically said if they removed the anti-glare film before installing it on that model.
Screen delamination on an NEX-5
 Sleepdance's gear list:Sleepdance's gear list
Sony E 16-50mm F3.5-5.6 PZ OSS Sony Alpha NEX-6 Canon EF 50mm f/1.4 USM Sony E 18-55mm F3.5-5.6 OSS +22 more
Sony Alpha NEX-3 Sony Alpha NEX-5 Sony Alpha NEX-6
mxl123dp
mxl123dp Junior Member • Posts: 33
Re: NEX-6 - Will the LCD delaminate like a 5N?
I'm curious to know if the nex 6 has the delaminate issue also.  I just upgrade from original nex-5 to 6.
 mxl123dp's gear list:mxl123dp's gear list
Canon EOS M Sony Alpha NEX-6 Canon EF-M 22mm f/2 STM
areichow
areichow Senior Member • Posts: 1,581
My 5R has the start of this problem as well. I wouldn't be surprised if the 6 also did.
 areichow's gear list:areichow's gear list
Canon PowerShot SD1000 Sony RX100 NEX5R Sony Alpha 7
GaryW
GaryW Veteran Member • Posts: 8,118
Sleepdance wrote:
I've owned the NEX-3 and 5N, and both suffered from the rear LCD delamination problem . They were easily fixed by peeling off the original anti-glare film and replacing it with an optical glass protector, which brought them back to looking flawless and new....
My 5 had this problem, but there was no film to peel off.  Once the Trublack coating wore off, I just left it that way.
Anyway, I ordered Sony's stiff plastic protector to go with my Nex-6, when I originally got it, so my 6 hasn't had a chance to wear off.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha DSLR-A100 +9 more
tqlla
tqlla Veteran Member • Posts: 3,035
what?  You could peel off the film?
unfortunately the trublack coating wearing off, Is a problem with Sony camera LCDs.  I always put a screen protector on my camera's because of this.
 tqlla's gear list:tqlla's gear list
Sony Cyber-shot DSC-RX10 Sony Alpha DSLR-A850 Sony SLT-A99 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +8 more
binauralbeats
binauralbeats Forum Member • Posts: 73
Sony should use glass and raise the price 10$
Don't know why camera makers don't use glass LCD covers.  How much could it possibly cost them?  An additional $.50?
-Really there is a God... And She loves you and wants you to buy camera gear!
Sleepdance
Sleepdance OP Junior Member • Posts: 33
Actually I have my wife do it for me. She can get them peeling in a few seconds with her nails, whereas I messed around for a while and couldn't even get it started. Here is a video showing the full procedure: http://www.youtube.com/watch?v=xW724cngWk4
I don't have a before shot, but it was utterly terrible looking. Here's a picture from my NEX-3's auction showing what it looks like after replacing the film with glass:
Not only does replacing the film fix the delamination, but all of the scratches on my LCD were isolated in that film, so after removing it, the screen underneath was absolutely pristine.
PatrickB01
PatrickB01 Junior Member • Posts: 35
After a year and a half my nex6 shows no signs of the delamination issue.
tqlla
Wow, pretty cool.  THanks for the info
bigley Ling
bigley Ling Senior Member • Posts: 2,863
Re: Sony should use glass and raise the price 10$
yes agree, but I suspect the tru black coating also helps when using the LCD in bright sunlight, and also with reflections. By adding a glasss protector, these fancy coatings may not be as effective especially with regard to reflections
Sleepdance
That sounds very promising. On the 6 then I'll probably try applying a glass protector without removing the film first.
MMMFalafel
MMMFalafel New Member • Posts: 9
My NEX-6 is delaminating. I've had it since December 2012.  I kept it bagless in a coat jacket a lot on European adventures last year, so I guess I should've expected some wear:
GaryW
They charge something like $15 for their plastic protector/cover.
Gary W.
demarren 123
demarren 123 Veteran Member • Posts: 3,595
I just got the NEX6 few weeks I am following this threat.
I am curious.
My English is poor.Try to Understand
Nikon D90,Nikon D3200 Samsung NX100 Fuji X10 Canon 600D
Sony nex5n
_______________________________________________
http://www.flickr.com/photos/73737307@N00/sets/
Claus M
______
 demarren 123's gear list:demarren 123's gear list
Olympus E-10 Sony Cyber-shot DSC-HX100V Fujifilm X10 Nikon Coolpix P7700 Nikon D70s +7 more
GaryW
You know, that looks like it's currently mostly around the edges.  You might be able to put on Sony's protector and at least keep it from degrading further and most of it might not even be visible (as the plastic cover has black/opaque edges that cover the edges, except for a bit in the lower-left corner).  Good luck?
Gary W.
parallaxproblem
parallaxproblem Veteran Member • Posts: 5,334
No, it won't
The problem with the older generation NEX cameras is caused because the protection film that Sony put on the LCD's starts peeling off after a while...   you can complete the process and replace it yourself as a partial repair.  However the protective film was actually part of an anti-reflection process and unfortunately none of the aftermarket films are quite as effective
This protective film was not fitted to the NEX-6 or NEX-5R/T and so you will not have the same problem on those cameras as there is no film to bubble-off!  However by the same token the LCD's of these cameras are not so visible in daylight as on the older cameras
I'm not sure if the film is missing from the later cameras because of the issues it caused on the earlier ones, or simply as a cost-saving measure
What a shame Sony don't sell the protective film to their customers directly!
DUMP the HUMP! A5000 & A6000 success.... campaign for *REAL* NEX-5 and NEX-7 replacement bodies
* newly updated ignore list: hostile responses are probably not visible to me
 parallaxproblem's gear list:parallaxproblem's gear list
Sony Alpha DSLR-A900 NEX5R Sony a77 II
Enigma002
Enigma002 New Member • Posts: 1
Yes. The protective screen will delaminate.
 Enigma002's gear list:Enigma002's gear list
Sony Alpha NEX-6 Canon EOS 6D Canon EF 17-40mm f/4.0L USM Canon EF 24-105mm f/4L IS USM Sony E 16-50mm F3.5-5.6 PZ OSS +1 more
Duskbat
Duskbat Regular Member • Posts: 256
I just peeled off my de laminated screen on my sony 5n. Could someone give me the amazon link to a suitable replacement screen I can order. I can't find exactly what I need to replace my bad film I removed. I guess its a hardened plastic screen cover.
thanks much
I did find this http://www.amazon.com/GGS-Optical-Screen-Protector-NEX-5N/dp/B007V5CD0W/ref=sr_1_fkmr0_2?ie=UTF8&qid=1396234260&sr=8-2-fkmr0&keywords=CGS+glass+protector+sony+5n
Is this what I need or please show me on Amazon what I need to replace what I peeled off.
 Duskbat's gear list:Duskbat's gear list
Sony Alpha NEX-5N Sony Alpha NEX-6 Olympus OM-D E-M10 Apple iPhone 5s
Joachim Wulfers
Joachim Wulfers Senior Member • Posts: 1,541
After two and a half years my NEX 5N shows no sign of delamination. It has had a screen protector since 4 weeks after I received it.
Joachim
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Sony Alpha NEX-5N Sony a6000 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony E 18-200mm F3.5-6.3 OSS +9 more
ryan92084
ryan92084 Contributing Member • Posts: 521
Joachim
Typically its warmth and moisture that do AR/glossy coatings in because they are generally semi permeable.  There were a fair amount of people using microwaved moist paper towels to take overly aggressive AR coatings from their Dell monitors.
 ryan92084's gear list:ryan92084's gear list
Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS +3 more
