Nice L-plate for A7 / A7R with Vertical Grip
Started Mar 29, 2014 | Discussions
d altman Regular Member • Posts: 121
I really like having the vertical grip on my A7, and haven't removed it since I got it. I purchased from www.milich.com an L-plate made for use with the vertical grip. It wasn't inexpensive, $140 plus $20 for shipping, but it fits nicely. It arrived from New York to California via USPS in two days. It's a perfect fit with my RRS head.
The only negative I can see is it isn't possible to remove the batteries from the grip with the plate on it. It is easy to remove the plate though, with no Allen wrench. Probably with the design of the grip and how the battery compartment is extended, it isn't possible to get an L-plate designed to be open right there.
I thought I would share with the group here.
 d altman's gear list:d altman's gear list
Sony Cyber-shot DSC-RX100 IV DxO One Sony Alpha a6300 Nikon AF Nikkor 85mm f/1.4D Sigma 70-200mm F2.8 EX DG OS HSM +3 more
Sony Alpha 7 Sony Alpha 7R
npires
npires Senior Member • Posts: 1,545
Re: Nice L-plate for A7 / A7R with Vertical Grip
Thanks bookmarked! Have ordered a vertical grip also. How much heavier do you feel the camera is now you've added this on top of it? I guess this is when you're doing studio/tripod work?
 npires's gear list:npires's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-5 Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
John A Clark Senior Member • Posts: 1,509
Looks very industrial, and to some extent, you seem to lose the value of having a smaller body.
I go without the grip, but with a RRS custom plate on the bottom. When I want a L plate, I have an old RRS L plate from a Canon 5D I sold I have mounted a clamp inside it, and simply clamp that to the RRS plate on the A7R ... instant L plate
Beauty is only a light switch away ...
www.clarkfamily.com.au
 John A Clark's gear list:John A Clark's gear list
Sony RX100 Canon EOS 5D Mark II Leica M9 Canon EOS-1D Mark IV Sony Alpha 7R +23 more
d altman OP Regular Member • Posts: 121
The grip adds a little weight but makes holding the A7 in any orientation easier and more comfortable, IMO. So even though it adds weight, I don't notice it. The L-plate adds nominal weight, but I will only use it when I am using my tripod.
dbm305 Senior Member • Posts: 1,626
Thanks! been looking for something like this...
 dbm305's gear list:dbm305's gear list
Sony RX100 Sony Alpha 7R II Canon EF 135mm f/2.0L USM Canon TS-E 17mm f/4L Canon MP-E 65mm f/2.5 1-5x Macro +16 more
Gary H Senior Member • Posts: 2,162
I just received my A7 and the first thing that I did was to install the vertical grip.  The second thing was to attach a lens.  Even with the grip the camera is too small for my hands.  I do like the weight savings.  I will need to try this, or a long shot... maybe someone will make a case with the grip installed... doubt it.
 Gary H's gear list:Gary H's gear list
Fujifilm FinePix X100 Fujifilm X100S Canon EOS-1D Mark III Sony Alpha NEX-6 Sony Alpha 7 +13 more
If it makes holding the camera more comfortable, then why would you only use it when doing tripod work?
LBJ2 Senior Member • Posts: 1,172
Thank you.  This is what I have been looking for.  I placed my order and am looking forward to receipt.
Sorry, my response was confusing. I never remove the grip.
