Sony A7 with Canon 16-35mm f2.8 or 17-40mm F4
Started Mar 29, 2014 | Discussions
RER220
Junior MemberPosts: 34Gear list
Mar 29, 2014
I recently purchased the new zeiss 24-70 f4 oss FE for my a7. I took it for my trip to AZ to take photos of the canyons. I had mixed feelings about it since a lot of people said it had soft corners, but sharp center. All of that was true. Horrible for landscape, but very usable for everything else. I already own the metabones adapter, so I'm thinking about going back to L glass for landscape. I can't find much reviews on the 16-35 or 17-40 combo on the a7 system. I use to own the 17-40, it was sharp and light, but might consider the 2.8 cause i might want to get into star photography.
I am aware that certain wide angle combos dont work well with the A7, just wondering if you guys can share your thoughts or samples.
If you want to check out my travel blog - i shoot exclusively with the A7 system now and currently own all 3 zeiss lenses excluded the kit of course
Ryan
www.LIFEofRI.com
 RER220's gear list:RER220's gear list
Fujifilm X100S Sony Alpha 7 Canon EF 50mm f/2.5 Macro Sony FE 35mm F2.8 Sony FE 55mm F1.8
Sony Alpha 7
neil holmes
Veteran MemberPosts: 9,137Gear list
Re: Sony A7 with Canon 16-35mm f2.8 or 17-40mm F4
In reply to RER220, Mar 29, 2014
Ryan
www.LIFEofRI.com
Can not help you with the choice but want to add another option to maybe consider....
Tamron 17-35 2.8-4 in Canon mount may be worthwhile....it is a full frame lens that is also designed for digital.
A few years ago was often considered alongside the 17-40.
I only have it in Pentax k mount so no AF...it seems ok from limited testing....is better as an AF lens and I have some nice MF primes so not wont be used much.....might be a good alternative in Canon AF mount.
 neil holmes's gear list:neil holmes's gear list
Panasonic Lumix DMC-GX7 Sony Alpha 7 Sony Alpha 7S Canon EF 135mm f/2.0L USM Canon TS-E 17mm f/4L +9 more
dbm305
Senior MemberPosts: 1,365Gear list
It's only rangefinder wide angles that don't work well on most digital sensors including the A series (especially symmetical designs)
These Canon zooms will work as well (modulo slower autofocus) as they do on Canon.
However neither is blazingly sharp, if that's what floats your boat: especially in the corners (I only really mention this because the FEzoom has disappointed you)
It floats mine too, a bit. If you don't want to wait and see if the Zeiss wide zoom will be more like their primes and less like their normal zoom (which was constrained I think by the size and weight brief) then I'd go the distagon 21 or 252.5 FE for landscape (assuming the Canon TSEs are too pricey and to large)
 dbm305's gear list:dbm305's gear list
Sony RX100 Sony Alpha 7R II Canon EF 135mm f/2.0L USM Canon TS-E 17mm f/4L Voigtlander 75mm F1.8 Heliar Classic +14 more
KwhyChang
Veteran MemberPosts: 3,474Gear list
Ryan
www.LIFEofRI.com
I have had the 17-40 for just about 10 years. Used it on crop and FF Canon and now on Metabones III adapter. Although it's not as fast as the 16-35 II it is sharper and has a better range:
I usually put these on the 6D for highest ratings, but it came up this way.
A7 with Canon 17-40/4
The Metabones III adapter allows, exif info, IS, and control of aperture. AF is about 2 seconds.
Dave
 KwhyChang's gear list:KwhyChang's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha 7
RER220
RER220 OP
In reply to dbm305, Mar 29, 2014
thats for the input. When you say that the canon lenses aren't as sharp, do you mean on the a7 or generally speaking even on a canon?
you mention the distagon series, do you mean ZE and not FE series? cause they dont make 21mm primes.
RER220
RER220 OP
In reply to KwhyChang, Mar 29, 2014
Dave,
I had this lens and i sold it with the 6D when i switched to the A7. I am thinking about getting it again cause its cheaper and lighter.
KwhyChang
RER220 wrote:
Dave,
Just curious why you sold the 6D? I'm sure it does some things much better than the A7. I have a very old 5D.
Dave
RER220
RER220 OP
At this point in the game, all cameras do the same things now. I just wanted something smaller and lighter. The more convenient it is to bring around to take those shots.
DtEW
Senior MemberPosts: 2,123Gear list
Something else to consider are the Tokina 16-28mm f/2.8 and the 17-35mm f/4.  The former is better than either Canon L-glass you referenced, but it is quite heavy with a bulbous front element that will not take a filter easily.  The latter is more manageable in size/weight, can take a 82mm filter and is weather-sealed.  I can attest that the Tokina 17-36mm f/4 is built to a higher degree of burliness than my GF's EF 16-35mm f/2.8
The Tokina 17-35mm f/4 can be prone to purple CA at the edges in extreme DR conditions, which can be helped by stopping down to f/8.
 DtEW's gear list:DtEW's gear list
Canon EOS 6D Sony a6000 Samyang 14mm F2.8 IF ED MC Aspherical Samyang 24mm f/1.4 ED AS UMC Sony E 50mm F1.8 OSS +15 more
KwhyChang
Agree.
Here is a test I did with the A7 and the Canon 24/2.8 IS. It's much smaller, lighter, and a better choice for IQ than the 17-40. I really enjoy this combo:
http://www.dpreview.com/forums/post/52781113
Dave
RER220
RER220 OP
Good callout, ever since i had the prime FE lenses I've been learning to shoot more like a prime user than a zoom user. Im just sometimes concern that 24mm is not wide enough and if i got a a wide angle prime that it would not get used enough, but the 24mm prime is a good alt. I wonder how the 24L does on the A7?
NomadMark
Contributing MemberPosts: 556Gear list
The 24L is a nice lens, but it's heavy and large. And you'll likely never shoot it at 1.4 anyway in most cases if you are a landscape shooter. Nice for low light action, and night shots, but in my opinion it's not the best paring for the A7's. If you want ultimate image quality, the 24mm TS-E is the way to go. If you want good portability and a light package at 24mm, the 24mm IS USM is very hard to beat. L lens image quality, in a tight little package. I prefer it to both 24mm L and the TS-E in most cases.
Many people complain about edge quality of the 24-70 FE at 24. Canon's ultra wide angle lenses don't do any better at their respective wide ends, but weak corners are a common characteristic in most UWA lenses, unless you get into primes.
I have not used my 17-40 on my A7r yet for much, but the corners were not stellar on my 5Dmk2. Didn't stop me from making good images though, at least in my perspective anyway. Too many people focus just on sharpness alone. The picture below was taken at f22, to get the longest shutter speed possible to smooth the water out but this limits the sharpness a tad because of diffraction. Its sharp enough for me, however and the content was more to my liking. I am very happy with the 17-40 myself. Supposed to be sharper than the 16-35 as well. I like it because it's weather sealed and light. And for a UWA zoom, it's good. Though from reading a lot of posts in this Sony NEX/Alpha form, it would probably fall well below most people standards!
snug Harbor
 NomadMark's gear list:NomadMark's gear list
Sony RX1R Sony Alpha 7R Canon EF 50mm f/1.2L USM Canon EF 400mm f/5.6L USM Canon EF 17-40mm f/4.0L USM +8 more
RER220
RER220 OP
In reply to NomadMark, Mar 30, 2014
I think I'm going to go with the 24mm IS. I loved my 17-40mm/6D combo and the IQ and corners were good enough for me, but do sony users complain cause they are using UWA on the adapters there for causing soft corners or they are just snobs? Can a7 truly bring out the native performance on some lenses anyway
Steven-T
Veteran MemberPosts: 3,316Gear list
In reply to RER220, Mar 30, 2014
Ryan
www.LIFEofRI.com
I have the 16-35/2.8L (Mark I), about the same footprint as the 17-40/4L. It performs "reasonable" on my A7R.  For landscape, one can't beat a TS-E lens (I use the 17TSE for both landscape and architecture, but they are not my main interests.)
Steven
 Steven-T's gear list:Steven-T's gear list
Leica M9 Panasonic Lumix DMC-GH4 Sony Alpha 7R II +6 more
