Are you worried about light leak in your X-T1?
Started Mar 26, 2014 | Discussions
photo perzon
Veteran MemberPosts: 4,032Gear list
Mar 26, 2014
Seems like best left alone, no?
 photo perzon's gear list:photo perzon's gear list
Sony Cyber-shot DSC-RX100 III Olympus PEN E-PL5 Fujifilm X-A1 Panasonic Lumix DMC-GM1
Fujifilm X-T1
slimandy
Forum ProPosts: 15,880Gear list
Re: Are you worried about light leak in your X-T1?
In reply to photo perzon, Mar 26, 2014
I checked mine with a torch and it's fine so I'm no longer worried.
If I was I would send it back to Fuji as I am assured their customer service is second to none.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Olympus OM-D E-M5 Fujifilm X-E1 +1 more
jimbofoxman
Regular MemberPosts: 453Gear list
I'm not worried about it, but I will probably still send it in anyway since I still have my Canon stuff to shoot with in it's absence.  To me people aren't happy unless they have something to bitch about.  Quit shinning a fricken light in there!  Same thing with the 4 way control pad on the back.  I don't see anything wrong with it...but maybe it's because I have basketball fingers and not sausages for fingers.
 jimbofoxman's gear list:jimbofoxman's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
unknown member
(unknown member)
I am not the least bit worried.
  • The problem only exists for very long shutter times, which I don't use. The compartment access door is sealed so even in extremely bright light with normal shutter times the problem is negligible.
  • If I did need very long shutter times, I would need a tripod. When the camera is on a tripod, and when the access door must be open I could drape a black cloth over the remote cord/compartment. Many experienced photographers who use very long shutter times cover their cameras with a black cloth anyway.
  • Fujifilm will fix the problem.
I will get my body fixed eventually, but I'm in no rush to do it.
 wchutt's gear list:wchutt's gear list
Fujifilm X-Pro1 Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +20 more
Ray Sachs
Forum ProPosts: 10,335Gear list
In reply to jimbofoxman, Mar 26, 2014
Shine the damn light in there. At least you'll know if you have the issue. If you don't all is good. If you do, you have to decide whether to send it in or not. If you don't do long exposures with a remote, you'd probably never have the door open in a situation where it would come into play so you might decide not to. OTOH, if you have the problem, you're probably better off sending it in for the repair so that if you try to sell the camera later, you can honestly say it doesn't have the problem. In addition to which, some folks who send it in seem to find that the feel of the four way controller has improved when they get it back - that's a bigger deal to some than others, but again not a bad thing to have had done when it comes to selling the camera down the road. OTOH, if you plan to keep it forever, no need to worry.
I shone the light in there. I didn't have a problem. But I'm glad I checked. Now I'll never give it another thought...
-Ray
We judge photographers by the photographs we see. We judge cameras by the photographs we miss - Haim Zamir
http://www.flickr.com/photos/20889767@N05/
darngooddesign
Senior MemberPosts: 3,963Gear list
Fuji is doing a good job of fixing the issue, why would you leave it alone?
 darngooddesign's gear list:darngooddesign's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
wooly1
Junior MemberPosts: 38Gear list
In reply to wchutt, Mar 26, 2014
You do not need long shutter times or bright lights to see if you have the light leak, with mine you left the lens cap on , opened the side door and in normal daylight inside my office without any lights turned on, the purple intrusion was quarter way across the screen - If you have got it -you have got it. Mine has just been returned by Fuji UK, full return time 8 days which I thought was excellent plus they sent the packaging and paid for the postage, I couldn't ask for more.
I know these are retro cameras but I didn't think this extended as far as using the black cloth draped over your head, Fuji should supply one in the kit!! Where's their telephone number again!
 wooly1's gear list:wooly1's gear list
Fujifilm X-T1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
CrazyCanuk
Regular MemberPosts: 282Gear list
In reply to wooly1, Mar 26, 2014
What do you think the lens cloth pouches are for ?
cyip0
Regular MemberPosts: 219Gear list
I haven't bothered checking mine. My X-T1's serial number is in the range. I will eventually send it in but I'm not in a rush as I'm still enjoying the camera.
 cyip0's gear list:cyip0's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Fujifilm X-E1 Sony Alpha NEX-6 +11 more
Birddogman
Senior MemberPosts: 1,614Gear list
My TX1 - SN: 27XX has the issue, big time.  I'm not "worried" about it because I don't (or at least have not yet) done the sorts of photography with the camera where the light leak becomes a problem.  Nor, am I especially concerned about the effect of the problem on resale value, because it is very rare I sell camera equipment.
However, I did buy and pay for a product without manufacturing defects and that's not what I got (an honest error for sure, but still a significant defect).  Also, I buy through Amazon because they stand behind what they sell. I've bought tons of stuff through Amazon (when you live in the sticks, mail order is how one shops), but have never returned or exchanged anything before.  Nonetheless, the ability to do that if there is a problem is part of what I pay for with Amazon.
Therefore, I have commenced the exchange process with Amazon.  I am hoping to get the new body (hopefully not in the affected serial number range) before I must send in my existing TX1 body in late April.  That way I won't be without the use of the camera (I hope).
 Birddogman's gear list:Birddogman's gear list
Sony RX1R II Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
baobob
Veteran MemberPosts: 6,959Gear list
Mine had a very important leak which was viisible in my living room with the door open to operate the RR 9 USB distant shutte rrelease
See my post http://www.dpreview.com/forums/post/53383637 It's so easy to have it fixed  that this should not prevent to have it done
Whe you want in 2 years to sell the cam, potential buyers could argue about it
If you think either your's has a minute leak and or you willnever open the door you might want just to ignore the fix.
Fujifilm FinePix X100 Sony RX100 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +7 more
baobob
In reply to Birddogman, Mar 26, 2014
4 days here to fix it !
I have excatly your position : I pais to have a camera fully functional and i douse the camera with the shutter release hiding it behind the window and shooting brsts at birds eating in the garden plus other training such tilt and shift nature morte
So I was quite motivated
Once again Fuji was excellent to cope with the issue.
rjx
rjx
Contributing MemberPosts: 908Gear list
Hopefully it works out for you
Sounds like it would have been easier to have Fuji send you a box to ship the XT1 in and knowing for sure your camera won't have the defect when it returns. Instead of having Amazon go through the trouble of sending you another one and crossing your fingers that it doesn't have a light leak issue.
 rjx's gear list:rjx's gear list
Sony Alpha 7 II Sony FE 28mm F2 +1 more
baobob
Re: Hopefully it works out for you
In reply to rjx, Mar 26, 2014
This is why I just Fuji's  I just followed Fuji's process for the fixprepaid parcel and an overal 4 working days duration quite acceptable IMHO !
SaltLakeGuy
Forum ProPosts: 10,901Gear list
Not really worried
but figure if I'm going to own a camera that meets all it's specifications correctly it should have the shield in place. If not for me a future owner, as is most often the case, when a X-T2 comes out or equivalent, I'll sell this one for top dollar (as my gear is always kept like new, and yeah I USE it not ABUSE it) so it makes sense to have it fully up to date firmware and hardware wise. I just sent mine off yesterday by the way for the fix.
Fuji X-T1 Camera, Fuji 18-55 f2.8-f4 Lens, Fuji 55-200 f4-f5.6 Lens, Fuji 23mm f1.4 Lens, Fuji 56mm f1.2R Lens, Fuji EF-42 Flash, Picturecode PhotoNinja
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-240mm F3.5-6.3 OSS +1 more
Digital Shutterbug
Senior MemberPosts: 2,076Gear list
It's unlikely to be a problem. Amazon replaced mine a couple of weeks ago. Not because of the light leak, which it had, but due to a problem with shutter speed. They had to delay the shipment for 24 hours while waiting on new stock to arrive. The new one they shipped me was well beyond the serial number range Fuji said was defective. And, it is light leak free. Anything Amazon gets at this point will be fine.
I'll toot Amazon's horn. Their service was outstanding. They shipped the new camera before they received the defective camera. In fact, I could have kept the defective camera until receiving the replacement unit. They reimbursed me for the return shipping cost. I had paid for overnight shipping on the original order. They sent the replacement camera to me overnight as well. I received several emails from their customer service representative that handled my case. She was in touch at every point. I could not have been happier.
Steve
WT Jones
Senior MemberPosts: 2,491
Mine has the leak & I am not the least bit worried about it, but since Fuji is taking high road & not dragging out the process or making excuses. (like some other companies, both photographic & not).  I am going to send it in for repair.
I spoke with them today & they put me in the system to get fixed. They said they will be sending me an email in a few days & a FedEx label to send it in. I assume they are spacing things out so they can get the repairs done in a timely manner & not have a backlog. I did not ask him why or how. He simply said they were fixing them.
All of this is fine with me, I have other cameras. I might add the representative was polite, professional, was truly interested in making sure my camera got repaired and that I was happy.
Warren
unknown member
(unknown member)
Leaving the lens cap on is nonsense. No rational person would do that.
The black cloth solution is a temporary fix. Using extremely long shutter times requires techniques (besides light-leak protection) that are irrelevant otherwise.
Red G8R
Senior MemberPosts: 1,720Gear list
I haven't checked and I don't care. But I will send it in for service before the two year warranty is up.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Nikon D600 Fujifilm X-T1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +11 more
photo perzon
I'm worried about the USA technicians
80 seals, electronics all over, 2000 parts, and a tecnician making $ 20 an hour in the USA in there?
They could do more harm than good in a complicated camera
Seems to me the only place to truly get in and out there is Japan.
For me it is to ignore it or to replace it.
