sRAW samples anyone?
Started Mar 25, 2014 | Discussions
Kuvasauna Contributing Member • Posts: 771
Would anyone care to put some D4s sRAW samples available to download? Playing with samples would help to understand what are the limitations of sRAW format.
'Anyone who believes exponential growth can go on forever in a finite world is either a madman or an economist.'
Nikon D4S
crosstype Regular Member • Posts: 179
Re: sRAW samples anyone?
I remember that the resolution is reduced by 75% and the maximum number of continuous shots is reduced by 50%, but the file size is only reduced by 25% or so, so it looks like something completely useless to me.
 crosstype's gear list:crosstype's gear list
Sony Alpha 7S Nikon D810A Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G +1 more
InTheMist
InTheMist Senior Member • Posts: 3,077
Id like to see some to.
It's more important how an image looks as a thumbnail than how it looks at 100%.
http://inthemistphoto.com
 InTheMist's gear list:InTheMist's gear list
Leica M Monochrom (Typ 246) Leica M-Monochrom Nikon 1 AW1 Nikon Df Nikon D810 +18 more
Kuvasauna OP Contributing Member • Posts: 771
Anyone? n/t
Joesiv Veteran Member • Posts: 5,497
I'm very interested in seeing some files too, preferably an a/b comparison sRAW and full sized.  I'm hoping the pliability is similar, if so, seems like a great option to save card/disk space for less critical shoots.
Cloverdale, B.C., Canada
http://www.joesiv.com
 Joesiv's gear list:Joesiv's gear list
Nikon D700 Olympus E-510 Nikon D600 Nikon D750 Nikon AF-S Nikkor 50mm f/1.4G +7 more
InTheMist
Bump for sRAW samples!
noirdesir Forum Pro • Posts: 12,418
12-bit lossy compressed 'sRAW' 2464 x 1640: 13.1 MB
12-bit lossy compressed RAW 4928 × 3280: 14.1 MB
So much for saving any meaningful space by using sRAW.
Jack Hogan Veteran Member • Posts: 5,152
Right. And my guess is that comparing the ratio of the information content to the ratio of the file sizes favors lossy compressed RAW.  I wonder why they do not have a losslessly compressed lossy compressed RAW format
Could someone with D4s post a sRAW sample for us to download please? It would be very interesting now that we speculate D800 update.
ImageAmateur Senior Member • Posts: 3,667
Unless there is some particular data stream effect that causes shooting and record speed to dramatically improve due to sRAW, does now look like a bit of a gimmick, as no 'real' recording space saved, even with lost data.
Wishing You Good Light.
 ImageAmateur's gear list:ImageAmateur's gear list
Phase One Capture One Pro
michaeladawson Veteran Member • Posts: 9,306
I don't really need an sRAW file to play with.  Unless I took the shot and had RAW files for comparison it wouldn't do much for me.
But I would like to know what white balance controls are available in post processing software like Adobe ACR and Lightroom and how much highlight recovery is available.
Is the white balance control in ACR reduced to the same +/- slider that you get for JPEG?  Without any ability to choose sun, shade, flash, etc. or dial in a Kelvin value?  Is the ability to recover much in the way of highlights reduced to what you get with JPEG?
If so then I really don't see a lot of utility for sRAW.  People talk about it being great for event photographers who need to process thousands of images quickly.  But if the WB controls in ACR are just like for JPEG then I think you lose a lot of flexibility.  If you want to adjust WB across thousands of files in post then you won't be able to shoot in auto-WB.  I don't use AWB so it's not an issue for me but I suspect it would be for many event shooters.
I've not seen this specific question asked or answered before.  Does anyone know?
Mike Dawson
 michaeladawson's gear list:michaeladawson's gear list
Panasonic Lumix DMC-LX3 Nikon D200 Nikon D4 Nikon D800 Nikon D800E +21 more
Jim Keye Senior Member • Posts: 1,817
According to rawdigger:
  • It contains YCbCR data much like JPEG, not RGB data
  • The data is 11-bit
  • The tone curve is applied to the data
  • The in-camera white balance is applied to the data
  • The pixel count is 25% of regular NEF files
  • The color information is shared between two adjacent pixels (in other words, chroma is recorded for every other pixel)
  • The file size is insignificantly smaller than full resolution 12-bit lossy compressed NEF
  • Compared to a regular NEFs the data needs additional processing (linearization) while converting it to a TIF/JPEG; that may cause additional problems during the conversion as well as some additional computational errors
  • There is some loss of color accuracy in shadows, which negatively affects the usable dynamic range if color accuracy is important.
So...the D800/E. It has or shares the highest pixel count of any DSLR and can potentially capture more information/resolution than any other on the market. And then doing the above to that information is "interesting"? Seriously?
Iliah Borg Forum Pro • Posts: 19,266
Thank You (nt)
Thank you
