How to come back to customized way d600
Started Mar 25, 2014 | Questions
Renato Mozzarella Junior Member • Posts: 49
IHi,
I switched my d600 to U1 or U2  and now switching again is not bringing back my customized functions as the af-on button.
Thanks!
Nikon D600
Renato Mozzarella OP Junior Member • Posts: 49
Re: How to come back to customized way d600
The question:
How can I get it back??
Nevermind
I turned the camera off switched the ring and turned it on again, it worked then.
Thanks anyway
MRM4350
MRM4350 Senior Member • Posts: 1,921
I'm going to assume that you did not save the settings. Here is how I set up the U1/2 modes. With the camera in S mode I set auto ISO, AF On using the AF/AE button, and Easy Exposure Compensation. Then in the 'Setup Menu' I 'Save User Settings' to U1. Then I set the camera to 'A' mode, and in the 'Setup Menu' I save to U2. I usually shoot in M mode with no auto settings other than auto focus, so when I need the camera to respond quickly I can select either Shutter Priority with U1, or Aperture Priority with U2.
You do not need to be in one of the U modes to set it up.
 MRM4350's gear list:MRM4350's gear list
Nikon D90 Nikon D7000 Nikon Df
