Setting the INTERVAL TIMER on a D800.....
Started Mar 25, 2014 | Discussions
JP Scherrer
JP Scherrer Veteran Member • Posts: 9,929
I needed to use my D800 Interval Timer function, but it seems that there's a problem !
As the procedure looks rather complicated, I checked the D800 Manual and, better IMO, the Thom Hogan D800 Guide !
I followed the procedure as described: I went to SHOOTING MENU > INTERVAL TIMER SHOOTING.
I first moved the Direction Pad (from now on called DP) to NOW, then used the UP/DOWN DP to go to the Interval time, set the time between shots. As I wanted to use 30" sec. shots, I set the interval to 32" sec., to leave enough time for the camera to compute the image.
Then I used the RIGHT side of the DP to go to the next entry screen. There I set 999 - 1 and got = 0999, to ensure a maximum of shots ! Finally, I pressed again the RIGHT side of the DP to continue...
The system got back to the START screen, where I pressed the UP/DOWN DP to chose ON ! ...but nothing happened: I just can't get the selection to move from OFF to ON !
I tried to vary the figures in the different choices, but in the end, the results were allways the same: I just can't get the damn selection to move up !
Here's some images of the different steps:
The following images have been shot with a Nikon V1 + Nikkor VR 10-100 f/4.5-5.6 (non-PD)
Have I been doing something wrong or is my D800 faulty ?
Please help.......
Thanks in advance !
J-P.
Photo Galleries at http://www.pbase.com/scherrer
Spherical Panoramas (360x180 degrees) at http://www.360cities.net/profile/jps
Equipment list in profile
 JP Scherrer's gear list:JP Scherrer's gear list
Nikon 1 V1 Nikon 1 J1 Nikon D800 Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
Nikon 1 V1 Nikon D800
mathi_vadhanan
mathi_vadhanan Forum Member • Posts: 59
Re: Setting the INTERVAL TIMER on a D800.....
Release mode is in something other than single-shot.
 mathi_vadhanan's gear list:mathi_vadhanan's gear list
Nikon D800 Sony Alpha 7 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-Nikkor 80-200mm f/2.8D ED Voigtlander 40mm F1.4 Nokton Classic +6 more
JP Scherrer
JP Scherrer OP Veteran Member • Posts: 9,929
@ mathi_vadhanan !
No, it isn't !
J-P.
Joshua Chung New Member • Posts: 14
Re: @ mathi_vadhanan !
Enough space for 999 pics in the card(s)?
Nikon Shooter
 Joshua Chung's gear list:Joshua Chung's gear list
Nikon Coolpix 3700 Nikon Coolpix AW110 Nikon D800E Nikon D4S Nikon AF-S Nikkor 24-70mm f/2.8G ED +35 more
LBlack Regular Member • Posts: 141
My Df does the same if no memory card is installed. Your D800 has 2 slots so it may behave differently.
Janoch
Janoch Senior Member • Posts: 2,307
Very clever of you not to show the release mode dial!
My bets are on, that you're in self-timer mode?
 Janoch's gear list:Janoch's gear list
Nikon D800 Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm f/4G ED VR +2 more
JP Scherrer
Re:Re: @ mathi_vadhanan !
Nikon Shooter
Yes, as I have 1 32 Go SD card PLUS 1 32 Go CF card in the D800 ! That should do, isn't it ?
J-P.
JP Scherrer
@ LBlack !
Indeed, I have 1 32Go. SD card + 1 32 Go.CF card in the D800 !
J-P.
JP Scherrer
@ Janoch !
Very clever of you to have noticed that I purposely hidden the release mode dial ! ...but I thought that it wasn't important !
...anyhow I can swear that the damn thing was set -of course- to Single Shot !
J-P.
tomnorth
tomnorth Contributing Member • Posts: 593
Did you change the video setting that turns the shutter release button into a video record button when pressed? If so, Interval shooting doesn't work. I found this out this past fall.
 tomnorth's gear list:tomnorth's gear list
Nikon D800 Nikon D4S Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 85mm f/1.8G +10 more
JP Scherrer
Thanks to mathi_vadhanan and tomnorth ! Problem solved !!!
Indeed it was one setting NORMALLY DEDICATED TO VIDEO, the G4, which was wrongly set and prevented moving the choice to ON !
WintrHawk wrote in https://www.flickr.com/groups/nikondigitallearningcenter/discuss/72157631681859954/ :
Are you also trying to do time-lapse? Also, what is your setting for CSM g4? See page 203 of the D800 User's Manual [EN].
Interval timer photography can not be combined with long time-exposures (bulb photography, pg 124) or time-lapse photography (pg 207) and is not available when Record movies is selected for Custom Setting g4 (Assign shutter button, pg 324).
I haven't noticed NOWHERE in the Nikon or Thom Hogan that one should set the damn G4 setting to "TAKE PHOTOS" !!! I don't even remember having changed this setting since I bought my D800, as I DO NOT SHOOT VIDEO !
Now, I set it correctly and..... miracle: it works ! The stupid ON thing is now avaliable !!!
...someone SHOULd write to Nikon AND to Thom Hogan and let them know about this unforgettable ommission !
...now I'm happy !!!
J-P.
Janoch
Re: Thanks to mathi_vadhanan and tomnorth ! Problem solved !!!
Okay, I owe you a beer then!
I checked later, and if you had indeed your dial set at any other setting, it would have shown in the the shots above. So my bad for not checking properly!
Page 203 clearly states "Interval timer... is not available, when record movies is selected for CS g4"...
Someone has to stand up for poor, innocent Nikon!
Happy shooting!
Robin Casady Forum Pro • Posts: 12,898
Something Else to Remember...
If your exposures are 30 sec. long and you have Long Exposure Noise Reduction turned on, your interval must be greater than 60 sec. It needs 30 sec. for the image exposure and 30 sec. for the dark frame exposure. Add a few sec. for other functions.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
luchs Regular Member • Posts: 177
They know about this firmware bug - and did not fix it.
BTW - with the G4 option changed to "Video" you can also NOT clean your sensor.
Since they have reintroduced the AF focus trap to D4 firmware, hopefully Nikon can do the same for the D800 and also fix this problem.
The G4 option should only make a difference if the LV mode was set to Video.
JP Scherrer
Happy shooting!
Oooops ! My bad ! Didn't notice that !
J-P.
JP Scherrer
@ luchs !
Let's hope Nikon includes these changes in a future update !
...but I highly doubt it, though !
J-P.
JP Scherrer
@ Robin Casady !
Robin Casady
—Mark Twain
Yep, Robin ! I knew that one ! Anyway, I never use those funky in-camera settings ! I'm from the old school and I like to control everything myself !
J-P.
afoton
afoton Senior Member • Posts: 1,044
Not an answer for what you ask for, but what you trying to do, is easier to do with a lockable cable release. Just set shutter speed and the camera on Continuous and lock the release, and a new exposure will start when the camera is ready after the previuos. And it will continue until the cards are full, battery is empty or you switch off the release.
JP Scherrer
@ afoton !
Hi !
Thanks for this other method ! Can you please explain the steps for "set shutter speed and the camera on Continuous and lock the release" ?
Setting shutter speed is OK, but how do I set the camera to "continuous" ? ...AND "lock the release" ?
TIA,
J-P.
afoton
Re: @ afoton !
Continuous as in C, and not S (singel). With 30s exposure time, you of course don't get 3 frames/second, but the next exposure start when the previous is finished.
Lock the release as in hold the trigger button down. But a lockable remote trigger has a locking function so you don't have to hold the trigger button down. The same locking function you would use if you use B (bulb) for long exposure.
