D600 Shutter Replacement <> Does anyone know why the shutter count is not reset?
Started Mar 22, 2014 | Discussions
Prime85 Senior Member • Posts: 1,009
Nikon D600
Fogsville Contributing Member • Posts: 577
Re: D600 Shutter Replacement <> Does anyone know why the shutter count is not reset?
I've had my D3s shutter replaced and Nikon did not reset the shutter count. Colleagues of mine who have had shutters replaced more than once (on the same cameras) have never had their shutters reset either (through NPS.) The shutter is only one mechanism that gets wear and the total shutter count is also an indication of overall use. But if you're concerned about this when selling the camera, just show the buyer the work order which will be dated as to when the shutter was replaced.
Otherwise, it can be kind of misleading as to overall camera usage to reset shutter counts. It's somewhat like resetting the odometer on a car. Normally you'd tell the buyer the miles on the chassis and also the miles on the new engine.
Anyway, this question was asked several years ago http://www.dpreview.com/forums/thread/2681063  (read to the very end for the most current responses.)
T O Shooter Senior Member • Posts: 5,026
In a recent thread on shutter count resets, a couple of fellows pointed out that Nikon now has a policy not to reset. Think this was USA but might be everywhere.
Photography - It's a passion No other reason required.
 T O Shooter's gear list:T O Shooter's gear list
Canon PowerShot G5 Nikon D4 Nikon D810
arrr
arrr Senior Member • Posts: 1,735
Why not ask them to RESET the shutter when sending it in? Seriously put it in the instructions and threaten to send it back to them if it wasn't done. New shutter = zeroed shutter count IMO. Maybe they didn't replace the shutter?
 arrr's gear list:arrr's gear list
Nikon D5200 Nikon D610 Nikon D810 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF Nikkor 50mm f/1.8D +6 more
lickity split
lickity split Senior Member • Posts: 2,635
If your 2012 BMW with 450,000 miles on the odometer had it's motor replaced by BMW,will they reset your odometer to ZERO??  NOPE
When it's said like this it's easy to understand why they don't....
Sounds a bit illegal also.
 lickity split's gear list:lickity split's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +10 more
Red G8R
Red G8R Senior Member • Posts: 1,726
Why should it matter. All that matters for resale would be proof that the shutter was replaced and when.
I do not think it should be reset and I'm glad Nikon Canada didn't.
Peter
Ontario, Canada
 Red G8R's gear list:Red G8R's gear list
Nikon D4 Fujifilm X-T1 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +11 more
