Nikon D610 JPEG rendering
Started Mar 22, 2014 | Questions
SL98 New Member • Posts: 2
I noticed that when I shoot RAW+JPEG on my D610 on high ISOs, the JPEGs come out with this super odd, blocky, chromatic noise that the RAWs don't have. It happens whether I have in-camera High ISO noise reduction on or off. The JPEG settings are at their highest; 'FINE' and 'Optimal Quality.' anyone else noticed this on theirs?
JPG @ ISO 25600
RAW @ ISO 25600
JPG @ ISO 6400
RAW @ ISO 6400
Nikon D610
webfrasse Veteran Member • Posts: 3,857
Re: Nikon D610 JPEG rendering
How do you process the raw files?
Mikael
VicC Senior Member • Posts: 1,557
That's why we use and process Raw files our selves. Vic
SL98 OP New Member • Posts: 2
Well yes, that's why I shoot RAW most of the time (I use ACR for processing). But sometimes I have no choice but to shoot JPEG, and this seems way worse than it should be; even without processing there is still a distinction! At high ISOs, the JPEGs show up with the green and purple noise that the RAWs never have.
DezM
DezM Forum Pro • Posts: 34,281
Exactly
Did you try to correct that in the camera settings somehow? To little details here to have any opinion...
Mikael
(unknown member) Veteran Member • Posts: 3,441
Probably a hot/unshielded Chip in the Camera there add this "blocky noise" when the RAW is reduced to the JPEG.
ZAnton Contributing Member • Posts: 589
I almost never shoot in JPEG.
That is why I had bought a DSLR.
Also Nikon is not very good at in-camera jpeg processing. Well, imho only Canon is really good at it, Oly is between Canon and the rest.
The rest - Nikon, Sony, Pana - are OK moderate ISOs, but when serious NR/color correction is required, they are quite bad.
But, as I said, all this irrelevant to me, as I always shoot raw and advise you to do so either.
At high ISO, raw is a MUST.
I had made a test shot at ISO 25600.
LR4 has default NR:
Luminance 0.
Color 25.
If I set Color to 0, I see no difference to RAW except for the JPEG compression artifacts, which is totally OK for a random noise.
Setting Color NR to 25 in LR makes dramatic difference.
 ZAnton's gear list:ZAnton's gear list
Nikon D600 Tamron SP 70-300mm F/4-5.6 Di VC USD Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G Tamron SP 24-70mm F2.8 Di VC USD
olyflyer
olyflyer Forum Pro • Posts: 23,914
No, it is a typical Nikon noise. Same in the D300s and the V1 also. It is the color moire typical for Nikon, and it is a shame that Nikon does not manage to take care of that in the camera and force us to use raw and work extra just to get rid of the ugly yellow/green cast.
olyflyer
This is typical for Nikon. I can not for my life understand why they can't clean the files better in the camera. It is the color moire you see, it is fairly easy to get rid of it but you need to shoot raw. Same in every Nikon camera I know, you can also see it in the DPR sample images. Shame on Nikon for not handling this fairly simple issue correctly in the camera.
sandy b
sandy b Veteran Member • Posts: 8,171
This is 25600, 6400
Very high ISO, I believe your raw files are being cleaned by ACR, Nikon in camera NR is on the conservative side, I prefer that rather than plastic over processed files, also when printed these would probably be ok, especially the 6400.
 sandy b's gear list:sandy b's gear list
Nikon Coolpix A Nikon 1 J1 Nikon D7100 Nikon D750 Nikon AF-S Teleconverter TC-14E II +8 more
