>>> Challenge #187: Voting Open <<<
Started Mar 21, 2014 | Discussions
Dan Wolf Senior Member • Posts: 2,671
Voting is open in FujiMugs Challenge #187: Selective Colour.
To vote or view entries, go to:
http://www.fujimugs.com/challenge
Voting will continue through Monday, March 24, 23:59:59 (GMT).
You can download the Challenge entries and select your Favorites and vote offline! Go to the Challenge page (shown above) and click the 'Offline Voting' button, or click the links below:
Main category:
http://www.fujimugs.com/challenge/offline_0187/FujiMugs_challenge_0187_Main.zip
Open category:
http://www.fujimugs.com/challenge/offline_0187/FujiMugs_challenge_0187_Open.zip
PAUL TILL
PAUL TILL Veteran Member • Posts: 9,285
Re: >>> Challenge #187: Voting Open <<<
I can only find 3 images worth adding to my favourites in the main..! Dan, you really aught to drop the minimum to 3 as those are the only places that matter really.
The 10% Rule:
You Must Be 10% Smarter Than The Equipment You're Operating
NPW UK
NPW UK Contributing Member • Posts: 695
Hi Paul,
I still don't think you get the voting on Fujimugs Paul (actually I think you probably do!). Just vote for the 10 least worse (yes terrible English), in decending order, as hardly any photos ever come up to your (overly) high voting standards.
Nice to see you back though
Neil.
 NPW UK's gear list:NPW UK's gear list
Fujifilm FinePix S100fs
PAUL TILL
My way would still work, you could still vote for 10 if you so wished, but you could also only vote for 3 or 5 if that's all you could pick.
Most of the time there a few really good entry's but I don't get to vote because I can't filter out the not so good. Bad is bad and I just switch off with those ones.
Just putting it out there.
The 10% Rule:
rd52
rd52 Regular Member • Posts: 244
I have been in Fujimugs for 10 years now. Even when there were many more participants, it seemed that there were always one, two, maybe three photos that were the class of the challenge. Then I would go through the rest and pick the pics that weren't as good, putting them in the order I felt they deserved. Often I have to look at the pictures quite a few times, often changing the order as I looked at them again and again. I don't feel that is to much effort, to look through the photos, and pick the order of ten in the order of what I feel they deserve.  If you can't pick ten worthy of your vote, the simple cure is don't vote.
rd52
As a side note, I don't hide my vote.  I don't vote anonymously you can see my votes.
