SX50 in manual mode
Started Mar 20, 2014 | Discussions
bill nu Junior Member • Posts: 34
SX50 in manual mode
My LED screen goes blank in Manual mode.  Is there a way to turn it on?
Dale Buhanan MOD Veteran Member • Posts: 3,996
Re: SX50 in manual mode
In manual mode, the screen shows what the actual exposure settings would produce.  The way to make it visible is to adjust the exposure to what the proper value would be for that light level.  It is dark for a reason, and that reason is that the shutter speed/aperture value set on the camera would underexpose.  Baffled me when I first got mine also... for a little while.  Likely, by the time you read this, you will have figured that out already.
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +34 more
bill nu OP Junior Member • Posts: 34
Thank you are right. I figured it out just before reading your reply. I am assuming in manual mode on the right vertical is the metering showing me under and over exposure?
