What advantage does the Rokinon 14mm have over the kit lens?
Started Mar 19, 2014 | Discussions
vjk2
Regular MemberPosts: 231
Mar 19, 2014
Just wondering if someone could clear it up for me.
Kit lens at widest is 18mm and f3.5, not too far from 14mm and f2.8, plus has autofocus and can accept filters.
Russell Evans
Forum ProPosts: 11,232
Re: What advantage does the Rokinon 14mm have over the kit lens?
In reply to vjk2, Mar 19, 2014
Field of view at the wide end is more dramatic than at the long end. The difference in the diagonal FOV of the 14mm to the 18mm is a little more than 14°, 77.4° vs 91.7°. For example if you have a subject distance of 10 feet, you will get 17 feet, 1.7 inches of horizontal scene with the 14mm. At 18mm you would only have 13 feet, 4 inches of the horizontal scene. Real world example; the average car is 16 feet, 4 inches, so at ten feet you would be able to get the whole car into the shot, and then some, with the 14mm, whereas with the 18mm, you probably would only be getting the car from the doors to the trunk in the shot.
Thank you
Russell
Petroglyph
Senior MemberPosts: 4,526Gear list
Cough sputter?    14mm on APS/C is in the UWA range and equiv to 21mm in 135 format.  18mm in APS/C is barely in the WA range and 27mm in 135 format.  The Rokinon is f/2.8 (and sharp as a tack already at that point) whereas the kit is f/3.5 and IQ might improve with stopping the lens down somewhat.  btw, I'll post some comparisons when I get a chance and I'm convinced folks will agree the prime will knock the shots "out of the park".  Oops I can't compare since I don't have my "kit lens" any more.
There is one big down side to the Rokinon and that is when trying to use a CPL.
Cheers.
 Petroglyph's gear list:Petroglyph's gear list
Pentax K-3 Sony Alpha 7 II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Sigma 35mm F1.4 DG HSM | A +3 more
JNR
JNR
Senior MemberPosts: 2,402Gear list
In reply to Petroglyph, Mar 19, 2014
I generally agree with the replies above. Optically, the Pentax kit is quite good, but it really improves once you get to about 21 or 24mm, and stopped down to around f/5.6. This distances a quality 14mm like the Samyang/Rokinon even further from the kit. Not that we are anticipating full frame digital for Pentax anytime soon, but the 14mm lens does cover it, so it can be shot on a film camera if one is so inclined.
I wonder why Samyang decided to release a 16mm lens for APSc. That differential from kit (or some very nice zooms that start at 16mm or 17mm) is more open to question.
As for the CPL issue, it is a concern, but not a huge factor. As you get so wide in perspective, polarization tends become rather spotty with the varying angle light paths. This can be harder to correct than the options available in post to enhance a non-polarized image lacking saturation. Although a CPL is your only real solution for extreme reflections (such as water surfaces).
JNR
www.jamesrobins.com
 JNR's gear list:JNR's gear list
Pentax K-3 Pentax smc DA 16-45mm F4 ED AL Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 XS Lens Pentax smc DA 50mm F1.8 +7 more
MightyMike
Forum ProPosts: 33,170
In the wide end 4mm is a big difference... sure the difference between 50 and 54mm isn't much but between 14 and 18mm its almost a different world (well maybe a bit of an exaggeration)...
Anyhow, the 14 is much sharper and 2/3rds of a stop faster, when its that wide AF is rarely necessary. Yes its larger, yes it can't easily take filters... However its the best 14mm lens on the market. BTW I don't own one.
One final note, it covers FF.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
MightyMike
In reply to JNR, Mar 19, 2014
The 16mm is an F2.0 lens a whole stop and more faster than any zoom that covers 16mm or close... excluding the Sigma 18-35mm F1.8
JNR
www.jamesrobins.com
Mike from Canada
JNR
JNR
In reply to MightyMike, Mar 19, 2014
No doubt about it, MM - the 16mm is unique, and will be especially attractive for shooters in the other mounts that don't have decent quality around the 24mm FF field of view. Pentax has the 15mm - which is a fine, but not fast, lens for the money. On the other hand, regarding the f/2, how much speed do you need in an UWA given the low light capabilities of current sensors?
And, as long as Samyang had decided that the company was going to offer a 10mm lens - it just seems to me that should have been more of a priority than getting the 16mm out first.
JNR
www.jamesrobins.com
Mike from Canada
JNR
www.jamesrobins.com
MightyMike
Personally i want to play with a 14mm F1.4 on FF really i see a use for it, for very wide field shallow DOF type photography
Wasn't the 10mm cancelled?
Also Keep in mind their next step is to offer AF
Mike from Canada
Russell Evans
If you buy a Sony Nex-3n for $299 and then buy a $120 focal reducer to use with the Samyang 14mm f2.8, that would net you a 10mm f2 in APS-C, FOV and DOF, terms, I think.
Thank you
Russell
MightyMike
In reply to Russell Evans, Mar 19, 2014
Thank you
Russell
Or just use the 14mm F2.8 on a FF camera for the exact same effect.
Mike from Canada
Russell Evans
Wake me when Pentax has a digital one of those, please.
Thank you
Russell
ozdean
Forum ProPosts: 22,451Gear list
Good analogies Russell.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
JNR
JNR
JNR wrote:
Pretty sure the 10mm is on the way - very soon. In the UK, they are taking pre-orders for delivery starting by the end of this month - including for Pentax (Sigma, are you taking any notice of the footsteps inching closer?).
Mike from Canada
JNR
www.jamesrobins.com
