Initialise your A7 prior to installing Firmware Update...
Started Mar 19, 2014 | Discussions
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Go to>Menu>Last Column (Travel Case/Brief)>Line 6>Setting Reset>Down to Initialize>Restore to default>OK...then install Firmware...
Initialise back to factory settings prior to installing Firmware and you will not have any issues...
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
Panasonic Lumix DMC-FZ50 Sony Alpha 7
RDMSguy Junior Member • Posts: 49
Re: Initialise your A7 prior to installing Firmware Update...
I did not do this and had no issues with the update.
Is there a reason to do this? Or a better safe than sorry sort of thing?
LTZ470
LTZ470 OP Forum Pro • Posts: 11,926
Mostly for folks that are struggling or getting abort error...
FlickR Photostream:
The Lotus Eater
The Lotus Eater Regular Member • Posts: 346
FlickR Photostream:
Is this official advice from Sony?
What reasons do you have to believe that this will eliminate any potential issues with the update?  I'd much rather not have to reset to factory settings.
 The Lotus Eater's gear list:The Lotus Eater's gear list
Sony Alpha DSLR-A700 Sony Alpha NEX-6 Sony Alpha 7 Sony Alpha 7 II Sigma 30mm F2.8 EX DN +5 more
stevo23 Forum Pro • Posts: 10,123
FlickR Photostream:
It didn't occur to me and mine worked fine, startup is very fast. Maybe others have had abort issues?
 stevo23's gear list:stevo23's gear list
Sony Alpha 7 Nikon AF Nikkor 20mm f/2.8D Tamron SP AF 90mm F/2.8 Di Macro Sony FE 35mm F2.8 Sony FE 55mm F1.8 +1 more
LTZ470
FlickR Photostream:
It's a free world, you can take advice or leave it, it is mainly for folks that have issues with aborting or uploading FW...
It happens on Sony's, Oly's and Panny's at times, reinitializing to factory settings will usually do the trick...
What setting do you think the camera is at, at the factory when they test the firmware update?
FlickR Photostream:
qianp2k Forum Pro • Posts: 10,350
Good advice.  I will record all changes from default.  Then do on that approach.
Is there a way to save all changes to SD card and to restore from card later that some cameras have that feature?
 qianp2k's gear list:qianp2k's gear list
Sony RX100 Canon EOS-1D Mark III Canon EOS 5D Mark II Canon EOS 5D Mark III Sony Alpha 7R +20 more
sean lancaster
sean lancaster Veteran Member • Posts: 6,735
Honestly, I expect them to smarter than just testing from a fresh camera. The last thing they need is for the update to fail for everyone because they only tested a clean camera.
 sean lancaster's gear list:sean lancaster's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony Alpha 7R II Voigtlander 35mm F1.2 Nokton Sony FE 55mm F1.8 +4 more
DOglesby New Member • Posts: 5
I read in a Thom Hogan review that you cannot save settings.
Doug Oglesby
 DOglesby's gear list:DOglesby's gear list
Nikon D800E Sony Alpha 7R Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Carl Zeiss Distagon T* 2,8/21 +5 more
LTZ470
I would say so as well, but a initialized camera is a sure bet...
FlickR Photostream:
LTZ470
Not that I know of, like some are saying you can do it with your custom sets, and it worked, if it doesn't then Initialize and retry...
FlickR Photostream:
FlickR Photostream:
Fair enough and thanks for the input. It doesn't sound like this is based on specific incidences for this camera at this time so much as a past track record.
le_alain Senior Member • Posts: 1,504
When you install the firmware, at step "11",
you are asked to
"reset device" and answer OK, so , no chose no ?
I did as it's written, "OK".
firmawre installed, camera off,  battery out, camera on, and I loose no settings !
 le_alain's gear list:le_alain's gear list
Epson R-D1 Sony Alpha 7S Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS
Petroglyph
Petroglyph Senior Member • Posts: 4,813
FlickR Photostream:
Let's see, follow Sony's instructions carefully or something I got from the forums?  For me, following the maker's instructions always worked best and I don't have to remember any camera settings from before = everything worked fine.  Thanks for the advice though.
Cheers.
 Petroglyph's gear list:Petroglyph's gear list
Pentax K-3 Sony Alpha 7R II Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +4 more
XPatPat New Member • Posts: 6
I had a few scary moments in the upgrade process.  On the initial attempt it aborted and after that it seemed the device was bricked.  A few aborted attempts later I realized that I had forgotten to remove the SD card. Once I removed that it worked without a hitch- I followed all of the other instructions from Sony exactly.
 XPatPat's gear list:XPatPat's gear list
Sony Alpha 7R Sony E 10-18mm F4 OSS Sony FE 55mm F1.8
