It's new A7 series firmware day! Where to look?
Started Mar 19, 2014 | Discussions
dbm305 Senior Member • Posts: 1,626
Well here in Oz, and therefore in Japan, it's 19 March. Midday.
Should be new firmware day! Where to look for it???
 dbm305's gear list:dbm305's gear list
Sony RX100 Sony Alpha 7R II Canon EF 135mm f/2.0L USM Canon TS-E 17mm f/4L Canon MP-E 65mm f/2.5 1-5x Macro +16 more
Sony Alpha 7
blue_skies
blue_skies Veteran Member • Posts: 9,646
Re: It's new A7 series firmware day! Where to look?
http://support.d-imaging.sony.co.jp/www/dslr/products/ilce-7/index.html
http://www.sony.ie/support/en/product/ILCE-7
www.sony.co.uk/support/en/product/ILCE-7
http://esupport.sony.com/US/p/model-home.pl?mdl=ILCE7&template_id=1&region_id=1&tab=download#/downloadTab
Search for ILCE7r similarly
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony Alpha 7 II Sony DT 18-55mm F3.5-5.6 SAM +33 more
Jabba23 Regular Member • Posts: 304
Still nothing and I've been looking since I got to work this morning.
You would think that when Sony Japan announces they would be working off their time zone.
Darren Krusi
 Jabba23's gear list:Jabba23's gear list
Sony Alpha NEX-5N Sony Alpha 7 Sony E 18-55mm F3.5-5.6 OSS Google Nexus 4 Google Nexus 7
martindesu
martindesu Senior Member • Posts: 1,245
Going by the Japanese working day, it'll probably drop at about 23:30 local time, in time for the last train.
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
Juha Kannisto Regular Member • Posts: 105
http://www.sony.jp/ichigan/update/index.html
Now seems to be found there.
 Juha Kannisto's gear list:Juha Kannisto's gear list
Sony Alpha NEX-6 Sony Alpha 7R Sony Alpha 7 II Voigtlander 35mm F1.2 Nokton Sony E 16-50mm F3.5-5.6 PZ OSS +41 more
martindesu
Thanks Juha
polara New Member • Posts: 5
Tuloom Senior Member • Posts: 1,805
No details on the image quality enhancement. Interesting.
dbm305 OP Senior Member • Posts: 1,626
Thanks! And all installed. The installer was in English despite coming from the Japanese site!
All works, and all my settings are preserved.
Dandrewk Senior Member • Posts: 1,094
So how about one of our Asian friends installing the update and reporting back?
 Dandrewk's gear list:Dandrewk's gear list
Sony RX1R II Sony Alpha 7R II Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 90mm F2.8 macro +7 more
You can safely install it from the Japanese site; I just did. Of course above there is a link to the Australian site if you are worried!
Nicklau81 Junior Member • Posts: 41
any good things you notice after the upgrade i.e image quality as stated initially?
robert614 Senior Member • Posts: 1,322
Startup time is faster than before with new firmware
I just updated the firmware on my A7.The startup time has indeed been improved.
To early to reach any conclusions about IQ improvement.I'm assuming Sony is talking about IQ improvement for the jpeg engine.
Robert
File sizes about the same..
So I've shot a couple of frames.
The file sizes are about the same (37.5MB) so I doubt that lossless compression has been implemented. But I didn't expect that; the clamour for it started to late to have influenced Sony in time for this update.
It certainly starts up much faster. The focussing on the FE24-70 seems faster, but I may be kidding myself.
As I posted elsewhere, file sizes the same so RAW files likely the same (i.e. lossy compression, not that it matters much)
I don't shoot JPEG so I'll leave that to others to look at!
Definitely starts faster; maybe AF faster.
I thought the faster focusing was to take advantage of the feature for incoming lenses, notably the FE 70-200.  I took this to mean a focus distance limiter.
But I could be wrong.  Faster focusing would be a good thing.
Yes that was my guess too, so I could very well be kidding myself...it's hard to do an AB test when you only have one camera!
DonSantos Senior Member • Posts: 1,145
Af seems the same.
Start up to evf seems faster to me.  It used to bother me.  Now it's not instant but it's bearable
 DonSantos's gear list:DonSantos's gear list
Fujifilm X100S Nikon D600 Sony Alpha 7 Voigtlander 40mm F1.4 Nokton Classic Nikon AF-S Nikkor 50mm f/1.8G +3 more
abortabort Senior Member • Posts: 1,704
DonSantos wrote:
Af seems the same.
Yes definitely faster start up time.
I also used to find that the ISO dial (rear dial) would lock up on me and not be able to be changed while writing to the card which I used to find very very annoying. Now it seems to work just as you would expect it to, the other dials for Av and Tv always worked fine, but ISO used to just stop working for some inexplicable reason.
 abortabort's gear list:abortabort's gear list
Sony RX100 Fujifilm X100S Konica Minolta Maxxum 7D Leica M8 Nikon D700 +54 more
Richt2000 Senior Member • Posts: 2,900
abortabort wrote:
DonSantos wrote:
Af seems the same.
Really?!!?! Amazing - ISO dial delay was my biggest complaint of the camera!!!
 Richt2000's gear list:Richt2000's gear list
Sony RX100 Olympus OM-D E-M5 Sony Alpha 7R Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Canon EF 70-300mm f/4-5.6L IS USM +9 more
