XF 56mm ???
Started Mar 18, 2014 | Discussions
Mikess1
Mikess1 Contributing Member • Posts: 612
XF 56mm ???
Not only is it extremely slow to focus half the time I either get a red box or a green box but its still out of focus im confused after all the awesome reviews it got
http://500px.com/mikess1
 Mikess1's gear list:Mikess1's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR +1 more
mooshoepork Regular Member • Posts: 252
Re: XF 56mm ???
Minimum focusing distance is 70cm.
Are you keeping this in mind? Mine is snappy. No troubles at all.
Mikess1
Mikess1 OP Contributing Member • Posts: 612
Re: XF 56mm ???
Yeah I relize that even out side today in great light
ScottD1964 Senior Member • Posts: 1,324
Re: XF 56mm ???
Are you shooting in low light at high ISO where the camera uses CDAF or outdoors in brighter light where it uses PDAF?  Makes a huge difference In focus speed.
 ScottD1964's gear list:ScottD1964's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +3 more
Mikess1
Re: XF 56mm ???
Mikess1
Re: XF 56mm ???
Its much faster in good light but I still get the red box and the green box thats out of focus
Conrad567 Regular Member • Posts: 493
Re: XF 56mm ???
What camera are you using it on. If you are using it on an X-Pro1 or X-E1 or E2 you might need an update for the firmware on your body for the new lens.  If it is an X-T1 or you have the latest firmware...then something is wrong with your copy and send it back.  The 56mm is the fastest focusing XF lens.
 Conrad567's gear list:Conrad567's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 35mm f/1.4L USM Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +10 more
Mikess1
Re: XF 56mm ???
I have the XT1 and my xf35mm is way faster and more accurate
guitarjeff Senior Member • Posts: 1,146
Re: XF 56mm ???
It would help if you could post a photo with exif.  Also, close in objects with it wide open your dof is going to be very shallow, can you be sure you are not slightly moving forward or backward?
Mikess1
Re: XF 56mm ???
I get its shallow but I get the red box meaning it cant find something to focus on and even worse somtimes I get the green box on my subject and shes out of focus while the background is in focus
Mikess1
Re: XF 56mm ???
Mikess1
Re: XF 56mm ???
Mikess1
Re: XF 56mm ???
Both these pictures gave me the green focus box like this
Re: XF 56mm ???
Others will know much more than I on this, but it looks to me like you are moving in and out and altering your dof.  at 1.2 your dof must be very thin and especially when you are fairly close to the subject.
Shutter speed doesn't matter either because this type of movement is before the shutter even opens. and, and it looks as though focus is achieved but at the wrong distance.  You seem to be having no trouble with the 35 though, however that is at 1.4.  You may have to send it back but I would let a few more folks here comment on it and try and help before you go through sending it back.  If you bought it local then that would be much easier.
All I can do is say to you thaton my old 5D2, when using the Sigma 50mm 1.4 that dof was razor thin,and even if you felt only a barely conscious movement before the shutter fired the pic was oof.   The movement only had to be slightly perceptible and it would throw you out.
Good luck and I am sure you will get it worked out soon no matter what has to happen.
Mikess1
Re: XF 56mm ???
even before i take the picture i can clearly see it is focusing on the back ground and not the subject that is in the green box i only took it for this post i then refocused and took the other shot same everything only the subject in the green box was in focus i am taking my kids to the zoo today and will only be taking the 56mm i will figure out today if I'm gonna keep it or not a grand is a lot to spend you know right not i could get the 55-200 and the 14mm for just a little more then this lens but i love shooting portraits and 85mm is perfect
FJJ Regular Member • Posts: 117
Re: XF 56mm ???
I assume that you are using one shot AF and not continuous?  Have you tried reducing the size of the focus box to make it akin to 'spot af'?  One the X-E1 that is achieved by pressing the AF button to bring up the AF point selection grid then using the rear dial to increase/decrease the size.  Have you tried it on e.g. an eye which should be easier to focus on as there is a larger flat area than the sink and tap?  Other tip would be to make sure that you don't focus and recompose when shooting wide open as the DOF is very thin.
 FJJ's gear list:FJJ's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +9 more
Mikess1
Re: XF 56mm ???
yes one shot not continuos focus and i have changed the size i made it bigger cause this was happening and I'm not focusing and recomposing as i said i could clearly see it missing focus even before i take the shot
Chris Dodkin
Chris Dodkin MOD Veteran Member • Posts: 6,818
Shooting f/1.2 requires better technique
5
The challenge of shooting at f/1.2 - It's very difficult in a non controlled environment.
We will see dozens more posts on DPR in the coming months from people saying 'my new f/1.2 lens is faulty' etc etc due to soft/OOF images
A few technique suggestions:
Reduce the size of the AF box on the camera - to ensure you get exactly what you want in focus
Figure out the thing that's going to be sharp, the nose, eye, ear, etc - because most likely only one thing will be sharp!
Always put the AF box over the thing you want to be sharp by moving it's position before you shoot - using the old focus and recompose method will spoil most shallow DOF shots as the subject will no longer be in the focus plane after you recompose
Consider shooting f/1.4, f/1.6 or f/2 outside of the studio, You get the same sort of bokeh, better DOF, higher hit rate
Don't focus then pause before taking the shot - if you and/or the subject move at all in that pause, you're toast - do a test shot where you line up the AF box, frame comp and verticals etc - then for the actual shot just mash the shutter release so it does focus and immediate shot without any gap
Hope these help - technique with a longer fast prime is a killer
You'll need to practice, and practice, and practice
http://f-sunny.com
The future is just a click away...
 Chris Dodkin's gear list:Chris Dodkin's gear list
Fujifilm FinePix X100 Canon EOS-1D Canon EOS-1D Mark II Canon EOS 5D Mark II Canon EOS 30D +34 more
Mikess1
Re: Shooting f/1.2 requires better technique
http://f-sunny.com
thanks for your help i am not a professional or even close to it but i think i am experienced enough to know how to take a picture with a shallow dept of field i you look at my picture the green box saying focus is locked on the subject when its clearly focused on the background has nothing to do with me but the camera is missing the focus now when i refocused and took the same picture and nailed the focus how is this because of my lack of experience
jrk Senior Member • Posts: 1,853
http://f-sunny.com
Chris
Thanks for your professional advice.  I just received my 56 last night and am anxious to start using it.  I plan to get out this weekend in Annapolis and do some shooting with it.  I will certainly follow your suggestions.  I have a lot to learn and advice from professionals like yourself is always appreciated!
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Canon EOS 70D Fujifilm X-E2 Fujifilm X-T1 +12 more
