Silly question about aspect ratio - do you shoot 4:3 or 3:2?
Started Mar 17, 2014 | Discussions
jennajenna
Senior MemberPosts: 1,283
Mar 17, 2014
I have no idea why my gh3 was set on 3:2 (I normally shoot with the 7-14mm lens); but I was adjusting the settings and noticed that 4:3 files were 16mb and 3:2 were 14mb.
Is there any loss to shooting 4:3 over 3:2; it seems like a no brainer to shoot 4:3 and then crop..but I recall reading that shooting 3:2 actually gives you a "longer" horizontal image vs a 4:3...so you actually do miss some of the subject when shooting in 4:3...true?
http://digital-photography-school.com/aspect-ratio-what-it-is-and-why-it-matters
Panasonic Lumix DMC-GH3
markintosh13
Senior MemberPosts: 1,767
Re: Silly question about aspect ratio - do you shoot 4:3 or 3:2?
In reply to jennajenna, Mar 17, 2014
That image assumes you retain the vertical resolution - i.e. you're using a DSLR sensor in 4:3 crop mode.
With a 4:3 sensor - you'd end up chopping the top and the bottom off to maintain width.
This link shows the result of cropping a 4:3 shot various ways, as well as what gets cropped with photos taken with a 3:2 sensor:
http://tracy-larsen.com/blog/photo-tips-aspect-ratios-cropping/
ApertureAcolyte
Contributing MemberPosts: 994Gear list
No you don't lose anything with the native aspect ratio.
The diagram you posted is deliberately misleading.
If you crop to 3:2 on a 4:3 camera, you lose resolution.
4:3 is more efficient in using more of a lens' image circle
 ApertureAcolyte's gear list:ApertureAcolyte's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
Guy Parsons
Forum ProPosts: 22,727Gear list
Silly answer, I shoot 16:9
In reply to jennajenna, Mar 18, 2014
[image badly misleading in our context... deleted it]
Check out the pixel dimensions of your results at variously 4:3, 3:2 and 16:9 and see how on some Panasonic cameras the image gets wider as the tops and bottoms get cropped. My LX3 does that and probably your GH3?
Olympus and most other Panasonic just progressively crop the top and bottom to get the different aspect ratios and the width stays the same.
As the image is cropped there is a "loss" of megapixels but if the subject is the same size in the frame then there's no loss of resolution. Same "pixels per duck" so to speak.
In Olympus's case no matter what aspect ratio you shoot (or use 2x digital tele converter) then you always get the full 4:3 image in RAW. I take advantage of that on my E-PL5 by shooting 16:9 to get the biggest possible image on my LCD and then later use the 4:3 RAW to extract whatever I want from the image.
Regards..... Guy
Olympus PEN E-PL5 Olympus PEN E-P5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus 12-40mm F2.8 Panasonic Lumix DMC-LX3 +19 more
Desert Rose
Regular MemberPosts: 129
4:3 v. 3:2
In reply to Guy Parsons, Mar 18, 2014
The only problem I've encountered with 4:3 aspect ratio is printing 4x6's; especially if you don't have time to crop each one, something's gonna get lost.  That doesn't usually matter unless in the original image you've filled the entire frame with essential elements. You usually do lose something no matter which aspect ratio and print size you use. However, other than 4x6's the 4:3 ratio is closer to that of  most standard print sizes, e.g. 5x7, 8x10, 11x14, 16x20.
leafinsectman
Contributing MemberPosts: 763
Mostly 3:2 on my E-P3 to match the LCD aspect ratio but I switch to 4:3 when shooting raw or when shooting with an UWA lens.
3:2 or 16:9 on my GH1. I love the multi aspect ratio and I wish newer cameras would have it.
tomnorth
Contributing MemberPosts: 538Gear list
It's actually a good question
I've gone back and forth on this. I shoot both a D800 and a GH3. For that reason I started out with my GH3 at 3:2 to match my D800. Later I changed the GH3 to 4:3 to gain the extra resolution. I have just decided to back to 3:2 though. What drove this decision has to do with making large prints for a showing. Most of my shots were from my D800. I wanted the lone GH3 image in the group to look the same, so I had to crop it at a 3:2 aspect ratio. I use every bit of the viewfinder when composing an image. In this case what I lost at the top wasn't crucial, but it did make me realize that I'm better off composing in 3:2 if that's where the prints will end up. One side benefit of using the 3:2 aspect ratio on my GH3 is that the entire surface of the LCD and EVF is used.
 tomnorth's gear list:tomnorth's gear list
Nikon D800 Panasonic Lumix DMC-GH3 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 85mm f/1.8G +10 more
Elemental Photography
Contributing MemberPosts: 776Gear list
I shoot the native ratio of the sensor
Which is 4:3 for most current m4/3 bodies. If needed, I crop to the final ratio in post.
The GH1&2 had multi aspect ratio sensors so there was an advantage to choosing the appropriate ratio in camera. Aside from that, all you get is a cropped version anyway, so I capture what the sensor is capable of.
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic Lumix G 20mm F1.7 ASPH +7 more
Gregm61
Forum ProPosts: 14,414Gear list
4:3, 100% of the time. I rarely print, and when I do it's never using a 3:2 format size.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
 Gregm61's gear list:Gregm61's gear list
Leica M9 Olympus OM-D E-M5 Panasonic Lumix DMC-GX7 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +17 more
Klarno
Veteran MemberPosts: 4,067Gear list
I shoot the native aspect ratio of the sensor. If I need another aspect ratio, I crop in post. And I very rarely crop, except to do a square crop.
If the sensor has more than one native aspect ratio (the case in this system with only the Panasonic GH1 and GH2), then I choose the native aspect ratio that best fits the shot. Unless I'm using a two-camera setup. Then I'll choose whatever they have in common for the sake of visual consistency.
 Klarno's gear list:Klarno's gear list
Olympus PEN E-PM2 A3000 Olympus E-M1 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 II Olympus Zuiko Digital 11-22mm 1:2.8-3.5 +4 more
Vlad S
Veteran MemberPosts: 3,639Gear list
Shoot closest to display AR
Like tomnorth said, composing for one aspect ratio, and displaying at another can result in problems when cropping. I suggest you shoot in the ratio at which you are most likely to display the image. I print most of mine at 8x10, so 4:3 works for me better than 3:2, but if you print at 8x12, then 3:2 would be better.
Cropping in post only sounds like an easy solution, but in my experience if you like to frame tightly, it's too easy to loose important parts of the image.
Vlad
 Vlad S's gear list:Vlad S's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +2 more
Banger
Contributing MemberPosts: 592Gear list
I shoot both.....
I have my EP-3 & E-M1 set to 3:2 and to record jpeg & raw and therefore I frame the shot as 3:2 which is good for landscapes but useless for portraits where you want 3:4.
When PPing  with LR5.3  you can keep the 3.2 frame in raw or adjust it to better suit the composition or reset it to get all the 4:3 image data. This way I get to use the full lcd & evf screen to frame the shot.
Rgds, Rob
 Banger's gear list:Banger's gear list
Olympus E-30 Olympus PEN E-P3 Olympus E-M1 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +6 more
jalywol
Veteran MemberPosts: 7,042
I shoot only at 4:3.  I found, when I started using DSLRs, that I really disliked the 3:2 ratio, so I was pleasantly surprised when I got my first M43 camera that it seemed to see the way I did with its 4:3 sensor.
Once in a while I will play with a 1:1 crop in camera, but that's rare, and usually only when I am doing macro work with flowers, if at all.  Mostly I will crop later if necessary to get to a different aspect ratio if the image requires it.
-J
tanniewu
Regular MemberPosts: 256Gear list
Re: 4:3 v. 3:2
In reply to Desert Rose, Mar 18, 2014
nowadays printing shops can print 4D instead of 4R, which is 4" but in 4:3 format, which looks a lot larger than 4R and very satisfying
And ya I shoot 4:3 coz it makes use of the full resolution of the sensor, and I kinda feel that shooting 3:2, some of the image produced by the lens is "wasted"
TWu
E-M5, HLD-6, E-P5, GX1, XZ-1, XZ-2, TG-1, VF-3, VF-4, LVF2, FL-50R, FL-300R, FL-600R
9-18, 12-35, 12-50, 35-100, 14-140 II, 100-300, 17/1.8, 25/1.4, 45/1.8
Pentacon 50/1.8 (m42)
 tanniewu's gear list:tanniewu's gear list
Olympus XZ-1 Olympus XZ-2 iHS Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Olympus PEN E-P5 +14 more
Sergey_Green
Veteran MemberPosts: 8,861Gear list
Re: 4:3 v. 3:2
In reply to tanniewu, Mar 18, 2014
Resolution has no meaning if your framing is not what it should be. Most larger sensors have more pixels anyway, and cropping to a different formats is hardly a downside. It is the ratio or framing that one often feels more comfortable with (for a certain subject at least) than with what it would be (look like) if it were different.
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
Martin.au
Forum ProPosts: 10,080Gear list
I shoot 4:3.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
Paul De Bra
Forum ProPosts: 11,998Gear list
With your camera it's best to shoot 4:3 and then crop.
With the GH1 & 2 or any other camera with a multi-aspect-ratio sensor it makes sense to shoot 3:2 as it will use a larger horizontal part of the sensor (and a bit smaller vertical part) than when shooting 4:3. But on the GH3 and many other cameras the sensor really only does 4:3 and other aspect ratios mean cropping from that image. So on your camera you do not gain width by shooting 3:2 but you do lose height.
There is also a difference in what cameras save in a RAW image file. The cropping done by setting the aspect ratio may delete the unused pixels from the RAW file or may leave them in. When the unused data is left in the image (as with Olympus cameras) you could uncrop the image in post-processing if your RAW convertor allows it. (ACR and Lightroom for instance can do that with cameras introduced after the E-M5 (not including the E-M5 itself despite the data being in the files).
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
bluevellet
Senior MemberPosts: 2,221Gear list
In reply to leafinsectman, Mar 18, 2014
Same with me, though I also do prints and the stores in my area print in 3:2. I don't like letting them crop my pics so it's better to shoot them "right" to avoid me the hassle of cropping them afterwards.
 bluevellet's gear list:bluevellet's gear list
Nikon D600 Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Sigma 35mm F1.4 DG HSM | A +9 more
Isabel Cutler
Forum ProPosts: 15,448Gear list
Re: Guy?
Regards..... Guy
I wondered about this so I set my e-pl5 for 3:2 and I definitely do not have a 4:3 raw - it is 3:2.
What am I missing?
Isabel
 Isabel Cutler's gear list:Isabel Cutler's gear list
Canon EOS 7D Olympus PEN E-PL5 Panasonic Lumix DMC-GX7 Olympus OM-D E-M10 II Samsung Galaxy Note 4
Guy Parsons
Re: Guy?
In reply to Isabel Cutler, Mar 18, 2014
Regards..... Guy
What am I missing?
Isabel
The RAW is always 4:3 but some RAW converters are not smart enough to know that, they default to the jpeg settings. Usually there's a way to get to the full image.
Olympus Viewer 3 does 4:3 when asked, Silkypix does 4:3 by default, also AfterShot Pro does 4:3 by default.
Regards..... Guy
