D800 totally cooking reds
Started Mar 17, 2014 | Discussions
primeshooter
Senior MemberPosts: 2,853
Mar 17, 2014
Has anyone else observed the D800's tendancy to overcook red in images. Tends to be worse if it's a reddish glow or light, even shooting raw sometimes I am noticing it has totally clipped all information and it's doing it regularly. Is UNIWB the answer, if so can someone go into more detail.
Nikon D800
JacquesC
Senior MemberPosts: 1,622
Re: D800 totally cooking reds
In reply to primeshooter, Mar 17, 2014
In my experience most cameras tend to blow reds easily, and that includes the D800. For that reason I tend to dial in some negative exposure compensation when there is a lot of red in an image.
The camera that best handled reds was my Fuji S5Pro, it was quite amazing with that.
Jacques
apple-and-eve.com
Randy Z
Senior MemberPosts: 2,551
Every camera meter I've ever known has it's idiosyncracies that you have to deal with.  They each have situations where they're good at guessing, and different circumstances where they're not so bright.
As much as camera ads say otherwise, meters are just a place to start.  You can't expect your camera to know what you want to see, or what you're seeing, anymore than you can expect a car to drive itself because it has an automatic transmission.
Z-Man
primeshooter
In reply to Randy Z, Mar 17, 2014
Z-Man
Sounds like you are answering something i never asked. I don't expect it to do everything for me - I know how the meter works and why it's there! I'm asking for tips, workaround etc.
M Lammerse
Forum ProPosts: 11,208
'Sony reds'
I know what you mean,
And I call them Sony reds, due to that all of my Nikon camera's with a Sony sensor have the similar tendency
You can control it largely by making an own profile.
Michel
- Objectivity is of the very essence of photography, its contribution and at the same time its limitation -
http://www.fotopropaganda.com
http://www.fotopropaganda.com/blog
http://www.flickr.com/photos/9240992@N05
anotherMike
Veteran MemberPosts: 7,874
Nope. If anything, compared to the D700 I had, the D800 handles strong reds far better. Doesn't mean you can stop watching the exposure - gotta keep an eye on that for sure, but in terms of the body itself having a propensity to blow the red channel, no, I don't agree.
-m
j_photo
Senior MemberPosts: 2,379Gear list
It might help if you posted a sample or said under what conditions you are seeing this.
To some extent I agree with what you say. For example, when shooting Caucasian skin in strong lighting I set image preview to show blinkies on the red channel only. This works for me to avoid overexposure and produce good skin tones.
 j_photo's gear list:j_photo's gear list
Nikon D800 Nikon Df
39matt
Regular MemberPosts: 441
What are you using to post process your raw files.
Adobe standard in ACR and Lightroom overcooked reds but this solved by changing the camera profile in Lightroom etc to camera standard.
Once I had done this no more colour issues with the D800 files
_sem_
Veteran MemberPosts: 4,682
Z-Man
I think you've already mentioned the answer, UniWB. Next best should be fixed daylight WB and neutral picture control - for the RGB histogram. But you still have to watch it, because in high DR the meter goes roughly after luminosity (predominantly green) & midtones, not red highlights. ADL might help sometimes if you don't fiddle with EC. But it may not help enough, and it may harm if you do fiddle with EC.
Although I'm not sure why the cameras should not be able to protect the reds sometime in this millenium. On second thought they just might and very soon, but we will not like it for some reason.
Charles Bittinger
Regular MemberPosts: 129
In reply to JacquesC, Mar 18, 2014
Had the same problem with my D200 and D700 for red or yellow objects. Just used negative exposure compensation. Will probably have to do the same with my new D800. Thanks for the heads  up
Charlie
David314
Veteran MemberPosts: 4,790
Uniwb doesn't help
In reply to _sem_, Mar 18, 2014
_sem_ wrote:
Z-Man
assuming you are shooting raw with uniwb, it really doesn't help, you still have to white balance to have a viewable picture
and most red channel problems are not in the raw data, it is the conversion to jpeg where the issue is created
adventure_photo
Regular MemberPosts: 381Gear list
In reply to primeshooter, Mar 18, 2014
During capture, try looking at the RGB histogram and in particular the red channel. You'll have to underexpose a bit to minimize or eradicate clipping in the red channel. Two other tips, make your own raw custom camera profile using something like X-Rite Passport and the other is to reduce the luminance of red in your raw processor. In Adobe CR in the color adjustments there are adjustments with sliders for hue, saturation and luminance for all colors or use targeted adj tool that's also there too.
 adventure_photo's gear list:adventure_photo's gear list
Sony a6000 Sony Alpha 7 II Sony Alpha 7R II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Fisheye-Nikkor 16mm f/2.8D +20 more
Yxa
Yxa
Contributing MemberPosts: 656Gear list
In reply to Charles Bittinger, Mar 18, 2014
Charlie
I find the colors from D200 CCD sensor to be excellent, better than my D800
Martin Grecner
Contributing MemberPosts: 519
In my experience using Adobe RGB color space set in camera and viewing the result on an sRGB monitor causes overblown reds. If you are using Adobe RGB, try to switch to sRGB and see if if helps.
If you are already using sRGB, then the only option you have is watching your exposure, which is not easy to do as you do not have true RAW histogram on the D800, so finding UNIWB is the only way to be sure.
Martin
adrian1sun
Forum MemberPosts: 55Gear list
 adrian1sun's gear list:adrian1sun's gear list
Nikon D800 Sigma 150mm F2.8 EX DG OS Macro HSM Nikon AF-S Nikkor 50mm f/1.8G Carl Zeiss Distagon T* 2/25 Nikon AF-S Nikkor 85mm f/1.8G +1 more
JP Scherrer
Veteran MemberPosts: 9,403Gear list
Agree 100% on all that ! (image included)
...and indeed underexposing -1 EV can help !
Although I had forgotten that my D800 was set to ISO 1600, I underexposed -1 EV and (despite the noise created by the high ISO), the reds are absolutely not cooked !
J-P.
Photo Galleries at http://www.pbase.com/scherrer
Spherical Panoramas (360x180 degrees) at http://www.360cities.net/profile/jps
Equipment list in profile
 JP Scherrer's gear list:JP Scherrer's gear list
Nikon 1 V1 Nikon 1 J1 Nikon D800 Nikon AF-S Nikkor 300mm f/2.8G ED VR II Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR +8 more
j_photo
Re: Uniwb doesn't help
In reply to David314, Mar 18, 2014
David314 wrote:
_sem_ wrote:
Z-Man
+1
Nikon D800 Nikon Df
Mikael Risedal
Veteran MemberPosts: 4,049
Color space and profiles
In reply to M Lammerse, Mar 18, 2014
Some of you have to learn about color space and profiles.
Use Prophoto instead of s-rgb or adobe rgb and chose a good profile to the subject or make one by your self with for example www.qpcard.com if the scene has intensive colors
Then proof the colors into a smaller colorspace as S-rgb or adobe rgb
I have No problems with colors and/or what ever I shoot with, Nikon, Sony, Canon
Member of Swedish Photographers Association since 1984
Canon, Hasselblad, Leica,Nikon, Linhoff, Sinar
Ernest Hemingway to Irving Penn:?“Your photos are really good. What camera do you use?”?Irving Penn to Ernest Hemingway:?“Your novels are excellent. What typewriter do you use?”
Mikael Risedal
no I don't, and I use d800 daily in my work
If the scene has intensive colors, use a larger color space as Prophoto and select a good profile
se my answer about color space and profiles
aut0maticdan
Senior MemberPosts: 1,143Gear list
Can't say I have consistent issues with the D800 in this respect but there could be a lot of reasons for that. For times that I have color issues that are not (easily) correctible via WB adjustments in RAW processing, I use the awesome curves tool in Aperture. I find Aperture to have the most straightforward approach in this respect because you can stack many curves tools and have a separate one for just pulling down the highlights in the Red channel for instance.
This guy has an awesome four-part series on the Aperture curves feature:
http://photo.rwboyer.com/2014/01/23/aperture-3-curves-part-iv/
I'm sure much of it is applicable to other software, even if they're curves tools are not quite as elegant.
 aut0maticdan's gear list:aut0maticdan's gear list
Fujifilm X100S Nikon D800 Nikon Df Nikon D750 Sony Alpha 7S II +14 more
