SX50 HS portraits
Started Mar 16, 2014 | Photos
Paul S Wheeler
New MemberPosts: 7Gear list
SX50 HS portraits
Mar 16, 2014
Having used the SX50 mainly outdoors, during this winter I decided to practise portraiture in my living room, thanks to grandaughters Jamie-Lee & Kodie. Cheap white backdrop, 2 flash setup camera left and right, post processed in Lightroom 5
 Paul S Wheeler's gear list:Paul S Wheeler's gear list
Canon PowerShot SX50 HS
Comment & critique:
Dale Buhanan
Veteran MemberPosts: 3,975Gear list
Re: SX50 HS portraits
In reply to Paul S Wheeler, Mar 16, 2014
Those are very nice portraits with really lovely skin tones.  Well done!
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot G1 X II Canon EOS 7D Canon EOS 70D +34 more
Augustin Man
Veteran MemberPosts: 6,003Gear list
That's an excellent series, showing once more that in skilled hands SX50 could provide fine images even in other conditions than its intended target, i.e. daylight super zoom !
Congratulations and thank you for sharing,
Augustin
P.S. I'm just curious how much better these would be with a larger sensor camera?!
 Augustin Man's gear list:Augustin Man's gear list
Canon PowerShot SX50 HS Nikon Coolpix P900
VisionLight
Senior MemberPosts: 3,599Gear list
Welcome to the forum and congratulations on some very beautiful portraits of your granddaughters. As a photographer who from time to time also uses my SX50 for studio portraiture, I can appreciate your work.
What I like about the SX50 is that when using my full frame Canon dSLR, I can easily transfer the ST-E2 slave between cameras and use the same lighting set-up (2x 580 and 1x 430, with or without softboxes). I find the SX50 to give very pleasing results, both in skin tones and skin texture, at the 14mm to 18mm focal length (85mm to 100mm full frame) for "formal" portraiture.
I'm interested in your set-up. What lights did you use and how did you fire them?
Again, nice work.
Ed
 VisionLight's gear list:VisionLight's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
KJaay
Senior MemberPosts: 4,813Gear list
Excellent work Paul.
KJ
 KJaay's gear list:KJaay's gear list
Canon PowerShot S3 IS Fujifilm X-S1 Nikon Coolpix P600 Nikon Coolpix P900 Canon EOS 450D
Hollander
Senior MemberPosts: 1,370Gear list
Nice work Paul, your portraits picture are beautiful and so are your granddaughters. Love to see more of your work.
Rob.
To keep my brain active I'm looking forward to my next trip. So much to see yet and not enough time.
http://robvorderman.zenfolio.com/
 Hollander's gear list:Hollander's gear list
Panasonic Lumix DMC-FZ35 Canon PowerShot SX50 HS Sony Cyber-shot DSC-WX80 Olympus E-1 Olympus E-3 +3 more
unknown member
(unknown member)
Paul,
Nicely done!  I really like your high-key and fun shots of the two girls.  Their poses are so cute (future models?).  But my FAV is photo #3.  It is so soft, dreamy and captures the essence of childhood. -- lovely work -- thanks for sharing.
Murry
Paul S Wheeler
In reply to MurryG, Mar 17, 2014
MurryG wrote:
Paul,
Murry
Thank you for all the feedback so far, #3 was a candid moment when Kodie sprawled out on the backdrop sheet to watch cartoons on the TV behind/left of camera
Paul S Wheeler
In reply to VisionLight, Mar 17, 2014
Again, nice work.
Ed
Hi Ed, thanks for your feedback.
The shots were taken with a Neewer tt560 on the left slightly in front and aimed at the backdrop, and a Yonguo 565ex with a diy dome diffuser front and right also aimed at the backdrop. Both were manually set at about 1/4 power and fired optically from the on-camera flash set at minimum to try and avoid too much front fill. Some grey areas and wrinkles were brushed out in lightroom, and some cleanup work on Kodies socks, dirty from running around the house and garden! Processing topped of with NR/Sharpening and some eye clarity.
My first real attempt at high key portraiture, and a few lessons learned in the process
Paul
VisionLight
In reply to Paul S Wheeler, Mar 17, 2014
Again, nice work.
Ed
Paul
Thanks for that Paul. I was pretty sure I saw a third point light and you've confirmed it was the on-board flash. You controlled it very well. By the way, I think Newer makes a 8" or so mini foldable soft-box for your flash for about $8-$10. It might be worth a look see.
Ed
Monicakm
Senior MemberPosts: 2,344
In reply to VisionLight, Mar 21, 2014
Holy Moly, those are great!  Beautiful young ladies too   Is there anything this camera can't do in the right hands?
Monica/SX50
