One of these must go: D600 or D800. Which one?
Started Mar 13, 2014 | Discussions
jadot
jadot Regular Member • Posts: 182
Hi,
My Nikon Kit:
D800
D600
105mm
85 1.4
24-70 2.8
50 1.4
flash etc. and other bits.
I'm shooting mostly Fuji now but keeping one of the Nikon's. with a 58 1.4 and a 35 1.4
Fuji X-T1, 56 1.2, 18-55, X100s (35 & 28 Equiv f2), Flash & etc.
My question is this: Which one do I sell? D800 or D600?
I like both cameras, but can't make up my mind between the advantages which each present.
D800 - 1/8000th Shutter speed, 5:4 Crop mode (I use this all the time), Can get a nicer Eye cup. Resolution (See below!)
D600 - Smaller files sizes, Only 1/4000th (ouch), No Crop Mode, U1 & U2 Modes, Quiet(er) shutter. Better Colour wb?
What would you do? I can't keep both of them.
Thanks.
p.s - Please; this is not a discussion about whether I should or shouldn't choose to shoot with Fuji or whether that is a better or worse choice! I've been shooting Nikon for since the beginning, and I will continue to do so, but the Fuji X system offers a better all round solution for me and the way I work.
examples of my photography at www.alexanderleaman.co.uk
Fujifilm X100S Fujifilm X-T1 Nikon D600 Nikon D800
paulski66
paulski66 Senior Member • Posts: 2,746
I would get rid of the one you like less...
6
...and keep the one you like more.
 paulski66's gear list:paulski66's gear list
Panasonic Lumix DMC-LX5 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +2 more
frank-in-toronto Senior Member • Posts: 1,028
Re: I would get rid of the one you like less...
i can't imagine why u would not keep the best one (obviously the d800).
jadot
jadot OP Regular Member • Posts: 182
Helpful.
jadot
Why is the D800 (obviously) better?
Ansel Spear
Ansel Spear Contributing Member • Posts: 555
Re-read the reviews.
I can only assume that you need the money, otherwise you'd keep both.  Therefore I suggest that you sell the D800, as you'll get more for it.
I also think that, if you don't know which of the two is the better camera, sell the D800 as it's wasted on you
 Ansel Spear's gear list:Ansel Spear's gear list
Sony Cyber-shot DSC-RX100 III Nikon D800 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +10 more
jadot
Another helpful and educated insight. Thanks!
T O Shooter Senior Member • Posts: 4,986
You have to decide based on
the parimeters that only you know. Personally, I'd keep the D800.  You should know what attributes of each you like, and which are most important.  This is a thread that shouldn't even be here. You own both bodies. Should be an easy choice. Why do you think anyone on here can help you decide??  I could see if you were looking to buy and hadn't owned either and needed some advice.+
Photography - It's a passion No other reason required.
 T O Shooter's gear list:T O Shooter's gear list
Canon PowerShot G5 Nikon D4 Nikon D810
paulski66
Re: You have to decide based on
I know, right?
ChapelThrill23 Contributing Member • Posts: 642
Re: One of these must go: D600 or D800. Which one?
If you are mostly using the Fuji system then it might make sense to sell the D800 and pocket more cash that you could then either invest in Fuji lenses/gear or just hold on to.
adventure_photo
adventure_photo Regular Member • Posts: 478
Wow that's a tough one. I own both D600 and D800 as well as the Fuji X-E2. I really like both Nikons so it would be a painful decision. If I absolutely had to make the choice, I'd keep the D800. It has slightly better and faster AF, more AF points, and higher resolution and beefier build quality. You've already got the lightweight alternative covered with the Fuji system.
 adventure_photo's gear list:adventure_photo's gear list
Sony a6000 Sony Alpha 7 II Sony Alpha 7R II Sony Alpha a6300 Nikon AF-S Nikkor 14-24mm f/2.8G ED +25 more
jadot
Ok, first of all, people need to drop the forum police defensive approach.
"This thread shouldn't even be here"? WTF?
I have a fairly good idea of which camera I want to keep, and FWIW I like both cameras equally. They do different things well.
The original question is a philosophical one, and one that could point to an interesting debate with considered responses. For e.g. Just asking the question suggests that for practical purposes it could be argued that these two bodies are more or less equal. Or, if the D600 would be kept over the D800 does that suggest that the extra features/customisations of the D800 are "worth" the extra cost?
If you don't like what you read in forums, why a) read them and b)respond??!!
in reply to frank-in-toronto; If the D800 is obviously better, then why did Nikon introduce new features to the D600 e.g User modes. Is 36MP better than 24? My Hard drives don't think so! Is it better because it costs more? If the D600 costs less, is more or less equal to the D800 in terms of IQ (some would say 'better' at high ISO) then isn't that 'obviously' better?
j_photo Senior Member • Posts: 2,548
I would keep the d800. I like the controls, larger files, and better focusing.
I don't think this is a philosophical question. You haven't told us anything about how you shoot or what's important to you in a camera. So how are we supposed to provide meaningful suggestions? If you have shot with both and neither seems to offer any strong advantage for you, then sell the one you can get more money for.
 j_photo's gear list:j_photo's gear list
Nikon D800 Nikon Df
You did not put in any info on what you shoot, if weight was a concern nothing. Just "which one would you chose?"  You own both - you don't need help from us. That's "WTF"
This has been debated on here forever. So you're a little late to the party with an "interesting debate"
I gave an appropriate response to a kind of "useless" question. Never said I didn't like what I read. You just don't like being told the truth.
jadot
thanks for that.
Anyone else here got anything constructive to offer?
bocajrs
bocajrs Senior Member • Posts: 1,571
Sell D600 and keep D800 - That's what I did
 bocajrs's gear list:bocajrs's gear list
Nikon 1 J4 Nikon D750 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Teleconverter TC-20E III Nikon AF-S Nikkor 24-120mm f/4G ED VR +2 more
jadot
Started well, but then you got a little bit cross.
I don't know why this question is upsetting people enough to feel compelled to tell me where to stick it!
Does it matter how I shoot? (BTW, the answer's in my sig) - Most cameras at this level can handle most situations well, and I'd dare say that both the D600 and D800 are aimed at a similar demographic. It's hardly point and shoot vs Phase One here...
I asked, Which one would you keep? It's a curiosity, not an attack!
jadot
Thanks. You and a couple of others managed to answer the question! That's probably what I'll do, but I was playing with the 600 this morning and kind of enjoyed the weight etc. Especially with the 50...
JayDreamer
JayDreamer Regular Member • Posts: 346
If your main camera is Fuji and Nikon is a backup that you use only once in a while or when needed then keep the D600 as it can do almost everything and it is been used as both a main or backup camera successfully. You can use the money from D800 to add more fuji gear or save it.
If your main camera is the Nikon and Fuji is your backup or day to day / walk around camera then keep the D800. Simple
Jay
Images from the mind are surreal!
 JayDreamer's gear list:JayDreamer's gear list
Nikon D610 Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 50mm f/1.8G Rokinon 24mm F1.4 Aspherical +7 more
paulski66
Sensitive much?
You're the only one getting upset.
If you're shooting a lot of sports, perhaps the d600 with its faster framerate would have a slight edge. Landscapes? Maybe the d800 with its extra megapixels would have an edge. Lots of travel/banging the camera around a lot? Again, maybe the extra build quality of the d800 is more important.
So, we're supposed to go do research on your shooting habits to answer a question for you?
I stick with my original suggestion: Keep the one you like more.
